Old Dec 07, 2012, 05:27 AM
darrom is offline
Find More Posts by darrom
Joined Dec 2012
rx board mod!
I have an rx receiver that has a 5 wire servo input for a servo that uses 5 wires , would anyone know how if it is possible to change the wire input to three wires so i can use a servo with three wires ?
darrom is offline Find More Posts by darrom
Old Dec 07, 2012, 02:15 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
No, but you might be able to convert your 3 wire servo to 5 wires. Just remove the control board inside the servo, and connect the 5 wires directly to the pot and motor. To find out which wire goes where, look inside an old 5 wire servo. If the servo motor drives continuously then it's wired backwards, so swap its wires over.
Another possibility is to find the PPM signal coming out of the receiver chip, and add your own decoder. However if the pulses are non-standard then you will probably need a custom programmed microcontroller to do the job.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Dec 08, 2012, 06:11 AM
XtalHunt is offline
Find More Posts by XtalHunt
United States, TX, Austin
Joined Sep 2012
Why bother with such a project when a receiver can be had for ~$12 and fairly reliable servo can be had for ~$5?
XtalHunt is offline Find More Posts by XtalHunt
Reply With Quote  (Disabled)
Old Dec 09, 2012, 03:58 PM
Joined Jan 2001
After reading his other posts, it looks like he wants to use a particular digital servo in a Losi Micro-T, and the 3 wire receiver required costs $20.
That's probably the best option, but as this is DIY electronics we are expected to provide a DIY solution! A simple 2 channel decoder can be built with a few standard electronic parts, costing under $10.
Here's an example circuit that uses only 4 parts. If the pulses are low level then you may need to add a transistor and resistor to amplify the signal.
For Sale Happy Sundays Modded KK v 5.5 Black Board thefokker Aircraft - Electric - Multirotor (FS/W) 5 Jul 15, 2012 05:35 PM
Sold Turnigy 9 x with er9x installed backlight mod, usb programmer mod + 4 rx KiTCyclic Aircraft - General - Radio Equipment (FS/W) 3 Jun 20, 2012 05:01 AM
Discussion Axe CP v3 RX Board / Belt Mod wiring HELP! Bladerrunner Mini Helis 0 Dec 16, 2009 04:00 PM
Discussion AA rx board help......actuator mod-4mm pager motor customminatures Micro Ready-to-Fly 2 Jan 19, 2008 08:57 AM
