Old Dec 08, 2012, 12:58 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
While your batteries may be performing to your satisfaction, there is absolutely zero doubt that they would most assuredly be performing better if they were maintained per best practice and stored well below full charge. There are mountains of data that support this.
Like you, there are some who find the accelerated degradation worth the convenience of having charged packs ready to go. For others, the slight inconvenience of charging immediately prior to flying is a small price to pay for the increase in longevity and long term performance.
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Dec 08, 2012, 01:08 PM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
As you say, it's all about choices. It's worth it to me to go out to the field, plug in a batt, and fly. This is the batt i'm using. I figure after 5 yrs. of good use it doesn't owe me anything. Also, I go by leaving 20% left in the batt. after a flight, which it still does. This is the biggest batt. killers in my book..
http://www.hobbyking.com/hobbyking/s...poly_Pack.html
Heck, That's the price of a tank of gas in my van.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Dec 08, 2012, 01:16 PM
So. Cal.
Agreed. Most if the time I will charge 12-20 packs at home in ~15-20 minutes prior to heading out to the field. I only drag my deep cycles if I am going to be flying all day, which is rare. All packs are discharged within ~4 hours of charging.
Mark
Old Dec 08, 2012, 01:52 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I'm a retired old phart so I go out to the field 3 or 4 times a week in the summertime and usually fly fron noon till dark. I have a little 1000 watt Champion inverter generator with two 200 watt chargers that are going steady. Probably uses 2 or 3 qts of gas in the day. Usually half a dozen different planes. I like the variety, all different personalitys
Gord.
Discussion When Charging Lipo's At The Flying Field Do You Do A Fast Or Balance Charge? itsme2 Batteries and Chargers 60 Aug 30, 2012 05:50 PM
Discussion Watch out for hitchhikers when you leave your bag un-attended. kilwein Multi Task F3X 23 Jun 13, 2012 11:06 PM
Question What do you do when you're between props? Mr. Wiz Power Systems 8 Mar 30, 2012 01:09 AM
Question Hobbico Quick Field Charger MKII - *how* do you know when a battery is charged ? FrostyTheBeerman Fuel Plane Talk 8 Aug 24, 2005 11:45 AM
Question How do you know when a battery is fully charged? Composer Dan Batteries and Chargers 6 Apr 11, 2004 02:54 PM
