Old Dec 05, 2012, 03:01 AM
hooked13 is offline
Find More Posts by hooked13
hooked13
Joined Dec 2012
Help!
castle thunderbird 54
I have a problem with this esc in that when I plug it into my 2 brushless motors using 3.5 bullet connectors (power 25 1250kv and OS .25 1200kv the motor does not spin freely. What I mean is that I can spin both my motors freely (by hand) not connected to the esc but when connected there is friction during rotation or what seems to be friction. I thought there was something wrong with the motor but the power 25 is one day old. To test out my theory on the thunderbird esc I connected both motors to an eflite 60 amp esc that I have laying around and both motors spin freely as they should with no friction of any kind. So my questiion is what could the problem be or is this a normal action from a castle esc? This is the first castle esc that I have owned. I am no expert but I do know that there is something wrong.
hooked13 is offline Find More Posts by hooked13
Old Dec 05, 2012, 08:11 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
There is an effect called " cogging" where the magnets passing each other generate counter forces in the other magnets that can be felt as the motor is turned by hand.
In most cases, the motor will not spin freely at any time, there will always be some cogging effect. The forces and evenness of the cogging effect will change with the motor not connected to anything, it will change again when connected to the ESC, again when the ESC is powered up, and the settings you have chosen for the ESC can change it even further.
The lightest and most evenly spaced cogging will normally be felt when the motor is not connected to the ESC and all three motor leads are shorted together.
How are you connecting two motors to one ESC? That normally will not work because the ESC reads the back EMF from the motors to work right and control motor RPM. So each motor has to have it's own ESC.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Dec 05, 2012, 10:35 AM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
You can't use two brushless motors on one esc. They need individual escs.
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Dec 05, 2012, 10:44 AM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Washington
Joined Apr 2009
He may not be connecting two at a time. But, the way he stated it sounds like it?
hooked,
I have the same ESC and experience the same condition. After reaserching I found that this is not a problem.
tacx is offline Find More Posts by tacx
Old Dec 05, 2012, 11:52 AM
pilotpete2 is online now
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Definitely not a problem. Just a Castle Creations thing
What you feel is the ESC's brake action kicking in when power is removed from the ESC. Doesn't matter if the brake is programmed or not.
You'll notice that the braking action disappears as soon as the battery is reconnected.
Pete
pilotpete2 is online now Find More Posts by pilotpete2
Old Dec 05, 2012, 01:06 PM
hooked13 is offline
hooked13
Joined Dec 2012
seperate
Sorry if I made it seem like i was connecting 2 motors to one esc. That is not the case. I am connecting them seperately. One esc, one motor. I do understand the braking that the esc may have and if that is a castle creations or thunderbird thing then great. When battery is connected or not connected there is that friction (braking) action whether there is power or not. The motor does turn normal with power on but it seems as there is tension. Internals are all ok. Bearings and everything.
Old Dec 05, 2012, 01:24 PM
hooked13 is offline
hooked13
Joined Dec 2012
Thanks and it's good to know.
Old Dec 05, 2012, 03:27 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Unless the magnets have lost all or nearly all of their magnetism (over heating can cause that) you will always feel some cogging.
The motor will not spin freely without a prop on, it will spin a little more with a prop added because of the weight of the prop. If you have more than one more they will all have some cogging. Some of the smallest motors will have the most strongly felt cogging.
If you connect a multimeter to two of the motor leads you'll see you are generating an AC voltage when you turn the motor by hand, that is what is causing the magnets to "fight" each other a little give the cogging feel.
Jack
Old Dec 05, 2012, 04:04 PM
hooked13 is offline
hooked13
Joined Dec 2012
Thanks for the explanation. I understand much better now. I did connect the motor, esc and battery and the cogging actually wasn't there. I thought something was wrong when in reality my esc shut my motor down do to overheating. Thanks again.
Question Castle Thunderbird 54 issues d2tw4all Castle Creations 3 Dec 03, 2013 11:15 AM
Sold Castle Thunderbird 54 - $25 shipped 6L6Amp Aircraft - Electric - Power Systems (FS/W) 2 Jun 19, 2012 11:07 AM
For Sale NEW Castle ThunderBird 54 and Multiplex BL480/4D Motor RBYM Aircraft - Electric - Power Systems (FS/W) 1 Jun 12, 2012 04:21 PM
Sold Castle Creations Thunderbird 54 ESC New in pack $35 shipped freddb3 Aircraft - Electric - Power Systems (FS/W) 3 May 07, 2012 08:41 PM
Sold Castle Creations Thunderbird 54 ESC ZackJones Aircraft - Electric - Power Systems (FS/W) 2 Apr 30, 2012 09:24 PM
