Old Dec 06, 2012, 03:46 AM
shanes heli is offline
Find More Posts by shanes heli
Australia, VIC, Seaford
Joined Apr 2012
Help!
Toilet bowl effect
Hi all , I have a couple of x350a's . my first one has had many a learning experience , the new one comes out on calm days . Anyway I like to keep the first one going as a hack and after a good hit into , surprisingly enough a toilet block at my local park I've done an extensive rebuild , ( shafts and whole top end ) ever since though when hovering it seems to be suffering what ive heard refered to as the TBE seeming to want to move in a circle while the nose stays in the same orientation , sort of like a circular pendulum under the rotors . Has anyone had this happen to them and even better know where the problems coming from . Any help would be much appreciated . Thanks Shane.
shanes heli is offline Find More Posts by shanes heli
Old Dec 07, 2012, 12:15 PM
Steve_ is offline
Find More Posts by Steve_
Venting Nowlege
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Almost sounds like too much weight in the nose, combined
with a damaged gyro.
What does it do if you hold the tail steady with rudder input?
Or does it still spin, even with full opposite rudder?
Steve_ is offline Find More Posts by Steve_
Old Dec 07, 2012, 12:53 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
TBE is caused by a harmonic distortion between the upper and lower rotor on a coax. It is usually related to worn or damaged linkage or anchor points for the blades or flybar, causing binding or excess slop. It can be a real pain in the ass to find, especially with poor quality materials.
Balr14 is offline Find More Posts by Balr14
Old Dec 07, 2012, 01:36 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
That's right.. come to think of it, my coax did that when it had a broken
flybar link.
At first glance, the link looked fine, but it had a crack on the very end
of the link, that would allow it to spread apart under load.
Not enough to make it pop off, it would stay attached just fine.
But it introduced enough slop to make it impossible to fly.
Help! Toilet bowl effect shanes heli Coaxial Helicopters 5 Dec 06, 2012 01:36 PM
Discussion Blade Scout Toilet Bowl Effect rdw777 Coaxial Helicopters 4 Nov 10, 2012 09:43 PM
Discussion Is there a direct solution to the "toilet bowl" effect? avt Multirotor Talk 7 Oct 17, 2012 07:49 AM
