Old Dec 05, 2012, 02:26 PM
karlik is offline
Find More Posts by karlik
Closed Account
Joined Apr 2010
There's also a good chance he changed it and didn't think it was related so didn't mention it. Or that the ratings are borderline and it's finally starting to fail?
personally, I keep looking at:
"since i bought 3 servos, i thought y not change all the 3 servos to metal gear. i used the tower pro mg90s.
there were no problems not until after the repair."
Put back the 3 old original servos and bench test.
karlik is offline Find More Posts by karlik
Old Dec 05, 2012, 02:44 PM
Steve_ is offline
Find More Posts by Steve_
Venting Nowlege
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Agreed. That was suggested in the first response
Steve_ is offline Find More Posts by Steve_
Old Dec 05, 2012, 03:26 PM
karlik is offline
Closed Account
Joined Apr 2010
What was the result?
Old Dec 05, 2012, 06:05 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
I don't think he had a chance to try that.
Old Dec 05, 2012, 06:34 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Originally Posted by janmykelg View Post
Yes, the servos are behaving correctly on throttle hold.
JUST noticed that.
If the only time they act up is when the motor is
being fed power, it makes me think wrong motor setup in ESC.
(I assume the ESC settings are adjustable to allow for different motors)
Lets review:
1) It works fine until you spool the motor.
2) It works fine on throttle hold
3) It works fine with the motor disconnected
4)The ESC gets hot quickly, but only when spooling up
This narrows it down to:
1) Bad Motor
2) Bad ESC
3) ESC setup not matched to motor
You said you changed the servos because one was stripped...
Was it stripped from a crash? Maybe you broke more than you
thought.
What you guys think?
Old Dec 05, 2012, 08:20 PM
janmykelg is offline
Find More Posts by janmykelg
Joined Nov 2012
Originally Posted by Steve_ View Post
JUST noticed that.
Lets review:
1) Bad Motor
2) Bad ESC
thought.
i think i found the problem. i tried connecting directly the servos to the receiver and it works fine. then i tried to connect the gyro back to the receiver and the servos wont move at all. do i have to setup the gyro or it's broken?
any suggestion for a great fbl gyro replacement?
janmykelg is offline Find More Posts by janmykelg
Old Dec 05, 2012, 09:14 PM
Joined Nov 2012
thought.
i had to say from a crash.
i checked it thoroughly and it's only one servo, it's a minor crash btw.
Old Dec 05, 2012, 09:49 PM
minbari is offline
Find More Posts by minbari
minbari's Avatar
Joined Jul 2012
I would say go through three fbl controller setup from start to finish all over again.
Sometimes starting over clears any mistakes you might have made
minbari is offline Find More Posts by minbari
Old Dec 05, 2012, 11:21 PM
Joined Nov 2012
im sorry but i have no idea whats the 3 fbl controller setup and how its done. i bought the heli RTF
Old Dec 06, 2012, 01:51 PM
Joined Nov 2012
dont give up on me guys, i need help here
Old Dec 06, 2012, 02:20 PM
minbari is offline
minbari's Avatar
Joined Jul 2012
What kind of fbl controller does it have? You need the manual to set it up.
RTF means ready to fix
Old Dec 06, 2012, 03:27 PM
mdugas is offline
Find More Posts by mdugas
Joined Aug 2003
hi,most likly cause of new problem is ,didnot rehook up wiring correctly.
instructions should be on there website if you havent already looked
e-hirobo.com for cx
mdugas is offline Find More Posts by mdugas
Old Dec 06, 2012, 03:38 PM
Joined Nov 2012
it's the stock gyro CX-3X1000 fbl system. im already planning on purchasing the usb cable so that i can set it up conveniently on my pc, but it would take at least a week for me to get hold of the item shipped from HK.
Old Dec 06, 2012, 03:40 PM
Joined Nov 2012
e-hirobo.com for cx
the wirings were rehooked up correctly like it was before i touched it.
Old Dec 06, 2012, 04:09 PM
mdugas is offline
Joined Aug 2003
hi intermitant than dead .ok, wire conection inside box possibly solder joint failed .
e-hirobo put post in cx3-1000 thread a while back sayin box should be opened and
inspected for that ocasionaly. intermitant .you spool up enough failing connectionn vibrates so servoes jump,again is possibility
Discussion servo acting crazy - jittering, shaking, etc. Wabball Parkflyers 9 Aug 13, 2012 04:12 AM
Help! [HELP] Ailerons acting crazy nocomp Eagle Tree Systems 8 Jun 26, 2012 09:07 PM
Help! Full throttle issue with servos acting up!! VIDEOPRO Power Systems 0 Jun 20, 2012 06:19 PM
Discussion servo crazy with throttle over 60% mick3485 Electric Heli Talk 15 Apr 29, 2012 08:06 AM
