Old Dec 05, 2012, 09:00 PM
cb100 is online now
Find More Posts by cb100
cb100's Avatar
United States, CA
Joined Dec 2010
DX7S tx battery voltage reading is not accurate!!!
Does anyone know if we cud calibrate DX7s tx battery reading? Mine was off by 0.2V. A full 2s pack should be read at 8.4V, yet the tx read it as 8.2V. When my DX7s went off at 7.4V (preset low voltage alarm), i took it out and measured the voltage with a DVM, it read 7.6V(?). Thanks,
cb100 is online now Find More Posts by cb100
Old Dec 05, 2012, 09:02 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
HH has an acceptable tolerance and it's within the tolerance, you can adjust the alarm accordingly or send it back to HH for calibration.
freechip is offline Find More Posts by freechip
Old Dec 05, 2012, 09:05 PM
cb100 is online now
cb100's Avatar
United States, CA
Joined Dec 2010
That's a huge tolerable error margin by any standard. for these kind of application, it should be within +/- 0.01V. I guess Spektrum's standard is low.
Old Dec 05, 2012, 09:21 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Call HH and have it serviced or adjust the alarm .2v lower then what you want the battery to actualy be.
Old Dec 06, 2012, 12:34 AM
cb100 is online now
cb100's Avatar
United States, CA
Joined Dec 2010
So much for quality control over at spektrum eh... Lol
Old Dec 06, 2012, 08:05 AM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
For heaven's sake!
richard hanson is offline Find More Posts by richard hanson
Old Dec 06, 2012, 09:55 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
You would enjoy the DX5e with 4 basic LED showing the voltage. No more numbers.
PS: Have you check you car's speedo, quality control might also be at play there.
Old Dec 06, 2012, 11:09 AM
Joined Oct 2007
better yet , check household "120v" voltage .
Old Dec 06, 2012, 11:57 AM
Barry2020 is offline
Find More Posts by Barry2020
United States, CA, Camarillo
Joined Jul 2012
Your measuring the battery voltage at no load, while the DX7s can only display the battery voltage while under load (turned on). What your seeing is likely normal.
Can you measure the battery voltage while it is connected to the transmitter and turned on?
Barry2020 is offline Find More Posts by Barry2020
Old Dec 06, 2012, 01:46 PM
B12 is offline
B12
Find More Posts by B12
B12
Finland
Joined Sep 2010
Mine is 233V. Checked today.
B12 is offline Find More Posts by B12
Old Dec 06, 2012, 06:21 PM
Joined Oct 2007
Must be getting power from some old hand cranked Soviet plant -
better make sure the AC is travelling the correct direction..
I think 230 is correct - just like in a Chinese dentist's office.
Old Dec 06, 2012, 08:36 PM
Rhea is offline
Find More Posts by Rhea
Registered with FAA since 2016
Rhea's Avatar
United States, MN, Eden Prairie
Joined Oct 2008
Key words here are “took it out”. Measure it the way it is done in the system; under load. No load is always going to be higher.
David
Rhea is offline Find More Posts by Rhea
Old Dec 07, 2012, 02:03 AM
cb100 is online now
cb100's Avatar
United States, CA
Joined Dec 2010
David
not when it comes to tx power. provided your theory has some validity to it, how do you explain higher end tx such as jr/futaba or airtronics. even the lower end one like flysky/turnigy 9x, walkera do not exhibit these discrepancies. Placating issues such as this one only make Spektrum/HH perpetuate their inferiority. By being critical about Spektrum's negligence and push them to make it better will help them/us providing better/improved products (WIN/WIN) lol.
Old Dec 07, 2012, 04:58 AM
pach is offline
Find More Posts by pach
United States, FL, Miami
Joined Aug 2009
So what you are saying is you didnt test the voltage with a multimeter under load.
pach is offline Find More Posts by pach
Old Dec 07, 2012, 11:56 AM
Rhea is offline
Rhea's Avatar
Joined Oct 2008
I’ll try to keep this short. I spent my working career in the electronic manufacturing and testing industry. Manufacturers of all electronic products set the specifications for proper operation of that product. The only time I have seen questions of inferiority arise is when the user makes up their own understanding of the specs.
David
Question DX7 Voltage and TX power Question sajeev Radios 14 Apr 19, 2012 04:33 PM
Discussion Voltage sensor not reading correctly on ER9x w/FrSky razorseal Radios 6 Apr 14, 2012 11:41 AM
Discussion New elogger V4 not accurate rivers Eagle Tree Systems 4 Mar 31, 2012 08:37 AM
Discussion Safe voltage readings on TX (dx7) rodneygt Beginner Training Area (Fuel) 2 Jan 29, 2009 03:07 PM
Discussion V3 - Mah readings not accurate UAVProducts Eagle Tree Systems 1 Nov 04, 2008 02:42 PM
