Pictures, as assembled! I did add some 4-1/2" tires, as I fly off of grass for the most part. I also had not put the bracing wires on the tail feathers as yet. Otherwise, it is as unboxed, and put together. Enjoy!
![]() ![]() ![]() ![]() And yes, that is a full size pool table it is on. This model is big.------Metalguy |
Canada, BC, Vancouver
Joined Dec 2011
Hi guys I have flown my Dec 8 times . It fly`s very scale . Just like a real Decathlon . Great flying aircraft. Landing and taking off on pavement with the original wheels. I have used three different battery set ups, 5000 ma , 4000ma, two 2200, all 4 cells. No problems with C/G. Getting 8 min. with 4000ma so far. Large battery box area to play with .I have changed prop to 13in 3 blade 8 pitch. OEM prop was drilled off center . Changed the front landing gear axels to 4mm drilled out old hubs using original wheels. Put a Sullivan 5-12 lbs tail wheel on the back using the original rear wheel {HK sells sullivan`s too}.Replaced the rudder hinges . Packing taped the inside of the engine cowl . Installed a bec. and 55 amp esc. I checked getting 26 amps full power with original out of ballanced prop. Original motor has lotsa power ! I am still working out the best prop and battery combinations . I always put a bigger esc in P.N.P. aircraft. The rest is stock and airframe is well built . This is a screamng deal for 6 foot $100 P.N.P. aircraft . I have also made a engine cowl mold for making new cowls out of two ply fiberglass .
I have flown mine once so far' and the only mod was to use pinned hinges on the control'surfaces, and to put 4.5"wheels on it for grass strips. My maiden found the elevator touchy for my taste, but once I calmed my thumbs down, it is a pleasure to fly. I think it could use a different prop size, but will play with that later. I may get some flying in this afternoon, if it stops snowing here in Yakima. I did have to glue in some velcro in the cave called a battery bay, but it is nice to not have to shoehorn a pack in there. I'll throw a camera on it next time I fly, as there is plenty of room to do so. Fun plane, and a bargain. I was able to fix my cowling by putting tape on the back side, and CA in the two cracks. I may make a new one from a 2 liter bottle after I make a plug to shrink it on.-----Metalguy
Joined Mar 2012
Hi Guys,
I've just started building this model but I've discovered that there are some parts missing from the hardware pack-the tailwheel/rudder horn and the screw for the spinner. Can anyone advise where I might be able to get replacement parts? Kinda in a bind as I bought the model in Switzerland and no suppliers here in the UK appear to have stocked the model. Thanks, Bill |
Joined Dec 2011
The original tail wheel hardware is junk Replaced it with a 5-12lbs Sullivan tail wheel kit $6 at H.K. The original rear wheel fits the new Axel. Front wheels are not big enought for grass.
My original prop could not be balanced . I am using a 3 bade 13 inch 8 pitch master screw prop. Lotsa torque nice fast take offs. I am still experimenting with props and batteries |
United States, WA, Olga
Joined Dec 2011
I will be experimenting with props shortly. The original is a 14" prop, and I bought a 14-7 APC prop as a spare, but after flying it a couple of times, it seems to need more pitch. Just not enough umph! to fly really well. I shall get out the wattmeter, and do some tests, and see what I can come up with. I also need to make a plug to pull new cowls over. I am sure this cowling will explode with any impact. Mine arrived with two cracks along the cowl, but were easily fixed with tape to back it up, and a line of CA glue in the crack. A two-liter bottle should yeild a good cowl. I am thinking of getting another one of these, just because it is such a good deal. After flying a couple of times, I think I will be flying this a lot. I put 4.5 inch foam tires on it, and it handles grass very well now. The stock aluminum undercarriage is junk. No spring to it, and bends easily. I shall make new ones, perhaps out of Titanium, for springiness. Huge presence in the air, and flies well, even underpowered. Tons of space in the battery bay for large batteries, too. and camera gear, and anything else you want to put in there. Nice, scale plane.-------Metalguy
Yes, I think it has everything to do with the stock prop. Weird thing is that they painted the prop! It is white, and the paint is flaking off everywhere after just two flights. I have an APC, and will do some tests on both, but I am betting the APC will come out ahead in performance. ------Metalguy
To bad HK won't ship the 1800 Decathlon. I was searching around and found a nice 1400 Decathlon at PW-RC. cost more, but looks nice. other than that I don't know anything about it.
http://www.pw-rc.com/product_info.php/products_id/2908 check it out. |
Joined Dec 2011
Hi guys
did a run up with 4 cel 40c lipo all cell averaging 4.15 to 4.18 Stock motor with 3 blade 8 pitch 13 inch master screw 535 watts power 34.5 amps I hope this helps. I have 11 flights now and new batteries are working better. 4 cell 4000ma getting 10 min. leaving 3.85 to 3.83 per cell |
| Thread Tools | |
| Discussion $100 SCRATCH/DENT Decathlon 1800mm from USA warehouse. +10 in stock :O | Koo | Hot Online Deals | 47 | Apr 12, 2013 06:31 AM |
| Discussion Hobby King 1800mm Composite P-47 | Olearsenewbie | Electric Plane Talk | 5 | Nov 04, 2012 09:57 PM |
| Discussion 1400mm wingspan EPO Super Decathlon from ESR HOBBY | Gavin he | Sport Planes | 7 | Oct 23, 2012 12:25 PM |
| Discussion Dynam (Hobby King) Piper Super Cub PA-18 - which replacement motor? | romandesign | Foamies (Kits) | 2 | May 28, 2012 01:41 PM |
| Discussion Hobby King KI-61 Hien!!!!!!!!!!!! 1800mm | TripleW | Glow to Electric Conversions | 7 | Feb 08, 2012 03:18 PM |
