I really appreciate the summary...it's making sense too.
Latest blog entry: Rusty Thumbs on 3DHK Slick 360
WOW!!!
Shipped Friday from EF...and minutes after I looked up the tracking number, I just received four boxes from Extreme Flight ![]() ![]() ![]() Effectively overnight shipping from GA to MN through a snow storm. Thanks EF...looks like you did your homework on a shipping company. |
Joined Dec 2012
How long are you guys getting out of a set of 7955's or JR's with normal flying, say a mix of 3d and IMAC? The reason I ask is that in my 48in airframes I go through a set of Hitec hs65mg gears every 3 months because they get sloppy but I just sold my 50cc which had 7955's and 2 inch arms in it for over a year and they were still perfect. So I'm wondering if next time it is worth forking out some serious coin for a set of JR's? If they are going to last 2 or 3 years then it's worth it. |
Latest blog entry: Transmitt
i had a set of 4 of those, and while i didnt have them for long, they seemed to put the 65mgs to shame. just make sure to up your bec voltage to 6 or 6.5 volts as they are pretty lathargic speed wise if not bumped up
I looked at the wings and cowling so far...I'm impressed. The wing tube on this is too about 30mm outside diamter...the wing posts are aluminum about 7-8mm. The cowling is huge. The DA motor is pretty nice looking, and lighter than it looks. I'll check the covering quality and straightness of the aileron after it accilmates to the new climate. |
We finally got a break in the rain today and I fell in love all over again with the RWB scheme. I re-covered the SFGs with white ultracote and white spinner with the black Aeronaut prop and white under the fuse. Looks badass again. Need to get new B&E graphics to freshen it up a bit. If they had a RWB in stock I'd go ahead and push the button. I REALLY like the red though. |
Red/black/white! I guess I got the last one, unless they had another stash. They still have the blue/white/red in stock...just checked.
I have only looked at the wings, wing tube, cowling, and motor so far. The DA60 motor is lighter than it looks. The wing tube -- you could play stick ball with this. It is about 30mm OD (using ruler, not very precise). The pegs sticking out of the wing are 7-8 mm, and made of what I guess is aluminum. The wings look pretty good, but I have to check how straight the ailerons are still. Haven't gotten to the fuse yet. |
| Thread Tools | |
| Help! Extreme Flight 60" Edge 540T EXP or 60" Extra 300 EXP | Liberty10 | 3D Flying | 12 | Aug 10, 2012 10:36 PM |
| Sold Extreme Flight 60" Extra 300-EXP RTF | hosam | Aircraft - Electric - Airplanes (FS/W) | 10 | May 15, 2012 06:05 AM |
| Found Extreme Flight Extra 300 EXP fuselage... | pilotuku | Aircraft - Electric - Airplanes (FS/W) | 0 | May 14, 2012 12:43 PM |
| Sold extreme flight extra 300 48" exp | The_MonsterMash | Aircraft - Electric - Airplanes (FS/W) | 7 | Apr 27, 2012 03:49 AM |
