Old Dec 07, 2012, 08:35 AM
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
No.
Not enough power.
A minimalist solution would be an 8Ah 4s Headway pack.
Julez is offline Find More Posts by Julez
Old Dec 07, 2012, 08:43 AM
Schweiz, BE, Münchenbuchsee
Joined Jun 2011
Yes. i have seen only 4A discharge current.
And this one:
http://www.aliexpress.com/item/12V-2...571093949.html
would have 8A discharge current, so about 96W. That should be enough.
I need at least 15AH and less than 2kg weight (for icharge 106B+)
Andy
Morphin is offline Find More Posts by Morphin
Old Dec 07, 2012, 08:49 AM
CP heli ≠ 3D heli
Gedexas's Avatar
United States, NJ, Point Pleasant Beach
Joined Mar 2009
Originally Posted by Morphin View Post
Can i also user this:
http://www.aliexpress.com/item/54000...485928305.html
I need a portable solution that i can pack in a backpack that is not too heavy....
Solar pannels will not work and cost way too much. First off, a solar panel will only generate it's rated output when the sun is directly above, so you can only use at it's peak output (being optimistic) for 4 hours a day, the other 4 hours will be only half the output (in the summer). Unless you live on the equator, you don't get enough sun to have 100% output from a solar panel.
The other thing about solar panels is the area required to deploy them. You can only get 10 watts per square foot at 100% efficiency, which means that for real life scenario, you need 6 square feet for 30 watts, that's only a single 3S1P 2200 LiPo. And you can only charge it four times in a day on that 6 sq. foot panel, which means that I would need about 24 sq. feet of panels to replace my field battery.
Do you know what 24 sq. feet of panels cost? And this is only if you fly a 450 sized heli.
Gedexas is offline Find More Posts by Gedexas
Old Dec 07, 2012, 08:54 AM
Joined Jun 2011
It is not the solar panel. it also have a rerchargable battery. but i have now seen that the current is only 4A. The other lipo-Battery has 8A, but i think it is still too little. So maybe headway 4S is a better way. maybe 4S 15AH. Where is a good and cheap shop to get one?
Andy
Old Dec 07, 2012, 09:58 AM
Julez's Avatar
Germany
Joined Dec 2003
Concerning headway cells and stuff, I just opened a thread about my approach:
http://www.rcgroups.com/forums/showthread.php?t=1784667
Old Dec 07, 2012, 12:06 PM
Joined Sep 2008
Yes a 6S LiPo will work for small 3s recharges. Just change your chargers input voltage minimum so the source battery does not get drawn down to far.
What do you drive? If a pickup/SUV there is room under the hood for two batteries.
Use one of these http://www.princessauto.com/pal/prod...-Master-Switch
or http://www.princessauto.com/pal/prod...ttery-Isolator
This way you have a install and forget system that is always ready to go,
flashburn is offline Find More Posts by flashburn
Old Dec 07, 2012, 12:13 PM
United States, NJ, Frenchtown
Joined Mar 2003
We connect a BIG LIPO to a DC field charger & start charging lots of small packs continously.
Who is sitting there with a accurate digital voltmeter watching the BIG LIPO drop in voltage & watching the charging LIPOs ????
Probably no one.
cyclops2 is offline Find More Posts by cyclops2
Old Dec 07, 2012, 12:30 PM
newTOpro's Avatar
United States, NY, Albany
Joined Sep 2011
Well I screwed up. Forgot a tiny little detail.
My charger can only take 18V DC input max. So a 6s Lipo is out of the question at 22.2V. At least this wound up to be a great conversation and kick started some alternative ideas.
I guess I will be looking more into the LiFePo's or a larger gel cell. A second battery in my car won't work, it's only a Kia Soul and fitting 3 kids, the wife and the gear is already an effort in itself.
newTOpro is offline Find More Posts by newTOpro
Last edited by newTOpro; Dec 07, 2012 at 12:47 PM. Reason: grammar edit - sounded like a teenage girl
Old Dec 07, 2012, 12:42 PM
Joined Mar 2003
Enclosed roof carrier ? There are those long plastic boxes that go on the roof racks.
Old Dec 07, 2012, 12:47 PM
newTOpro's Avatar
Joined Sep 2011
Actually, I am looking into those....imagine the battery I could store in there!
Old Dec 07, 2012, 12:59 PM
Jim Buzzeo's Avatar
Willmar, Minnesota, United States
Joined Sep 2004
I HAVE to ask... do you use an automobile to get to the flying field?
I'm assuming a regular ol' couple alligator clips to a 12V car battery isn't in the plan... :^)
(I say again, HAD to ask )
Jim Buzzeo is offline Find More Posts by Jim Buzzeo
Old Dec 07, 2012, 01:01 PM
Joined Mar 2003
The roof is a great place to have a
LIPO FIRE !!!
Not in the trunk or passenger space. Talk about toxic choking smoke !!
Up on the roof top all the RC gear. Enjoy
Old Dec 07, 2012, 01:03 PM
Joined Mar 2003
With some wood spacers, You COULD put a standard big car battery up there. Maybe ?
Old Dec 07, 2012, 01:21 PM
newTOpro's Avatar
Joined Sep 2011
Jim,
No, don't really want to use the car's battery. I know I could get away with it just fine considering the size packs I'm charging. But between the kids running around and making sure the planes and Tx's are set up I am pretty busy. IF (capital IF mind you) a Lipo were to pop while I'm flying or buddy-boxed with one of the kids I don't want it near the car.
Old Dec 07, 2012, 01:47 PM
United States, NY, New York
Joined Dec 2009
i will say get a deep cycle battery and forget about that 6s lipo.
deep cycle battery is about $60 in walmart or pepboys and it should could take care the small lipos when u in field.
As we all know lipo is not too stable when being discharge below 3.7 per cell. Not that worth to risk the fun family flying section because of the 6s lipo get fire.
If you decide to teach your children how to fly, please teach them how to charge lipo the correct way.
just my 2 cents.
bigtruck169 is offline Find More Posts by bigtruck169
Question How do you take your Lipo batteries to the field? Left Coast DJ Batteries and Chargers 26 May 26, 2012 05:02 PM
For Sale 1-4 cell LiPo Field Charger w/ 12v Gel Cell Battery Package jmead Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2006 08:22 PM
