Old Dec 16, 2012, 11:21 PM
Capt G is offline
Find More Posts by Capt G
Capt G's Avatar
So. Nevada
Joined Feb 2004
aft view
Capt G is offline Find More Posts by Capt G
Old Dec 17, 2012, 09:42 PM
Capt G is offline
Capt G's Avatar
So. Nevada
Joined Feb 2004
more planking - more sanding
Old Dec 19, 2012, 04:41 AM
JuanFe is offline
Find More Posts by JuanFe
Entre Rios - Argentina
Joined Mar 2009
great!
and fast!
one question...how will be the inlet an outle fans ducts and fan suport?
i dont see reinforcments in that areas...just 2 spars crossing the outlet section...
i agree with fans location forward...to get the CG easily, and speed control after but inside the ducts.
Really nice! estimated weight? and lenght?
Merry Xmas!
JuanFe is offline Find More Posts by JuanFe
Old Dec 19, 2012, 09:04 AM
Capt G is offline
Capt G's Avatar
So. Nevada
Joined Feb 2004
Juan - you are right about the Fan position for the CG, Post # 8 shows the fan actually screwed to the poplar rails but this point the pod structures are just roughed in. More structure to follow. ESCs actually go in the fuse in a compartment with the batteries behind the cockpit area on 15" cable extensions. Span is 84" and length is about the same. Est weight is aprox 18 - 19 lbs. CG computed out at 11" behind the wing leading edge measured at the fuse. Wing loading aprox 49oz.
Old Dec 19, 2012, 01:00 PM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
11 in behind the leading edge?? how big is this thing..yikes..what is the wing cord? that would need to be at least 28 in cord ..what fans are you running?
turbonut is online now Find More Posts by turbonut
Old Dec 19, 2012, 02:12 PM
Capt G is offline
Capt G's Avatar
So. Nevada
Joined Feb 2004
See post above for size. Fans are HET 9305 -700 (90mm) with HET 700-60 (2000 kv) motors using 6s batteries and Castle Ice 100s for ESCs. CG is set conservatively to give about a 10% static margain - slightly nose heavy for initial flights.
Old Dec 19, 2012, 07:13 PM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
What is the wing cord? front to back
Old Dec 19, 2012, 07:44 PM
Capt G is offline
Capt G's Avatar
So. Nevada
Joined Feb 2004
My mistake on the previous CG number - should be 8.66" from LE. Actual wing chord at LE is 23.5". Thanks for making me double ck my calcs.
Old Dec 19, 2012, 08:17 PM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Yea you had me going..Ha ha ..I was thinking it dont look that big in the pics...still 23.5 in cord is a huge wing...very cool
Old Dec 20, 2012, 05:27 AM
kestrel2003 is offline
Find More Posts by kestrel2003
No Guts No Glory
kestrel2003's Avatar
Switzerland
Joined Feb 2003
nice and clean
Very nice build, nice to see such a cleanly built balsa structure. Looking forwared to see it fly. rgds mv
kestrel2003 is offline Find More Posts by kestrel2003
Old Feb 07, 2013, 05:34 PM
Capt G is offline
Capt G's Avatar
So. Nevada
Joined Feb 2004
a little more progress-please pardon the Bondo
Old Feb 07, 2013, 05:53 PM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
What is the source of the canopy?
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Feb 07, 2013, 08:43 PM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Wow..I could tell its big but your hand gives it some scale...its huge!..the plane that is
Old Feb 08, 2013, 12:14 AM
Capt G is offline
Capt G's Avatar
So. Nevada
Joined Feb 2004
The canopy is from the RC Lander 64" T-33 ARF.
Old Feb 08, 2013, 03:31 AM
meerkat13 is offline
Find More Posts by meerkat13
meerkat13's Avatar
United Kingdom, Birmingham
Joined Jan 2013
Wow… beautiful build!
meerkat13 is offline Find More Posts by meerkat13
For Sale New #8836 K&B 3.5cc piston/liner/DF/O/B/I/B dankar04 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Apr 26, 2012 04:36 PM
Sold Oem k&b .21 d/f/o/b i/b abc p/l dankar04 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 22, 2012 06:58 PM
Sold K&b 7.5 n.i.b. darkseacret Boats (FS/W) 0 Mar 03, 2012 08:03 AM
Discussion B-57B Canberra Build Propbuster1948 Scale Fuel Planes 7 Dec 24, 2010 03:51 PM
Savage B-57B anyone? Daren Electric Ducted Fan Jet Talk 45 Apr 26, 2004 11:13 AM
