Old Jan 19, 2013, 12:14 AM
miatamama is offline
Find More Posts by miatamama
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
MIT, I just got back from our indoor night. I didnt have good luck with the maiden. I just saw that chemteacher ask the same questions I was about to. When you say left aileron dou you mean rotor tilting to left when giving left aileron.
Mine would loop toward the right then turn around to the left. I had the best flight with rotor level and right rudder down trim. Could this be cg or is my right and lefts wrong. Any ideas?
JCS
Also maidened the cub, flys great and can go very slow. Only thing is the roll. When I roll it drops the nose. Would this be CG or motor orientation. I have couple degrees right and down. CG 1/3 of cord.
miatamama is offline Find More Posts by miatamama
Old Jan 19, 2013, 07:52 AM
AJWoods is offline
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
JCS
Sorry to hear you guys are having trouble with the apache. I'll post some more pics of the rotor angles, but I guess each trim position is dependent on the build. took me a while to get mine flying properly.
As for the cub, I suggest you might want to add a slight aileron to rudder mix. cubs have a lot of adverse yaw, particularly with the big ailerons, and a 15-30% aileron to rudder mix should make coordinating the turns easier.
-Adam
AJWoods is offline Find More Posts by AJWoods
Latest blog entry: F-Zero Hovercraft
Old Jan 19, 2013, 11:44 AM
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
Adam, Thanks I will try the mixes for the cub. It is plenty good now but I was expecting the rolls to be smoother like the 300.
I will not give up on the apache, I am close to get it flying, after about a dozen launches I didnt want to break it so gave up.
Are we right in assuming that left aileron tilts the rotor to the left. If given right aileron the plane should turn right. That the rotor axle should follow the front of the fuselage slant and should be trimmed just a little to the left.
I do not know any principals of how an autogyro works. Only that one of our Guys has flown a 2 rotor in the GYM that is 3 times bigger and lots more powerful.
Mine has plenty of power but I was just thinking maybe I should have tried launching with part throttle instead of full might have stopped the looping. I am going to try a bigger rotor axle and rebalance. The axle wire I used flexes a little and might be changing the angle of the rotor.
JCS
Build Log TF Model /Smart Model Apache AH-64 Build & Detailing JayNZ Scale Helicopters 174 Jul 31, 2013 01:17 AM
Sold Align TREX 500 Size Scale AH-64 Apache Attack Helicopter Fuselage *New* $125 kclements Aircraft - Electric - Helis (FS/W) 5 Aug 13, 2012 04:37 PM
Sold AH-64 Apache Fiberglass Aerodyne Kit 500 size blue7.62 Aircraft - Electric - Helis (FS/W) 1 Apr 28, 2012 08:44 PM
Sold Syma S009g Apache AH-64 3 Channel Coax $25.00 Shipped Jake8131 Aircraft - Electric - Helis (FS/W) 3 Feb 29, 2012 04:17 PM
Rant AirHogs Reflex AH-64 3ch vs. other AH-64 Apache 3ch Sandbox\Hangar Jay-viator Micro Ready-to-Fly 56 Feb 01, 2009 04:21 PM
