This thread is privately moderated by WDKK, who may elect to delete unwanted replies.
Old Dec 04, 2012, 06:47 AM
WDKK is offline
Find More Posts by WDKK
Trader Rating: 0
United States, IN, Fort Wayne
Joined Dec 2006
Trader Rating: 0
Wanted
Want to buy power system
HI,
I have a 53 inch v-hull boat that I need a power system for. Would like a jet pump system. I know they can be expensive but I would buy a gently used one. Also looking at gas and electric.
Any ideas would be appreciated
WDKK
I line in Northern Indiana don't mind a short drive
WDKK is offline Find More Posts by WDKK
Old Dec 04, 2012, 07:39 AM
sleepwalker is online now
Find More Posts by sleepwalker
Trader Rating: 46
sleepwalker's Avatar
United States, PA, Clearfield
Joined Jan 2007
Trader Rating: 46
I was going to try the same thing you want to do on a V-hull and was advised against it as the V toward the transom was too deep to use a pump. The jet boat hulls have a totally different bottom than a V-hull and can accept a jet pump.Maybe a crackerbox hull would work with some modification since it is a flatter V than other boats.Maybe someone that is familiar with jet boats will chime in.
sleepwalker is online now Find More Posts by sleepwalker
Old Dec 04, 2012, 10:09 AM
hampboats is offline
Find More Posts by hampboats
Trader Rating: 32
Joined Jun 2009
Trader Rating: 32
KMB jet drives
The 40mm KMB jet drives should work. Sometimes you can find used ones on the forum. I bought mine directly from KMB and it was alot cheaper, even with the euro exchange, than the price you see on Ebay. I have attached the instructions for mounting it in a V hull. I use two of them in my PBR which about as long but I am sure weights more than your boat. It originally had a gas motor in it. I use two Proteus motors and 2S lipos.
Also, check our website, www.indyadmirals.org, we have two indoor runs set up for Jan and Feb. You are welcome to come down to Indy and join us.
hampboats is offline Find More Posts by hampboats
Old Dec 04, 2012, 11:44 AM
WDKK is offline
Trader Rating: 0
Joined Dec 2006
Trader Rating: 0
That's awesome .. Hope I can find one.. When I get further along in my build, I'll post a build log.
Thanks for the response
WDKK
Wanted Power system for an FVP Absolute wanted !! OzparkPilot Aircraft - Electric - Power Systems (FS/W) 8 Nov 30, 2012 04:37 AM
Found Want to buy: 1.3 ghz (1.280 ghz US) FPV system lockweeze FPV Equipment (FS/W) 0 Nov 11, 2012 09:55 PM
Wanted want to buy 1 3gx system sergeyo Aircraft - Electric - Helis (FS/W) 1 Sep 28, 2012 11:42 AM
JR XP8103DT FM Helicopter System - Wanted to Buy bobandris Electric Heli Talk 0 Sep 10, 2001 02:39 PM
JR XP8103DT FM Helicopter System - Wanted to Buy bobandris Aircraft - Electric - Airplanes (FS/W) 0 Sep 10, 2001 02:37 PM
