Old Dec 06, 2012, 03:03 PM
helinorthwest is offline
Find More Posts by helinorthwest
United States, WA, Seattle
Joined May 2012
revival of an oldie - need advice on motor/esc
I've got an old Kyosho Jetstream 26" hull brushed 540 motor boat. It has not been used in 10 years. i want to put a brushless motor & new esc in it to make it hum. I also want to use a motor with the same mounting screw holes as the 540 motor.
was going to use this but have no idea if the mounting holes will line up:
http://www.hobbyking.com/hobbyking/s...Cooled%5F.html
what do you guys recommend doing? Thanks in advance!
helinorthwest is offline Find More Posts by helinorthwest
Old Dec 06, 2012, 05:35 PM
antslake is offline
Find More Posts by antslake
How high will it go?
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
I believe that is too small. You need a motor in the 36mm can range, or a 500 class outrunner. Careful, it will be more than twice the power of the stock setup.
antslake is offline Find More Posts by antslake
Latest blog entry: FAA registration
Old Dec 07, 2012, 02:55 AM
pompebled is online now
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi helinorthwest,
Welcome on this forum!
As Antslake pointed out, the motor is on the small side, at least for direct drive.
If you use the geared reduction these boats came with, it should work, giving you 21.000 rpm on the prop when the reduction is 1:2.
Keep in mind that the design of the Jetstream isn't suitable for blistering speed, the steering outdrive won't handle much more power before it'll desintegrate...
Regards, Jan.
pompebled is online now Find More Posts by pompebled
Help! landing gear on an fpv radian. need advice. ne1 try it? g3f0rc3 FPV Talk 6 Aug 19, 2016 05:29 PM
Discussion Need advice on 15 inch props for T-Motor MT3515 rampa202 Multirotor Talk 21 Aug 09, 2012 06:06 AM
Discussion Need advice on quality motors for new build.... Adidas4275 Multirotor Talk 10 May 01, 2012 08:39 AM
Question Need advice on an E-bay transaction gone wrong CiprianGugu Other Websites 9 Apr 12, 2012 09:06 AM
Discussion Need advice on which motor to buy for an EXI 450 jedi391 Mini Helis 8 May 31, 2011 08:41 PM
