Old Dec 06, 2012, 08:03 PM
Jackspt28 is offline
Find More Posts by Jackspt28
Levittown,PA
Joined Jan 2003
Xplorer 3.5 receiver Battery? Etc.
Hello Guys, Expecting my new (used) Xplorer 3.5 ST to arrive tommorow. What battery size/ type do you recommend, has all MKS servos in it and a Airtronics 10 Channel receiver (2,.4). I have a JR 9303 2.4 radio, so I guess its buy a receiver (JR 9300/ Or spectrum AR-8000) and use my radio, or purchase an SD-10G Transmitter?? Does anyone have a set up available. Its been about 9 years since I flew competition TD contests.(flying turbine jets for past 6 yrs. I miss thermal flying and slope flying, so I'm gettng back into it with the Xplorer for TD and I still have my slope ships. Thanks for any suggestions! Jack.
Jackspt28 is offline Find More Posts by Jackspt28
Old Dec 06, 2012, 08:55 PM
Brandon is offline
Find More Posts by Brandon
Brandon's Avatar
Riverside, California, United States
Joined Feb 2004
Jack,
There has been an ongoing debate about the use of an unregulated LiFe pack with the MKS servos. Some are running a LiFe pack unregulated without problem and some have had issues with the servos burning up. There is no doubt that the MKS servos perform very well, have a super tight gear train, and are reliable. My two FS4's all are equipped with MKS gear and I have had no issues. That being said, I run a 4 cell NiMh pack in both planes. If you insist on the LiFe pack, I would regulate it at the very least.
Good luck, sounds like a very nice airframe.
Best Regards,
Brandon
Brandon is offline Find More Posts by Brandon
Old Dec 06, 2012, 09:14 PM
kilwein is offline
Find More Posts by kilwein
kilwein's Avatar
Joined Jan 2007
I have 4 planes using MKS servos, 6125, 6125h and a few 450's.
Some close to two years all on 4cell nimh 1500mah packs and no issues to date.
I just bought 6 of the MKS regs to go in my Sharon 4.2E, will run a LiFe 2300 pack in it.
kilwein is offline Find More Posts by kilwein
Old Dec 06, 2012, 09:19 PM
liftchaser is offline
Find More Posts by liftchaser
USA, FL, Milton
Joined Jul 2008
You might consider adding individual MKS regulators to each MKS servo and powering the 2.4 GHz RX and non-MKS servos directly from the LiFe battery. The MKS site has the regulators available. I have several of the regulators but haven't installed them yet in an airplane. Tested one on the bench and it regulated to 4.9V with inputs between 7.0V and 5.0V.
lc
liftchaser is offline Find More Posts by liftchaser
Old Dec 06, 2012, 09:20 PM
sailjester2811 is offline
Find More Posts by sailjester2811
Jody Miller
sailjester2811's Avatar
Orlando, Fl
Joined Jun 2009
What radio are you flying?
Jody
sailjester2811 is offline Find More Posts by sailjester2811
Old Dec 06, 2012, 09:22 PM
Levittown,PA
Joined Jan 2003
Jr 9303 2.4 thanks
Old Dec 06, 2012, 09:45 PM
Kiesling is online now
Find More Posts by Kiesling
San Diego
Joined Aug 2004
I run 4 cell 2/3 A 1500 Elite packs in all my Explorer's (also equipped with MKS servos). Works great. If you're in the market for a new radio, the SD 10G is a step up from the 9303.
Tom
Kiesling is online now Find More Posts by Kiesling
Old Dec 06, 2012, 10:02 PM
Levittown,PA
Joined Jan 2003
Thanks Tom, how is California? Used to fly with ,bill miller tony m and terry L and mike L in ESL about 9 years ago, thanks jack G
Old Dec 06, 2012, 10:11 PM
Levittown,PA
Joined Jan 2003
Tom ,What pack configuration for the 1500 elite batts in the 3.5 xplorer?
Old Dec 06, 2012, 10:46 PM
San Diego
Joined Aug 2004
Jack,
I use a 3+1 pack configuration (lll-).
California is pretty nice- you can fly all year round!
I miss the green of the East Coast but the weather here is fantastic.
Tom
Old Dec 06, 2012, 11:05 PM
J. Wydronek is offline
Find More Posts by J. Wydronek
J. Wydronek's Avatar
United States, AZ, Buckeye
Joined Mar 2010
Jack
Use the pack Thomas is recommending. I am just finishing up a 4.0m xplorer and it is using a 4 cell pack. In the old box shape. It doesn't fit in the nose very well. So I'm guessing I will have to add just a tad more nose weight with the pack sitting back so far.
Joe
J. Wydronek is offline Find More Posts by J. Wydronek
Old Dec 07, 2012, 01:50 AM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
Tom
I want to jump in slightly off topic.
I'm setting up a 3M Viking2 with 4 x 6125 minis and 2 x 65Ks. Just wondering how much flight time your getting with the above mentioned 1500 pack? And how many/what MKS servos?
Thanks, Bill
Flyextreme is offline Find More Posts by Flyextreme
Old Dec 07, 2012, 03:06 AM
San Diego
Joined Aug 2004
I can't say that I have ever measured exactly how much flight time I get out of a charge. But I do know that I have flown on the order of 2 hours before charging. This under typical practice conditions - many launches and landings. For a long practice day, I'll charge half way through the day just to be safe.
This is with 2 6125's, 2 6125 minis, and 2 6125 H's.
Tom
Old Dec 07, 2012, 07:02 AM
DrFragnasty is offline
Find More Posts by DrFragnasty
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
FYI
I run 4x Eneloop AAs driving JRXG8 RX, 3 x 3421s, 3x JR362s.
Highly recommended. Going on 18 months of solid service. Always charged timidly @100mAh or up to 400mAh at the field for top-ups.
Chris.
DrFragnasty is offline Find More Posts by DrFragnasty
Old Dec 07, 2012, 12:02 PM
satinet is online now
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
Thanks, Bill
Bill as a rough rule of thumb I find I usually consume about 300-500 mah per hour with a 3m/6 digi mouldie flying at the slope.
Obviously you can bring it up or down depending on what you do and what your setup is. That being said i don't find the type/brand of servo makes a massive difference. Flying style makes a difference - constant maxed out flying uses more obviously.
I don't think with nickel batteries you really want to go too far below half charge (IMHO).
Per the advice above I don't find f3b flying uses too much battery. Although there is really no need to have flat batteries if you are winching as you have lead 12v batteries and chargers on site all the time.
I agree that something in the order of 2 hours is reasonable. Assuming no binding servos and such!
satinet is online now Find More Posts by satinet
Wanted Xplorer 3.5 or 3.8 fuselage mlee8249 Aircraft - Sailplanes (FS/W) 2 Jun 10, 2012 12:55 AM
Sold Xplorer 3.5 Brain52 Aircraft - Sailplanes (FS/W) 5 May 23, 2012 05:39 PM
Sold 3.5 meter Xplorer for sale - new price! blewis01 Aircraft - Sailplanes (FS/W) 5 Apr 18, 2012 05:05 PM
Sold Xplorer 3.5 spread tow receiver ready Rairwalk Aircraft - Sailplanes (FS/W) 4 Feb 24, 2011 09:44 PM
