Old Dec 07, 2012, 09:03 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
My 5s3p 24ah LiFepo4 field battery.
Hi guys,
to plan for next year, I am now building a field battery from Headway 38120SP 8Ah LiFePo4 cells.
I got these from the german dealer www.Lipopower.de :
http://shop.lipopower.de/LiNANOZ-8-A...eadway-38120SP
For the rest of the world, there is Ebay.
There are cells with the same size but 10Ah. But these are not rated for high currents (20C) like the 8Ah version.
What I like about these cells is that they are prepared to be easily assembled to packs and connected.
So I will actually have a little fun during the process, instead of getting a soldering nightmare.
I liked the method of bolting the cells to a PCB though, so I keep this for the new pack.
There are, however, connection brackets available that would make things even easier.
I tested each cell for capacity, and assembled the cells in 5 groups with about the same combined capacity. After some initial discharge tests, I swapped individual cells between the strongest and weakest groups, until I reached a difference of less than 0.05V throughout the whole discharge process.
I cut the PCB material to shape with a dremel and a disc. I have a vacuum with a water filter, but if you don't, this work must be done with a dust mask, and outside.
To get the "traces" or better, the separations between the individual copper surfaces, I grinded the blunt side of a workshop knive to have a single saw tooth, and planed away the copper in thin layers about 0.5mm wide, until I reached the base material.
If you look carefully, you can see two of these strips with the copper removed in the last image, parallel to the silver connection bracket.
I used lugs to connect the power and balancer cables with the individual copper areas.
The CAD for the case is ready, and I will soon make it at a friend's who happens to own a CNC router.
Edit!
The case is now finished, and everything fits and works perfectly! The flying season can start!
At the front panel, one can see both the MPX output connectors, and the balancing connector. During operation, I plug in a programmable LiPo warner (~$3 on eBay) programmed at 2.8V, which will immedialtely alert me, if the pack is flat.
Julez is offline Find More Posts by Julez
Old Dec 07, 2012, 09:04 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Here are the CAD drawings of the pack!
Old Dec 07, 2012, 09:42 AM
eMoon is online now
Find More Posts by eMoon
I meant to do that
eMoon's Avatar
United States, NY, Albany
Joined Sep 2011
I'd be interested to understand how you wired the balancing cables too. My simple mind just can seem to grasp it as I'm just beginning to learn about parallel set-ups.
I'm thinking about a 4s2p configuration for my charger and would like to be able to balance charge them when on ac power at home.
Also, do you recommend the high discharge of 20C for anyone looking to do this or is that just the bulletproof, ready for armageddon, German engineering mind? I thought a 10c continuous rating would be enough since there isn't a burst moment when charging, correct?
Evan
eMoon is online now Find More Posts by eMoon
Old Dec 07, 2012, 09:57 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Hi Evan,
here is a start for balancing information:
https://sites.google.com/site/tjingu...nce-connectors
I will attach a more detailled connection plan soon.
Yes, I chose the 20C version because when I do something, I do it right. These cells have a lower inner resistance, and keep the voltage under load better.
As energy is not only based on capacity, but also on voltage, the lesser capacity might be compensated by the better voltage.
Also, these cells can stand a higher charge current, and I might charge with 30A if I'm in a hurry.
Old Dec 07, 2012, 12:22 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Thanks for the thread Julez!
Is there a good source for these cells in the USA?
Are they any good for flight packs?
jrb is offline Find More Posts by jrb
Old Dec 07, 2012, 04:15 PM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
You're welcome.
I don't know about any US suppliers, but there must be some. EV folks and Ebike enthusiasts use them.
I know of one plane powered by these cells:
http://www.modelflyvning.dk/forum/sh...&postcount=182
A large piper powered by a 16s pack.
I have also updated the initial posting with a wiring schematic.
Old Dec 07, 2012, 05:16 PM
Wayne Giles is offline
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
Julez,
I made up a 24V pack of these Headway cells to power my wife's disabled shopping buggy about 18 months ago although I used the 12Ah version.
They have done the job perfectly. Previous efforts to replace the standard lead acid batteries with LiFeP04 packs from HK were disastrous as they were rubbish.
I also used a battery management system which keeps them in perfect balance although I use a simple non balancing CC/CV charger. It also isolates the cells via series Fets in the case of excessively high charging voltage or overdischarge.
After 18 months use I checked the pack last week and all the cell voltages were balanced to better than 10mV.
I don't know whether there is a 5 cell version, but the 8 cell is at http://www.eclipsebikes.com/cell-30a60a-p-1040.html
Thoroughly recommend both the cells and management system
Wayne.
Wayne Giles is offline Find More Posts by Wayne Giles
Old Dec 07, 2012, 05:37 PM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Hi Wayne,
thanks for your interesting information. It's good to hear that the Headway cells perform well!
On my field packs, I only balance charge, and on the field, I use a warning beeper on the balance contacts, that alerts me as soon as a single cell group falls below a certain threshold.
This prevents both overcharge and deep discharge.
For my electric bike, I prefer a BMS though, as 16s are another dimension.
http://www.bmsbattery.com/bmspcm/323...rrent-bms.html
Here, a BMS system is essential as you write.
Cheers,
Julez
Old Jan 06, 2013, 04:20 PM
caioect is offline
Find More Posts by caioect
Brasil, São Paulo, São Carlos
Joined Sep 2004
Hi Julez,
Here is my field battery (LiFePO4 4s 10Ah) from Headway 38120S 10Ah cells. I´m using to charge A123 2s-4s 1100mAh packs with 5A.
http://www.e-voo.com/forum/viewtopic.php?p=1334881
Caio
caioect is offline Find More Posts by caioect
Old Feb 06, 2013, 11:07 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Wonderful! Very leightweight, ideal for recharging on the slope from the backpack!
Meanwhile, I have finished my pack. I updated the forst posting.
Old Jul 19, 2015, 03:10 PM
Jaketheone46 is offline
Find More Posts by Jaketheone46
Jaketheone46
United States, KY, Florence
Joined Nov 2014
Looks great Julez what's up with your last pack was it already giving up on you?? I thought it was just last summer you had built it but I'm probably wrong.
Jaketheone46 is offline Find More Posts by Jaketheone46
Discussion PROGRAMMING ESC FOR LiFePo4 Batteries Bjorn B Power Systems 9 Oct 23, 2013 11:25 AM
Cool Lifepo4 Field Charging Pack (lead acid alternative) la528it Batteries and Chargers 16 Nov 25, 2012 11:50 AM
Discussion Did field charging kill my car battery? arnav Batteries and Chargers 117 Oct 14, 2012 03:26 AM
Discussion Max charge current for a LiFePo4 battery? flyboy320 Batteries and Chargers 7 Jul 27, 2012 03:58 PM
For Sale 48v 24ah battery packs for car Lindapapa Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 03, 2012 10:09 PM
