Old Dec 04, 2012, 10:05 PM
dsmithwc04 is offline
Find More Posts by dsmithwc04
The Dude Abides
dsmithwc04's Avatar
United States, IN, Fortville
Joined Jan 2012
Problem with power transfer to blade?
Well, I've got a Rotor Concept ID-1 Swat as a project from the office. My goal is to get it flying by the end of the week but I've got a little problem. Upon starting it up I noticed it was extremely unstable and wanted to roll as well as being extremely short on power as it never actually left the ground. Since this heli is a co-axial type I decided to check that both gears were not stripped. I turned the top blades and it felt snug and could feel the motor turning but the bottom blades felt different.
I then held onto both gears and attempted to spin the top blades. As expected it didn't budge.
Then, I held onto the gears and attempted to spin the bottom blades which did move almost freely. It's as if the bottom blades arent securely attached the the gear that is spun by the motor.
So has anybody had this problem?
dsmithwc04 is offline Find More Posts by dsmithwc04
Old Dec 04, 2012, 10:31 PM
The Dude Abides
dsmithwc04's Avatar
Joined Jan 2012
Found the culprit. The top gear set which holds on to the outer blade assembly shaft (bottom blade power) is attached to the shaft assembly by two set screws. However, there is no indention into the shaft for these set screws to lock into. The screws rely on the threads in the plastic gear to hold the screw tightly against the shaft in order to transfer power from the gear (which is of course attached to the motor) to the blade shaft assembly. Well, these screws were of course stripping the plastic gear so not really sure on how to properly sort this out. What would a proper method of attaching the gear to the shaft be?
Old Dec 05, 2012, 01:22 PM
minbari is offline
Find More Posts by minbari
minbari's Avatar
Joined Jul 2012
if the set screw is stripped in teh gear, buy a new gear. ussualy only about $5
minbari is offline Find More Posts by minbari
Old Dec 05, 2012, 03:08 PM
The Dude Abides
dsmithwc04's Avatar
Joined Jan 2012
Is it usual for the set screw to not have an indention in which to crew into? Seams odd that the set screws hold onto the shaft by just the tension alone.
Old Dec 05, 2012, 04:27 PM
minbari is offline
minbari's Avatar
Joined Jul 2012
quite alot of them are that way, yes.
even the higher end heli have a grub screw that just grabs the tail shaft for tail rotor duty.
Old Dec 05, 2012, 07:38 PM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
If you can get the shaft out without much trouble, just grind
(or file) a tiny flat spot on the shaft for the grub screw to
rest in.
That is how the majority of pinions mount on 1/10 scale
electric cars.
Careful if you use a Dremel to do this, I cut halfway through
the shaft in about zero seconds and had to replace it.
I guess the best way is to break out the tiny drill bits, and send
a screw right through the shaft, and thread it into the other
side of the hub.
(as long as the shaft is not hardened steel)
The main gear on my Double Horse 9116 mounts that way.
Steve_ is offline Find More Posts by Steve_
Old Dec 10, 2012, 07:35 PM
The Dude Abides
dsmithwc04's Avatar
Joined Jan 2012
Got it fixed by drilling an indention into the shaft. I've never gotten this helicoptor to hover much less fly. It is extremely unstable and I'm having a hard time trying to figure out how to go about making adjustments. As soon as I take off to hover it rolls and not input seams to fix it.
Old Dec 10, 2012, 11:27 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
That's a rebadged Walkera LM180Q or something like that, discontinued about 3 years ago. It was terribly unreliable, they couldn't give them away. It requires very delicate swashplate leveling and weight balancing. It think it still has endless pots on the board, too. They require constant adjustments because the gyro is an old style that's very sensitive to current flow and temperature. Watch the lower rotor head, too. It looks like metal but it was plated plastic and doesn't hold on the shaft very well. If you over-tighten the screws, they will strip out the plastic. xheli was selling out the single rotor FP version of this heli about two months ago. I would have bought one if they would have priced it reasonably, because I know how to fix it. They weren't getting any takers, so they decided to try to sell it without the fuselage. What a joke!
Balr14 is offline Find More Posts by Balr14
Discussion Problem with transfering models from JR 9XII to XG11... Lars N Radios 1 Sep 12, 2012 05:53 PM
Discussion Power problem with Blade SR120 pchan23233 Micro Helis 2 May 07, 2012 02:45 PM
Discussion Problem w/ Data Transfer SD10g- help Kiteboarder 1 Radios 0 Mar 03, 2012 07:26 PM
Discussion Problems with JR Data Transfer USB Interface jhai Radios 7 Apr 07, 2009 07:47 AM
Discussion Help on low power problem with blade cx2 Soldierofroses Coaxial Helicopters 14 Dec 19, 2007 04:16 PM
