This thread is privately moderated by SkyCadet, who may elect to delete unwanted replies.
Old Dec 06, 2012, 12:25 PM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
Yak 55: the final stretch!
I finished connecting and centering the servos/horns, and installed the motor mount into the fuselage.
Final test fit of the cowling prior to adding mount screws, and the plane looks VERY nice, if I do say so myself! Below are two shots of the plane minus wings (easier to finish electronics layout without them on the plane for now), showing the vane system and prop as it will appear when I am done.
A static motor test the other day on the RCTimer 3536-6 1250Kv, 500W motor running the MAS 11x7 3-blade prop had around 330W peak on WOT with a nominal (not fully charged) battery, running just under 37Ap. 50% ran around 130W at 11.6-11.7A. well within the capaibilities of this 3S system, and some room for tolerance on the power system (ESC is Turnigy 45A/55Ap unit, so I am safe).
The only odd thing was in order to get close to the 40 degree throws in the manual, I had to run all servos at 125% - they all work fine at that setting. No binding or warping seen so far during test throws. These HD-1810MGs from HobbyKing are very nice - plenty of torque to run this model's control surfaces!
Linkages are made with Sullivan clevices, and 2-56 threaded rods. Very secure, easy to adjust, and solid. The HD-1810MG servos have plenty of torque for this plane.
Pix below. Almost done!
SkyCadet is offline Find More Posts by SkyCadet
Sold BNIB MAX OS 55 HZ-R Heli engine + EVO 55 PIPE (FINAL PRICE DROP) orentlikher Aircraft - Fuel - Engines and Accessories (FS/W) 3 Oct 27, 2012 11:58 AM
Sold BNIB MAX OS 55 HZ-R Heli engine + EVO 55 PIPE (FINAL PRICE DROP) orentlikher Aircraft - Fuel - Helis (FS/W) 2 Oct 27, 2012 11:52 AM
Discussion Crack Yak vs HK Yak 55 brandon_stehling 3D Foamies 14 Sep 28, 2012 11:01 PM
Discussion RCF 39" Yak-55 or Telink 43" Yak-55 3flyguy3 3D Foamies 8 May 11, 2012 10:52 PM
