Old Dec 06, 2012, 05:29 PM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
Mold riser insert
so here is the process-
Made a fiberglass part of the riser.
Sanded it to be flat on the bottom to mount to a piece of glass.
Poured urethane rubber over it to make a mold
Then used the negative to pour my liquid polyester foam into it.
Mixed up 2 grams of polyester foam
used 1 gram to pour into part.
cut off extra once cured
weighed,
right where i want to be, .5 grams, now I will remove the foam where the hardpoints will go.
This gives me room for fabric around the riser, some splooge for the hardpoint and insert the foam.
continue with lay up
doug
dougmontgomery is offline Find More Posts by dougmontgomery
Old Dec 06, 2012, 11:25 PM
sarmoby is offline
Find More Posts by sarmoby
Composites guy
North OC, Ca.
Joined Jun 2005
Doug-
If you post the total reinforcement weight and FAW(fiber area weight-gr/m^e
I may be able to give you a theoretical CPT(cured ply thickness)
This would tell you if a perfect part has much excess resin.
Scott
sarmoby is offline Find More Posts by sarmoby
Old Dec 07, 2012, 06:00 AM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
I been p[laying around with S glass the last few days My nose layup was 1 layer 3/4 E-glass 1 layer 0/90 3 oz crowfoot http://www.aircraftspruce.ca/catalog/cmpages/120.php and a final layer of the S glass on a bias http://www.aircraftspruce.ca/catalog/cmpages/4533.php. Killer strong . The way the nose should be
Im really liking the S glass. I think its equally as good as the 5 oz kevlar in fact , I think it takes a impact better. Its half the price and doesnt drink resin like the kevlar
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old Dec 07, 2012, 06:53 PM
sarmoby is offline
Composites guy
North OC, Ca.
Joined Jun 2005
S-2 glass is a very good product. Only downside is the limited selection at low area weights.
I have been pestering my supplier for some 4180, he got me some 4 oz. a while back.
Old Dec 07, 2012, 07:11 PM
Glendale,Az.
I will do a lay up in the morning with the new HM uni. I have everything ready tonight but have a friend coming over in the morning to watch.
If i cannot make weights I am considering a change to the bottom of the fuse.
Doug
Old Dec 08, 2012, 10:21 PM
GaryO is online now
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
Doug,
What Tom said is probably very important about the cg of the finished fuse. In addition to tracking the weight , I'd also suggest tracking where the fuse balances. Ideally, what you probably want is the lightest fuse for the strength, with the most forward cg.
While a larger cross section will use more fabric and epoxy, it may well be stiffer and stronger than a smaller cross section.
When you get close to your target weight, put tail feathers and gear in it and see where the cg is. But the weight of the tails is important as well, as it is going to influence whether the nose is going to need weight or not.
Opinions may vary.
Gary
GaryO is online now Find More Posts by GaryO
Old Dec 09, 2012, 06:48 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
I did a fuse as a test this past summer that's considerably bigger than my normal. I was able to make parts in it that were only 3-5g heavier than my smaller fuse but were very strong because of the shape and profile. I couldn't build them with the same layups, I had to use less fabric and strategically place layers, but I was able to do it. Larger size doesn't mean heavier... just means you have to use different layups.
For example: bigger booms can be made with lighter uni and lighter bias wraps. I was shocked how stiff this was with minimalistic cloth. In the fuse area, I had to go with fewer layers and add a servo tray but it still came out very stiff and roomy...
Stay with it and please PM me if I can help. I have made alot of different stuff over the past couple of years.
tom43004 is offline Find More Posts by tom43004
Old Dec 09, 2012, 09:51 PM
sporter is offline
Find More Posts by sporter
Come out swinging
sporter's Avatar
San Diego
Joined Mar 2005
Strength increases with the square of the area, but material mass increases because the surface area increases as well. A small increase in diameter is a large increase in strength. What Tom said...
Sean
sporter is offline Find More Posts by sporter
Old Dec 10, 2012, 11:28 AM
G_T is online now
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
On the flip side, getting a bigger fuselage to be light means a thinner wall, and therefore lower crush resistance. Plus more drag.
Too bad there isn't a hollow carbon fabric or a hollow Kevlar fabric, like there is for glass.
Gerald
G_T is online now Find More Posts by G_T
Old Dec 10, 2012, 01:28 PM
Joined Apr 2010
In the late 80`s I was involved with several hydroplane builds. You know , boats that do 120 mph on water. We couldnt mess with the underside surface much because it created drag but to gain strength to the boat we made a lot of curves on the top structure. Kind of sucks but the more we try to stream line or fuses for DLGs the less chance we get to utilize other means of gaining strength without adding more material .Pylons for mounting the wing is one way but I dont know many others.
Old Dec 10, 2012, 02:43 PM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Doug,
S glass contains copper and thus blocks RF signals. I agree its a nice material but I would stick with Kevlar for that reason. You can go down to a 1.7oz kevlar in the nose. Using 1oz kevlar in the tailboom really helps with impact resistance.
-Sam
samc99us is offline Find More Posts by samc99us
Old Dec 10, 2012, 03:15 PM
G_T is online now
G_T
G_T
Joined Apr 2009
http://www.asminternational.org/cont...81G_p27-34.pdf - I do not see copper in the list of contents for S-glass.
It is not that glass contains a metal or metals, or not, but whether the glass is conductive. Silicon for instance can conduct, but SiO2 tends not to, and is the main constituent of glass.
Are you sure you are not thinking of some of the specialized building materials for making tempest rooms?
Gerald
Old Dec 10, 2012, 05:47 PM
prodjx is offline
Find More Posts by prodjx
prodjx's Avatar
Joined Jan 2007
How about quartz cloth.LOL. in 1971 it was going for $64 a yard. And the main idea was that radio wave's could go right through it. And it had to be strong because it was used on the nose of an F-14 Tomcat.
prodjx is offline Find More Posts by prodjx
Old Dec 10, 2012, 07:06 PM
samc99us is offline
Aurora Builder
Joined Nov 2003
Gerald, it's always been my understanding that s glass is simply stronger e-glass, until I was told otherwise by a source I trust. Looking at your rather definitive document, my statement may have been inaccurate but the crux of the matter may not. According to the ASTM standards, s glass contains twice as much aluminum oxide as e-glass. That would be a concern from an rf standpoint for sure, I use aluminum enclosures to block rf.
To close the matter, Doug do you mind range testing with your s glass fuselage vs. a Kevlar fuselage vs. bare receiver? I realize that might be tough given winter is upon us.
Old Dec 10, 2012, 07:07 PM
samc99us is offline
Aurora Builder
Joined Nov 2003
Special fabrics are still used today in rf applications.
Discussion Fuse layup bubble problems BillO Composites Fabrication 43 Jul 31, 2012 10:34 AM
Question Fiberglass Layup on a large fuse question... OR...Making big 2 piece sailplane fuses steelhead Thermal 26 Oct 20, 2010 02:23 PM
Discussion Fuse layup over white painted mold motorhead Composites Fabrication 14 Nov 18, 2007 12:50 PM
Question Guidelines for first fiberglass fuse layup (and some other molding questions)... Picoflyer Composites Fabrication 17 Dec 21, 2006 03:37 PM
Wetlap Fuse Layup Twinboom Slope 28 Nov 30, 2005 07:14 AM
