Old Dec 10, 2012, 10:21 PM
A6TEXAN is offline
Find More Posts by A6TEXAN
A6TEXAN's Avatar
USA, TX, Dickinson
Joined Oct 2007
it only has the power of a .46 2 stroke? youre kidding right ? a .46 will not turn a 13x8 prop.
A6TEXAN is offline Find More Posts by A6TEXAN
Old Dec 10, 2012, 10:41 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
An engine makes significantly less power on gasoline. With spark ignition large props are no problem, the RPM (and power) just drops. Large props lead to overheating and detonation in glow engines because the timing is too far advanced.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Dec 11, 2012, 12:25 AM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
Greg
Greg,
The so-called ignition advance on a glow engine, is controlled by the mixture strength.
A leaner mixture ignites more easily and the flame propagation in it is faster, than a richer mixture.
Ignition-advance control is the single true function of the needle-valve in a glow engine.
Heavy prop loads (within reason) can be compensated for by setting the mixture richer (and/or by using a colder glow-plug).
On the same amount of air per cycle, a methanol engine will ideally produce 24% more power, compared to a spark-ignition gas engine. This means a glow engine will spin a given prop, 6.2-7.4% faster than a gas engine of identical displacement and design.
But the practice of setting a glow engine a little rich, to protect it from leaning mishaps, reduces the power difference to ~15% and the RPM difference to ~5%.
On the other hand, using more nitro in the fuel can makes the power difference greater.
I believe this .60GX engine will be comparable in its power to the Evolution .52NX.
DarZeelon is offline Find More Posts by DarZeelon
Old Dec 11, 2012, 09:06 AM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Ignition timing in a glow engine is also controlled by compression ratio, glow plug, temperature, and throttle setting.
Greg
Old Dec 11, 2012, 09:43 AM
DarZeelon's Avatar
Joined Nov 2003
Yes it is, Greg.
Of course it is.
But when you have the engine running full-bore, you cannot swap the glow-plug on the fly, or change the C/R...
What you can do is to turn the needle, just as easily as you could rotate the distributor slightly in an older model car, thus changing the ignition advance setting.
For a glow engine this is your immediate timing control.
Old Dec 11, 2012, 09:52 AM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Forget it Dar, my point is that you can safely put any prop you like on a gasser and have no problem running it. Try an 18x10 on a ~8cc fourstroke glow and let me know how it goes.
Same old games with you Dar, I'm done.
Greg
Old Dec 11, 2012, 09:55 AM
DarZeelon's Avatar
Joined Nov 2003
It won't go, Greg.
I agree to what you stated, regarding the ability to run big props on spark-ignition engines.
Old Dec 11, 2012, 11:43 AM
4075aaron is offline
Find More Posts by 4075aaron
United States, MD, Frostburg
Joined Aug 2008
Everyone take one big breath, and two big steps back!!!
This engine interests me greatly as I have a few smaller kits left to build, but I am tired of the cost and mess of glow. Let's keep the discussion focused on this particular engine!
4075aaron is offline Find More Posts by 4075aaron
Old Dec 11, 2012, 12:08 PM
jspauld2 is offline
Find More Posts by jspauld2
Horizon Hobby Employee
Joined Dec 2012
Since there's been a lot of talk about the power on the engine, here's some numbers we've obtained on various props.
Jimmy
Horizon Hobby, Inc.
Saito, Evolution & Zenoah - Developer
jspauld2 is offline Find More Posts by jspauld2
Old Dec 11, 2012, 01:52 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Jimmy, thanks for the figures. That's about what I'd expect.
Greg
Old Dec 11, 2012, 03:52 PM
SnickNitro is offline
Find More Posts by SnickNitro
Joined Dec 2012
2 Stroke Smoke
Hey,
I have a .60NX Evolution motor with a pitts muffler on it. I was wondering if smoke would work on it. If so any smoke system that i should use?
Snick
SnickNitro is offline Find More Posts by SnickNitro
Old Dec 11, 2012, 04:37 PM
Wingman26 is offline
Find More Posts by Wingman26
Wingman26's Avatar
Oklahoma
Joined Aug 2008
Originally Posted by SnickNitro View Post
Hey,
Snick
You would probably do better to start a new message on the board rather than tacking onto another subject.
Wingman26 is offline Find More Posts by Wingman26
Old Dec 11, 2012, 06:54 PM
A6TEXAN is offline
A6TEXAN's Avatar
USA, TX, Dickinson
Joined Oct 2007
thanks for your input gkamysz. also thanks jimmy for the chart. all helpful info fellas.
Old Dec 13, 2012, 05:20 AM
brw0513_2 is offline
Find More Posts by brw0513_2
Joined Dec 2006
Jimmy
Horizon Hobby, Inc.
Could someone please convert these figures to a power curve i.e. watts vs rpm?
I tried using this calculator:
mvvs.nl/prop-power-calculator.xls
But the graph doesn't look correct.
brw0513_2 is offline Find More Posts by brw0513_2
Old Dec 13, 2012, 08:50 AM
DarZeelon's Avatar
Joined Nov 2003
BRW,
The numbers posted by Jimmy are legitimate.
The output curve is pretty flat... It is turning out .95 HP (709W) on the 12x6 APC @10,500 RPM, 1.04 HP (777W) on the 11x6 APC @11,800 RPM and 1.02 HP (750W) on the 10x6 APC @13,700 RPM.
I don't have the prop index for the Evo props, so I cannot plot-out the numbers.
The HP claims from Horizon seem to be another chapter in the pissing contest...
I challenge Craig and Jimmy to show all of us here, how 1.68 HP @ 16,400 RPM, can be extracted from this engine!
New Product Hangar 9 Meridian Sport ARF and Evolution 10cc Gas Engine Bajora Sport Planes 423 Aug 23, 2016 12:40 AM
Sold Fox 4.2 cu. in. (70cc) gas engine, electronic ignition, runs great barchiola Aircraft - Fuel - Engines and Accessories (FS/W) 7 Nov 19, 2012 07:07 PM
For Sale Evolution 58cc gas engine with new KS header parts and new Evolution tuned canister Daveyboycfs Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 11, 2012 10:07 PM
Sold US Engines NIB 41cc (2.5 cu in) gas engine. REDUCED !! puplover Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 15, 2011 01:41 PM
Sold Saito FG-36 4 stroke gas engine (2.2 cu in) James Love Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 22, 2011 11:16 PM
