Old Feb 06, 2013, 08:39 PM
shahram72 is online now
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
I ordered a 12 tooth pinion to go with it. Stock was 14 tooth
shahram72 is online now Find More Posts by shahram72
Old Feb 07, 2013, 07:15 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
If you're running a lower kv motor, you'll want a bigger pinion to get some speed back.
wparsons is offline Find More Posts by wparsons
Old Feb 07, 2013, 07:36 AM
Joined Sep 2011
I ordered the 10300kv motor. Its on backorder ao the project is on hold ffor a while.
Old Feb 07, 2013, 10:05 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Ah, gotcha. Good call on the pinion then!
Old Feb 07, 2013, 01:10 PM
Joined Sep 2011
Yeah, I knew it was going to be too fast, so I guessed. You think that's a good choice? I still want to be able to do some crazy speed runs sometimes. Also, I think I need to upgrade this to bearings, no? I guess I need front spindles and a bearing kit. Does anyone make a decent bumper for this thing? The micro DT bumper is too small to protect it.
Old Feb 07, 2013, 02:53 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You shouldn't need front spindles to add bearings. I had bearings in mine without needing other parts.
Old Feb 07, 2013, 04:53 PM
Joined Sep 2011
What tool is best to remove those tiny e clips? I can those flying accross the garage. Better order some spares.
Old Feb 07, 2013, 07:15 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Buy the axles with nuts while you're at it, you'll thank yourself many times over later.
Old Feb 08, 2013, 12:04 AM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
+1
Those clips are fine, as long as you never take the wheels off.
SoloProFan is online now Find More Posts by SoloProFan
Old Feb 08, 2013, 03:09 AM
Joined Sep 2011
Yeah, I don't plan too, but still, what tool is best used for the clips?
Old Feb 08, 2013, 08:56 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
A small screwdriver, and remove them inside a big ziplock back so if the clip flies off it's contained.
Old May 02, 2013, 10:59 AM
Joined Sep 2011
OK, been waiting about 3 months now for that backorder motor. What a waste of time. I cancelled it today. looks like they have a new version now but it's out of stock as well. Typical. And the pinion I ordered was wrong anyway. These motors all use 1.5mm pinion and HK stocks 2mm but only 9T in 1.5mm. So I still need a motor and refuse to pay $30 for it. If I use Losi parts what's the point!?!?
In other news, I did get an HXT500 to work with just the mounting screw mounted from the bottom of the servo arm.
Losi Micro Desert Truck with HXT500 steering servo (0 min 21 sec)
Old May 02, 2013, 07:40 PM
Artur Fischer is offline
Find More Posts by Artur Fischer
Brazil, SC, Brusque
Joined Aug 2012
Hi, the HK motor the pinion will be a little loose on the shaft.
My way to solve this is: get a small piece of heat shrink and put around the shaft, then press the pinion on it, to finish cut the heat shrink that exceeds the pinion.
thanks!
Artur Fischer is offline Find More Posts by Artur Fischer
Sold Team Losi 1/36 Micro-T brushless with receiver and extras spbalaj Cars - Cars and Parts (FS/W) 3 Nov 01, 2012 08:05 PM
For Sale Vorza Flux/E revo brushless/1/36 scale micro t Australia buyers helicraze Cars - Cars and Parts (FS/W) 0 Jun 13, 2012 08:46 PM
Sold 2 Brushless Micro Setups, Servos / Motors / Escs Johnnymeg Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 May 13, 2012 06:27 PM
Sold 1/36 losi brushless system 10250kv micro t ect....15 shipped motor is bad rc4life85 Cars - Accessories (FS/W) 0 May 11, 2012 08:18 AM
Wanted Brushless setup for micro-t edu01jose Cars - Cars and Parts (FS/W) 0 Sep 01, 2008 12:26 PM
