Old Dec 06, 2012, 11:49 PM
DanL is offline
Find More Posts by DanL
DanL's Avatar
United States, MN, Brainerd
HELP to modify JR X9503 Please
The JR X9503 has a small lever on each upper side of the case. The two levers are called right trim amd left trim. The levers operate over a range of about 70 deg rotation.
The 5K pot inside rotates maybe 120deg, but the lever mechanism limits the pot rotation. The change in R over the limited rotation range is only about 600ohms.
I want to change the levers to knobs that will rotate a full turn for more precise control. What R range does the radio have to see to put out the proper signal?
Is 5Kohm the necessary range, or is the radio looking only for a delta-R?
Any tips, clues, solutions very much appreciated.
Dan
DanL is offline Find More Posts by DanL
Old Dec 08, 2012, 07:32 AM
XtalHunt is offline
Find More Posts by XtalHunt
United States, TX, Austin
Joined Sep 2012
Take the original 5k pot and add 20%. 6k ohms. Work from there. But you're not going to find a 6k pot, that's why they used a 5k, to keep it cost effective.
XtalHunt is offline Find More Posts by XtalHunt
Reply With Quote  (Disabled)
Old Dec 11, 2012, 10:12 AM
microfan is offline
Find More Posts by microfan
Germany
Joined Nov 2012
All newer radios are looking for valtages not Rs. So just measure the voltage at the output line at both endpoints and this is what you have to create agian.
You might use a 1k pot (or 500 Ohm) and 2 fixed Rs at the + and - lines, which reduce the voltage range to the range required.
microfan is offline Find More Posts by microfan
Old Dec 11, 2012, 09:40 PM
DanL is offline
DanL's Avatar
Thank you.
I tried a 5K linear pot with 330 deg rotation and got a full range of output to the servo over the full range of the pot.
Previous rotation was only about 80deg, so I have the increased control deflection that I needed.
Sold JR X9303, JR X9503, DX-8; 2 x AR9000, 2 x JR R921, AR7600 jgalexander Aircraft - General - Radio Equipment (FS/W) 8 Nov 14, 2012 01:35 PM
Help! A sensitive plea for help.... David A Ramsey Life, The Universe, and Politics 147 Jun 27, 2012 09:01 AM
Help! Blade msrx and JR x9503 help!!! pyrosamz Micro Helis 2 Feb 08, 2012 06:07 PM
Discussion JR X9503 Help!!!!!! Feliperc Radios 5 Oct 30, 2011 09:40 PM
Help! JR X9503 Throttle Timer Help !!! wrathofkhan Radios 9 Aug 02, 2010 04:11 PM
