Dec 15, 2012, 08:52 PM
Joined Apr 2006
Finished and maidened
I just maidened the Vixen and I must say that she is a winner.
With the recommended CG she balanced perfectly with the 2450mah 5s.
The take off run was a bit long, the plane felt heavy but she left the Tarmac gracefully, without jumping into the air.
I put 75% dual rates on ailerons and elevator and 80% expo on the steering wheel.
She looks beautiful on the air!
The CS has enough power for a relaxed kind of flight. I'm planning to use 6s for more punch.
I did some rolls, but she is very demanding on ailerons for this purpose so better to use no DR.
I tested her " floatiness" with zero power downwind and no issues, she can float easily.
Landing her was very easy, just turn to final, reduce power to 30% , let her sink slowly , reduce a little bit more until touch down and flare. No bouncing at all.
I did three 3' minutes flights, but it felt like much longer.
The batts went from 97% to 27 - 32% being a bit warm.
The booms are very solid, no need for CF reinforcement. If you manage to break one, is because the rest of the plane is also gone.
