Old Dec 10, 2012, 04:40 PM
gklein is offline
Find More Posts by gklein
Gary
gklein's Avatar
USA, CT, Sandy Hook
Joined Dec 2009
I love it! It already has my mind working. I am probably going to steal shamelessly!
gklein is offline Find More Posts by gklein
Old Dec 10, 2012, 04:50 PM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
I hope you post your mods or variants.
I love the way this looks in flight, but right now I've got an apartment full of planes that refuse to crash beyond repair. These micro things are too tough.
My building days seem to have been brought to a halt by the inherent ruggedness of micros leading to an apartment full of airplanes.
I can't blame it on personal skill. My MiG went in vertical when the clip on my neck strap (not in use but on the tx) totally jammed my right stick. The damage? Mostly cosmetic. I reglued the tail and flew the next day.
I'll try harder next time!
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Dec 10, 2012, 08:13 PM
AJWoods is offline
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
Haha, steal away. Whatever you come up with, feel free to post pics here.
-Adam
AJWoods is offline Find More Posts by AJWoods
Old Dec 11, 2012, 02:07 AM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
Hi MIT KID!
Where i coul find your old thread with airhogs A10 modded to 4 channel!?
I only see the video with maiden,but i search all 2010 year in micro thread and i d'ont find anything
Chhers...
nadine is offline Find More Posts by nadine
Old Dec 11, 2012, 09:30 PM
chem teacher2 is offline
Find More Posts by chem teacher2
Joined Mar 2006
ok i love this
I see rudder and elevator but what is the head servo pluged into
tom
chem teacher2 is offline Find More Posts by chem teacher2
Old Dec 11, 2012, 10:17 PM
356Jim is offline
Find More Posts by 356Jim
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
Adam,
Very nice!! This is going into my build queue, AHEAD of the Mini MonoTwirl !!
Can we see some detail of the rotor assembly, or is it the same as Al Foot's rotors (on the Twirl and Monotwirl)?
356Jim is offline Find More Posts by 356Jim
Old Dec 12, 2012, 06:26 AM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
Originally Posted by 356Jim View Post
Adam,
It's essentially the same hub design, I can do a more detailed build with pics of just the rotor. I couldn't quite figure out what his rotor dimensions were, so mine are probably different.
-A
Old Dec 12, 2012, 09:04 AM
Joined Mar 2006
Adam
also what servo did you use for the head
I have made a number of twin twirls but never a single with any success
would like to build one like yours love the video
it looks like the rotor and hub is built the same as the twin
this may sound like a stupid question what does the tilting the rotor right and left do i read in the heli section that the comand is 90 degrees off to the action
confused
tom
Old Dec 12, 2012, 10:14 AM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
I'm using one of the 2.2g Turnigy servos:
http://www.hobbyking.com/hobbyking/s...g_0_08sec.html
Tilt is for roll control, since you're directly moving the lift vector of the rotor, there's no real phase lag that you'd get with an articulated head.
-A
Old Dec 12, 2012, 10:29 AM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Is the rudder mixed to aileron or independent on the left stick?
Petefoss is offline Find More Posts by Petefoss
Old Dec 12, 2012, 02:28 PM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
Independent on left stick, I actually find you can turn tighter with hard rudder and opposite aileron compensation.
-A
Old Dec 12, 2012, 07:57 PM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
Here are some more detailed pics of putting together the rotor. I stack the base and two square spacers first using a toothpick for centering, then I coat all edges of the spacers, as well as the edges and tips of the blade roots with UHU Por. Next I shingle the blades on, using the overlap to establish the pitch angles.
I'm using a plastic pushrod guide as the hub bearing, and the pushrod stock as the shaft. To retain the rotor I glue a short length of the push rod guide to the shaft with CA. After the CA is cured you can twist it free from the shaft, and you now have a nice friction fit stopper to hold the rotor on, or take it off when necessary.
Tomorrow I'll take some detailed pictures of the rotor tilt assembly.
-A
Old Dec 13, 2012, 09:55 AM
Joined Mar 2006
thank you for the pictures that makes a lot a sence
could you also show pictures of the rotor tilting apparatus and servo linkage
tom
Old Dec 13, 2012, 01:13 PM
356Jim is offline
Joined May 2001
Originally Posted by MIT KID View Post
.................................Tilt is for roll control, since you're directly moving the lift vector of the rotor, there's no real phase lag that you'd get with an articulated head........-A
Oooh, oooh!! It would be great if you could give us the rotor tilt angle wrt to the longitudinal axis/horizontal!!
Old Dec 13, 2012, 09:47 PM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
Rotor sits parallel to the mast feature it mounts to. To get the proper balance, the stub wings should be parallel to the ground when the helicopter is held from the rotor shaft.
-A
Build Log TF Model /Smart Model Apache AH-64 Build & Detailing JayNZ Scale Helicopters 174 Jul 31, 2013 01:17 AM
Sold Align TREX 500 Size Scale AH-64 Apache Attack Helicopter Fuselage *New* $125 kclements Aircraft - Electric - Helis (FS/W) 5 Aug 13, 2012 04:37 PM
Sold AH-64 Apache Fiberglass Aerodyne Kit 500 size blue7.62 Aircraft - Electric - Helis (FS/W) 1 Apr 28, 2012 08:44 PM
Sold Syma S009g Apache AH-64 3 Channel Coax $25.00 Shipped Jake8131 Aircraft - Electric - Helis (FS/W) 3 Feb 29, 2012 04:17 PM
Rant AirHogs Reflex AH-64 3ch vs. other AH-64 Apache 3ch Sandbox\Hangar Jay-viator Micro Ready-to-Fly 56 Feb 01, 2009 04:21 PM
