Old Dec 07, 2012, 05:40 AM
Joined Oct 2012
ESC choice for 450 PRO
Hi guys!
Help me choose ESC for 450 PRO ..
Helicopter Tarot 450 Pro, motor Tarot 3800.
Stood hobbyWing 60A, now it does not work correctly.
Here is what I found:
Hobbyking 70amp OPTO ESC with 5 Amp External UBEC
Turnigy dlux 55A SBEC Brushless Speed Controller w/Data Logging
TURNIGY TRUST 55A SBEC Brushless Speed Controller
Turnigy AE-65A Brushless ESC
Turnigy Super Brain 60A Brushless ESC
TURNIGY Plush 60amp Speed Controller
Turnigy dlux 40A SBEC Brushless Speed Controller w/Data Logging
TURNIGY K-Force 40A Brushless ESC
Power wants 50-60A, that the stock was) in the future))) And I want to stress at the BEC 5,5-6 volts ...
I think the first option is the best.
Who else thinks? Can someone tell me anything else?
Thank you all in advance!)
Pavel83 is offline Find More Posts by Pavel83
Old Dec 07, 2012, 07:08 AM
Get to the choppa!
RFDelie's Avatar
United States, PA, Pittsburgh
Joined Sep 2012
I have this esc on my 450 it has served me well.
http://www.amainhobbies.com/product_...-Brushless-ESC
I don't know why you need 60a?
RFDelie is offline Find More Posts by RFDelie
Old Dec 07, 2012, 07:55 AM
Joined Oct 2012
I think the power supply can not hurt. Is not it? Or does not make sense?
Thanks for the link, I would like to order from HK, because for me there is going to parcel)
Old Dec 08, 2012, 10:46 AM
If I drop 1 more heli screw...
finguz's Avatar
United States, CA, El Cajon
Joined Mar 2012
I bought an Exceed 40a ESC from xheli last March (when I started flying helis) and it's running strong still. At the time they were about $21, now they are $28... I guess they're real proud of them.
I also own an Align ESC 35a that isn't bad. But maybe not worth the dough. BTW one thing, IMO the slow start on the align is awesome compared to the exceed. It's nice, even, not too slow, but graceful, like a full scale heli.
I would consider a turnigy, depends on how much is wrapped up in the heli. I wonder when my exceed will give up maybe.
Hobbywing, Exceed, Turnigy all have the same programmer, I wonder if they are all the same guts.
finguz is offline Find More Posts by finguz
Old Dec 08, 2012, 10:47 AM
finguz's Avatar
Joined Mar 2012
duplicate post, sorry
Old Dec 08, 2012, 03:38 PM
Joined Oct 2012
Thank you for your recommendation.
I choose from the range of Hobby King.
And I'm looking for good options and stable operation.
If I had been free on $ 100-200 ESC, I would look for somewhere else))))
I'm a beginner, and while you do not want to spend much on this hobby ....
Now I choose from:
Turnigy dlux 55A SBEC Brushless Speed ​​Controller w / Data Logging
TURNIGY Plush 60amp Speed ​​Controller
Someone experienced can give something, what would you choose?
Thanks in advance to all for your answers and advice!)
Old Dec 08, 2012, 10:43 PM
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
My 2c
Now I choose from:
I've used a few different ESC's on my 450 Pros.
HK Blue Series 40A - cheap, decent SBEC that can run all digital servos, can run up to 6s, not very good governor mode.
Hobbywing Platinum Pro 40A (same as HK K-force 40A) Excellent, SBEC adds choice of 5v or 6v outputs, can run up to 6s packs, better governor mode than Blue Series, easy to program with TX.
Turnigy Superbrain 40A - Data logging ESC, with great governor mode. Only has a 2A linear BEC, so you need to add a UBEC to run digital servos. Only does up to 3s packs.
Turnigy Superbrain 45A - Data logging ESC, with great governor mode, also with 3.5A SBEC that's fine for running all digital servos, though with only a 5v option. Can run up to 6s packs. Mine doesn't show current draw properly in the data logs, but voltage and rpm seem fine.
One that I have yet to try, but it's getting great reviews - the YEP 45A. It reputedly has a great governor mode, a good SBEC, 6s capability, and a feature called "active freewheel" that enables it to run low throttle percentages without overheating, but it's a bit of a bruiser at 63g.
All of the above ESC's would be a tight squeeze between the 450 Pro frames, which are only 1" apart. No problem for me, since I prefer to mount them on the outside of the frames.
2Doggs is offline Find More Posts by 2Doggs
Old Dec 09, 2012, 12:24 PM
Joined Oct 2012
Thank you for your response.
Your answer helped me decide ...
I searched informations about HK K-force 40A and YEP 45A on the Russian speaking forums. I'm from Russia
I found a lot of opinions that YEP 45A better than K-force 40A ... This is the opinion of those who experienced these ESC.
As a result, I ordered YEP 45A and card programming. In any case, ordered UBEC 6V/3A. useful
The theme can be considered closed.
Thank you all for your answers and advice!
Good luck, and regular landings!
Old Dec 09, 2012, 12:30 PM
2Doggs's Avatar
Joined Nov 2009
I think you'll be really happy with the YEP!
Old Dec 09, 2012, 12:36 PM
Joined Oct 2012
Thank you!
I hope so too!
Found WTT 450 Sport Belt Tail (for Pro) for 450 Pro Tail SYMAWD Aircraft - Electric - Helis (FS/W) 0 Apr 11, 2012 07:28 PM
Discussion Pinion choice for Trex 600EFL Pro seraphSG Scale Helicopters 10 Mar 11, 2012 04:46 AM
Sold HobbyWing Platinum-40A-PRO Brushless ESC for Trex 400/450 helifreak592 Aircraft - Electric - Helis (FS/W) 0 Feb 24, 2012 04:31 PM
Help! Choice of Motor and ESC for Align 450 Pro lcc014 Mini Helis 16 Jul 29, 2011 07:18 AM
Wanted Just bought a 450 pro and need the electronics since I need electronics for a 450 pro nyesteban Aircraft - Electric - Helis (FS/W) 3 Oct 19, 2010 04:43 PM
