USA So. Cal.
Joined Sep 2010
Just as info.
I put another 61 minutes of flight time on my 10GX this morning. After tweaking the hsn a bit it is turning a 13X6 Xoar prop 9400 Rpm on the ground. Flying a 6.5 lb (dry) low wing trainer type plane I get unlimited vertical. It will trip the telemetry RPM alarm that I set at 12600 after a couple seconds straight up. This is awesome power in a small engine, IMHO. And, I have been flying it for several days and not one dead stick. ![]() The only small complaint is: If it fails to start instantly it floods and spits LOTS of fuel and oil all over the plane in the next few seconds of starter time. This happens seldom, but is a bit messy when it does. |
United States, MI, Waterford Township
Joined Aug 2008
USA So. Cal.
Joined Sep 2010
Joined Aug 2008
I like what you've been saying about your 14x4, but have never flown with a prop that low in pitch? I'm sure 4" would be great for all out 3D, but more concerned about sport flying with a little 3D thrown in on occasion?
Prefer take off and vertical performance over speed to a point. Just not sure where that line is? Thinking of a Yak (Chinese ARF, forget who's) I've had up in the rafters for a while. Lost interest in it when I went to gas exclusively. By the sounds of the numbers I'm seeing from you guys for this engine, I might be able to give it a second look? It would likely be on the bigger/heavier end of this engines capabilities it sounds like. I was originally going to use a 70-80 4c in it. Don't know if I could keep it under 7lbs. Even if it went over a little, a gasser that small (56"?) pretty neat! |
The characteristics of the 14x4 are, less noise, more vertical line thrust (less throttle needed), more down line braking, slower speed, slower landings when no headwind exist, and very reliable idle. I've not experienced any heat issues.
The one thing that has me scratching head is the last several outings have each required a click or two more towards rich, probably 7-8 clicks all together. I don't know if that is a characteristic of ABC break in or what is going on as I've never owned an ABC engine previous. Sport flyer here... no 3D. I'm starting to age and appreciate slower. A 4 pitch might also be good for the higher drag of a bipe such as a 40 size Ultimate. |
Leander, Texas
Joined Sep 2003
I was doing some measurements earlier this week and think this engine may fit inside the cowls of a DS B-17,~7.1"dia. Its one of my distant dream builds and probably the first I'll do in retirement, 2.5 yrs. So I'm paying close attention to sport performance and reliability. I'm looking at using 3 blade props. I also figure by the time I'm ready to try one of these out the fuel/oil mix will be more fine tuned.
Edwin |
USA So. Cal.
Joined Sep 2010
After all I was flying that plane for a long time with a Saito FG-14 with a 13X6 Xoar, and his Evolution turns as big a prop at higher RPM so it will fly nicely . I am going to put it back into the Escapade later now that I see the power is there. |
| Thread Tools | |
| New Product Hangar 9 Meridian Sport ARF and Evolution 10cc Gas Engine | Bajora | Sport Planes | 118 | Yesterday 12:17 AM |
| Sold Fox 4.2 cu. in. (70cc) gas engine, electronic ignition, runs great | barchiola | Aircraft - Fuel - Engines and Accessories (FS/W) | 7 | Nov 19, 2012 07:07 PM |
| For Sale Evolution 58cc gas engine with new KS header parts and new Evolution tuned canister | Daveyboycfs | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Jun 11, 2012 10:07 PM |
| Sold US Engines NIB 41cc (2.5 cu in) gas engine. REDUCED !! | puplover | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Oct 15, 2011 01:41 PM |
| Sold Saito FG-36 4 stroke gas engine (2.2 cu in) | James Love | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Mar 22, 2011 11:16 PM |
