Old Dec 07, 2012, 08:22 AM
chemnut842 is offline
Find More Posts by chemnut842
United States, MD, North East
Joined Apr 2011
Bolt pattern
Ok, I think this is a good forum to start but I can move the topic if I have to.
I have a 4X4 inch aluminum plate (1/8 inch thick) that needs 12 holes drilled in a very specific orientation. I know I should use CNC for this but...
Is there some piece of software that I can place dots with specific measurements and print it out. Then, tape the paper to my aluminum plate and smack each dot with a center punch?
Is there some better way of doing this that does not involve CNC?
- Joe
chemnut842 is offline Find More Posts by chemnut842
Old Dec 07, 2012, 08:56 AM
Wazmo is online now
Find More Posts by Wazmo
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
Just draw your template in Inkscape. Use guides to get accurate positions and angles. Or send me your specifications, and I'll send you a PDF.
Wazmo is online now Find More Posts by Wazmo
Old Dec 07, 2012, 09:52 AM
Joined Apr 2011
Cool - I will give inkscape a shot. I really appreciate the offer on the PDF but right now my prototype is a cobbled-together, eyeballed rigging that works; but I need to do it right for this version - which means I have not measured and calculated everything yet.
Thanks a bunch for the link.
The chassis is for an on-board starter I am designing. As you can see - the aluminum I am currently using has a lot of flex (1/16 inch). I will go thicker and add L-shaped aluminum braces across the top as well.
Starter (0 min 11 sec)
Old Dec 07, 2012, 10:14 AM
Wazmo is online now
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
Do you have a one-way bearing in there, or some way for the engine to run after it starts without driving the starter motor?
Old Dec 07, 2012, 10:21 AM
Joined Apr 2011
yup, there is a sprag on the flywheel gear.
I started a thread in the engine section on it - I am having lots of problems but that is the nature of anything I try to design.
http://www.rcgroups.com/forums/showthread.php?t=1784305
For Sale Menzs Prop 28x10 drilled for DA100, DA120, DLE111 bolt pattern noahb Aircraft - Fuel - Engines and Accessories (FS/W) 2 Dec 20, 2012 02:40 PM
Discussion standard bolt pattern? seeyalaterbye Electric Motor Design and Construction 5 Jun 09, 2012 12:10 AM
Question Rimfire Prop Adapter Bolt Patterns Chophop Power Systems 0 Apr 22, 2012 06:58 PM
Question Gold Big Screamer Bolt Mounting Pattern Help bri6672 Electric Ducted Fan Jet Talk 2 Apr 17, 2012 11:41 PM
