Old Dec 22, 2012, 07:53 AM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Chester,
Where did you score the rotor..I like the 3 large blades..
Also,your painting skillz are awesome..That thing is starting to look like the real deal..2nd to the last pic above looks incredible...
Take care........Chris
Hover or die is offline Find More Posts by Hover or die
Old Dec 22, 2012, 09:11 AM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
Thanks Hover or die! Your Scorpion looks awsome.
to cut the rotor i used a compas and drew out the 25mm on the back then cut it with nail clipers ( it was the perfect shap) then i attached it to a 1230 4200kv inrunner and ran it up and sanded it to shap with a piece of 600grip sand paper i glued to a flat surface.
ill be doing the same thing to a gws rotor, ill make a video it was easy.
chester2240 is offline Find More Posts by chester2240
Old Dec 22, 2012, 06:32 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Chester, do you have the skills to solder on a new fet?
I got so good at frying Phoenix 10's, I also got really good at replacing the fet's too.
High pole motors need low switching frequency as you have now discovered.
NitroCharged is offline Find More Posts by NitroCharged
Old Dec 22, 2012, 07:02 PM
Joined Jul 2011
Im pretty sure i can solder the fets i just dont know where to get them.
And yeah now i do about the low switching frequency i wont make that mistake again
Old Dec 22, 2012, 10:07 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
ebay.
Old Dec 23, 2012, 12:05 AM
Joined Jul 2011
What name or type of fets are they, both the N and P? Or do you have a link.
I got a headache trying to reading what type of fets those are and i cant find my microfine glass.
Old Dec 23, 2012, 02:03 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
5pcs AO4606 4606 A04606 POWER MOSFET IC SOP8: http://www.ebay.com/itm/5pcs-AO4606-...item5adf90c161
5PCs Toshiba TPC8107 FET TPC 8107 SOP8 ICs: http://www.ebay.com/itm/5PCs-Toshiba...item336c3f64ec
Old Dec 25, 2012, 01:22 AM
Joined Jul 2011
Thanks for the links Nitro that will save me some money
I got my 25amp esc today and i programed the esc set all the settings to low and ran up the motor and holy cow this thing is gonna be awsome!!!!! I did a pretty ugly hook up job but for testing its ok.
I'll make a video of it tommaro
Old Dec 26, 2012, 11:56 PM
Joined Jul 2011
The EDF+ 25amp esc is now 19gr
I would like to take amp and watt readings but i dont have a watt meter.
I'll get a video of it spooling up soon i just need an eaxtra set of hands.
Old Dec 30, 2012, 02:28 AM
Joined Jul 2011
This how far ive got today
The inlet ducting isnt complet yet, the exhaust cone is 25mm-20mm and 50mm long it wont fit if its the full lentgh ive tried every thing to try to fit a full one but i would need to remove to much foam.
When i run it up it makes an awful scream i think its the cone vibrating. Maybe going up to a 85-90% exit on the tail cone. I'll post a video of it in the morning (it will be easy now that its mounted).
Old Dec 30, 2012, 04:57 AM
Joined Jul 2011
I took off the thrust tube and that wasnt it. What i found is the control linkage is amplifying the vibration in the fan, so since this is a very large outrunner im gonna balance it by puting tape on the outside of the motor case.
Old Jan 03, 2013, 04:45 PM
Joined Jul 2011
I pulled the rotor off to balance it and it felt and sounded very balanced so i was thinking the motor its self was not balanced so i ran it up to listen to it and it sounded like it was grinding somthing so i loosened the screws think it was rubbing and i ran it up again and saw sparks comming from the motor so i took the motor out and opened it up and one of the magnets was broken in half and the other half so now im gonna have to find these magnets some where . Im wondering if it has always been like that since the rotor was always balanced.
Im thinking about getting the GP 1015 and using that on 3s but im not sure it will be enough to fly this jet, i might have to do dual EDF's ?
Old Jan 03, 2013, 10:35 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Quick question about those servos: I have some on the way for my boats. Are those better than the older orange version in any way?
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jan 04, 2013, 10:59 AM
Joined Jul 2011
Ive never used the 1.7gr orange ones but so far these are holding up to 5 volts just fine ive not flown with them but im not worried about it.
Old Jan 05, 2013, 12:46 AM
bhoov128 is offline
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
This little bugger is fantastic. Subbed for eventual video of a tiny screamin' eagle.
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Discussion Sky e Matser F-15 EDF RCPLIOTTW Electric Ducted Fan Jet Talk 584 Apr 25, 2016 02:37 PM
For Sale nib gws twin 64mm edf f-15 kit with xtras 130 shipped crash8384 Aircraft - Electric - Jets (FS/W) 0 Apr 18, 2012 11:44 PM
For Sale SKYANGEL F-15 Twin 35mm EDF RC Fighter Jet www.hobbyb.com Aircraft - Electric - Jets (FS/W) 14 Apr 07, 2012 01:16 PM
Discussion 3 channel 1/48 scale MiG 15 with 25mm EDF! Joe Malinchak Micro EDF Jets and Power Systems 5 Nov 30, 2011 07:13 AM
