Old Dec 20, 2012, 11:46 PM
Paul Harvey is offline
Find More Posts by Paul Harvey
Canada
Joined Jun 2009
Hi Guys,
Is it possible to wet-out some of the fabrics outside of the mold, blot dry to desired resin content, then lay into mold?
I can appreciate some fabrics will not tolerate this approach such as .75 glass or 1oz Kevlar. Perhaps the difficult to handle fabrics can layered in in some way.
Could this be an approach to solving an excess resin content issue? Flame suit on
BTW I really admire the work you have been putting into this project.
Paul
Paul Harvey is offline Find More Posts by Paul Harvey
Old Dec 21, 2012, 12:15 AM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Paul, the challenge is knowing how much resin to remove and still not leave any air voids. This is the great thing about bladders on parts like this. The fabric is put into the mold while the fabric is "full" of resin and in it's relaxed state. The bladder then presses the fibers closer together leaving less space for resin. As the fibers are pressed together the excess resin migrates out of the mold along the flange. My DLG fuses would have been 16 to 18 grams heavier without the fiber compression. If the fibers don't get compressed then the open spaces between them need to filled with resin to transfer the load from fiber to fiber.
wyowindworks is offline Find More Posts by wyowindworks
Old Dec 23, 2012, 08:28 PM
samc99us is online now
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
It is possible to wet out outside the mold, this is a typical technique employed on dlg wings. However, it is difficult to avoid air bubbles as Adam mentioned but you can weigh the fabric to get exact weights. Unfortunately this really only works when you aren't distorting the fabric in the mold, as you need more epoxy in the mold to avoid bubbles.
One trick is to layer the fabrics before placing them into the mold with 3M77. This way you can wet the fabric outside the mold as one clump, place some extra resin in the mold, then drop the wet fabric into the mold and add a little more epoxy to help get it to conform. This saves you time wetting individual pieces of fabric out in the mold, and time is weight.
Reality is the layup schedule on a DLG is a science but in practice it is an artform to achieve light weights. It has become easier in the last 2 years as lighter materials are now available, but you pay a steep price to get those materials.
samc99us is online now Find More Posts by samc99us
Discussion Fuse layup bubble problems BillO Composites Fabrication 43 Jul 31, 2012 10:34 AM
Question Fiberglass Layup on a large fuse question... OR...Making big 2 piece sailplane fuses steelhead Thermal 26 Oct 20, 2010 02:23 PM
Discussion Fuse layup over white painted mold motorhead Composites Fabrication 14 Nov 18, 2007 12:50 PM
Question Guidelines for first fiberglass fuse layup (and some other molding questions)... Picoflyer Composites Fabrication 17 Dec 21, 2006 03:37 PM
Wetlap Fuse Layup Twinboom Slope 28 Nov 30, 2005 07:14 AM
