This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Old Dec 06, 2012, 04:47 AM
Jack Crossfire is offline
Find More Posts by Jack Crossfire
Jack Crossfire's Avatar
Calif*
Joined Sep 2006
Pi Complete
The object of the game was to make a box that could be set up anywhere & fly the vehicle with 1 button press & no GUI. That's mostly possible, except for the 1 issue of calibrating the compass. A user interface of some kind was necessary, but could also be done with aural cues.
Playing uncompressed sound files on a pi with 2 webcams is done thus:
amixer -D hw:2 sset 'PCM' 65535
aplay -D hw:2 test.wav
The webcams take up the 1st 2 devices.
Next, you need to restore the last of a pair of 28 year old, amplified speakers, in which the other one stopped working, but you threw out the electronics not knowing it merely required an easily obtained LA4461 audio chip.
As a standalone box, it takes 80% of the CPU during flight. The maximum stable frequency remanes 900Mhz. Active cooling made no difference at 1Ghz & isn't necessary at 900Mhz. What does need active cooling is the voltage regulator. The total power with the cooling fan, servos, cameras, & CPU is 1.5A at 12V. It still takes quite a bit of power to do machine vision.
With a network GUI enabled, it goes to 90% of the CPU. A system with at least a tablet interface is a lot more useful. Unfortunately, while an access point based on the rtl8192cu was possible in Linux 3.2.9 for Ubunt, it no longer is in 3.2.27 for the pi.
It now can't change the interface to master mode. A different dongle may be required, simply because the software no longer works.
Some things that got it farther along:
modprobe hostap
modprobe cfg80211
Jack Crossfire is offline Find More Posts by Jack Crossfire
Discussion Raspberry Pi for multi rotor 360walt Multirotor Talk 15 Apr 15, 2013 09:33 AM
Wanted 49-PI Type II Wankel Joe Pierson Aircraft - Fuel - Engines and Accessories (FS/W) 1 Aug 27, 2012 06:40 PM
Discussion Multicopter PI-tuning: How to recognize different settings. kapteinkuk Multirotor Talk 18 Jun 24, 2012 02:50 AM
Sold Brand New OS 49 PI Type II Wankel Greyout Aircraft - Fuel - Engines and Accessories (FS/W) 1 May 18, 2012 03:32 PM
Discussion pi-racer Bearweasel Foamies (Scratchbuilt) 3 Apr 22, 2012 10:48 PM
