Old Feb 02, 2013, 05:57 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
Originally Posted by Hance View Post
Well I can cross doing a dead stick, behind a hill blind, on skis, on a maiden flight off my list of things to do.
http://www.youtube.com/watch?v=Wh1IA...=youtube_gdata
Your blind dead stick landing was better than most of mine when I can see it and am not freezing. Good Job.
Fokker DII is offline Find More Posts by Fokker DII
Old Feb 02, 2013, 11:20 PM
Pete Bergstrom is offline
Find More Posts by Pete Bergstrom
Engine Category Manager - EVO,
United States, IL, Champaign
Joined Aug 2005
Tyor and Hance. What kind of gloves are you guys using that allows you to fly in such cold weather?
Pete
Pete Bergstrom is offline Find More Posts by Pete Bergstrom
Site Sponsor
Old Feb 02, 2013, 11:51 PM
Hance is offline
Find More Posts by Hance
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
Pete
No gloves or transmitter mit for me. I was bare handed just like I am in the summer time. It was actually fairly warm out the temp was around 25F but with the sun shining on you its not bad at all.
Hance is offline Find More Posts by Hance
Old Feb 03, 2013, 01:09 AM
tyor is offline
Find More Posts by tyor
Norway
Joined May 2005
Originally Posted by michael88997 View Post
So does it feel like it has plenty of power?
I fell it has plenty of power. hope I can get it to run better
Pete
I have gloves on when I am starting the engine and warming it up. Then I take them off when ready to fly. We had sun and no wind yesterday so it was not so cold. Today it`s -20c here. no flying today I think
tyor is offline Find More Posts by tyor
Old Feb 03, 2013, 11:20 AM
tyor is offline
Norway
Joined May 2005
I think the cold temperature could be one of the reason i cant get it to run nice. When i landed the plane and touches the engine it is not hotter than i can hold my fingers on the sylindertop
Old Feb 03, 2013, 11:37 AM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
What a quote!
Great job by the way!!
Kmot is online now Find More Posts by Kmot
Old Feb 04, 2013, 06:00 PM
michael88997 is offline
Find More Posts by michael88997
United States, TX, Lewisville
Joined Jan 2011
Ok so I've decided to build a sabre 47 with this, I'm going to use some life packs that have 2 power leads, I'm also running 2.4ghz... With 2 leads should I use a IBEC or anything to reduce noise from the ignition? Still a little confused on this topic
michael88997 is offline Find More Posts by michael88997
Old Feb 04, 2013, 06:12 PM
AA5BY is online now
Find More Posts by AA5BY
AA5BY's Avatar
East Texas
Joined Aug 2007
Traditionally, ei systems have needed isolation. Whichever way you go, be sure to range check with the engine running and not running and compare. If the range drops significantly with the engine running... the receiver is being desensed by RFI.
AA5BY is online now Find More Posts by AA5BY
Old Feb 04, 2013, 06:42 PM
tyor is offline
Norway
Joined May 2005
I have one 6v nimh pack. and just used a y-lead (i am not shure about the name i english) from the swich. one to the reciver and one to the ignition. have checked the range to be normal
Old Feb 04, 2013, 06:50 PM
Joined Jan 2011
ya I was just wondering because that IBEC plugs into the rx so it cancels out the noise, but if you have a different lead do you still get the noise... does the carb on this engine close completely? cause if not I could use that for remote shut down
Old Feb 04, 2013, 08:40 PM
ahicks is offline
Find More Posts by ahicks
United States, MI, Waterford Charter Township
Joined Aug 2008
The bigger gassers started using the Opti switches (or IBEC's) as a back up for closing the carb completely (not always as reliable as it should be?). After getting used to one, you'll likely stop using anything else. They're great for taking care of linkage malfunctions, and will even cut power to the ignition module if they loose signal from the transmitter or a low voltage issue.
ahicks is offline Find More Posts by ahicks
Old Feb 04, 2013, 08:42 PM
ahicks is offline
Joined Aug 2008
Originally Posted by tyor View Post
I have one 6v nimh pack. and just used a y-lead (i am not shure about the name i english) from the swich. one to the resiver and one to the ignition. have checked the range to be normal
I wouldn't be scared of that set up either - but range checking is a good plan!
Second thought. I wouldn't be scared of that setup if I was sure that NiMh could supply enough power for everything I was running? They are not hard to overwhelm using digital high torque servos!
Old Feb 04, 2013, 09:53 PM
Joined Jan 2011
well I placed a order for a sabre 47 and evo 10gx so I will be trying it out soon... cant wait to get it going
Old Feb 04, 2013, 10:55 PM
tyor is offline
Norway
Joined May 2005
In a plane of the size for this engine I dont think that the power from the servos could be a problem.
I have a 33% yak with digital servos. use nimh in that too. No powerbox, but have 2 batteries and a batshare. In that plane we measured the current in flight. tryed to make the servos work as hard as possible and the max current was 13Ampere. But here i dont use the same batteri for the ignition
Old Feb 05, 2013, 04:17 AM
AA5BY is online now
AA5BY's Avatar
East Texas
Joined Aug 2007
NiMh are current limited when cold... so they may work in 70-80 temps but not supply adequately at 50..
New Product Hangar 9 Meridian Sport ARF and Evolution 10cc Gas Engine Bajora Sport Planes 414 May 17, 2016 04:59 PM
Sold Fox 4.2 cu. in. (70cc) gas engine, electronic ignition, runs great barchiola Aircraft - Fuel - Engines and Accessories (FS/W) 7 Nov 19, 2012 07:07 PM
For Sale Evolution 58cc gas engine with new KS header parts and new Evolution tuned canister Daveyboycfs Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 11, 2012 10:07 PM
Sold US Engines NIB 41cc (2.5 cu in) gas engine. REDUCED !! puplover Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 15, 2011 01:41 PM
Sold Saito FG-36 4 stroke gas engine (2.2 cu in) James Love Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 22, 2011 11:16 PM
