Old Dec 05, 2012, 11:22 AM
Steve_ is online now
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Originally Posted by minbari View Post
Lol, ossum.
I charged up my dads flash on his camera, then touched wires together on the big cap. Made a huge, blinding spark and welded the wires on there. Pretty much loved electronics after that, lol
Just thought of this, minbari when you have time can you check over my
LED mod I posted a few days ago? Mikefromgermany wanted to drive several
LED's from the LED output of his PCB, and I think we found a solution
using a transistor and a few resistors.
The idea was to light extra LED's without any extra load on the host circuit.
It works on my 9116, but that does not mean it is correct
You just had to spill the beans about being an EE, huh? Now I will pester
you all the time... J/K.
Just whenever you get time. Thanks in advance,
Steve
P.S. My first "experience" was laying a metal rod across the prongs of my Lionel
train transformer, and then plugging it in the wall. It was awesome.
By age 12, I built a relay oscillator and was collecting the inductive kick from transformers, storing them in
HV caps. Driven by a pair of 9V Nicad batteries, it would charge to 800 volts.
It was basically a highly modified version of a neon lamp inverter circuit
that I found in one of those Forrest Mimms project books.
All this in a box the size of a camera. It would almost weld lockers shut.
This was in the early 80's, long before tasers were popular.
That one almost got me kicked out of school.
I was a 60lb weakling, but rarely got picked on The other kids were scared
to death of me.
Steve_ is online now Find More Posts by Steve_
Old Dec 05, 2012, 12:33 PM
janmykelg is offline
Find More Posts by janmykelg
Joined Nov 2012
Originally Posted by Balr14 View Post
Try removing the blades and raising throttle to max. Weak servos shouldn't have a problem raising cyclic with no blades.
done that, same results.
janmykelg is offline Find More Posts by janmykelg
Old Dec 05, 2012, 12:39 PM
minbari is offline
Find More Posts by minbari
minbari's Avatar
Joined Jul 2012
Same results as in it doesn't work?
minbari is offline Find More Posts by minbari
Old Dec 05, 2012, 12:40 PM
Joined Nov 2012
Originally Posted by Steve_ View Post
But it does not explain the ESC getting hot on the bench with no load.
If the ESC gets hot with the servo horns removed, I would suspect a
faulty servo or ESC.
esc gets hot even with the main and tail blades removed, i'd say about 2 or 3 mins of throttle up or less
i'm lost here guys, to tell u da truth
Old Dec 05, 2012, 12:42 PM
Joined Nov 2012
yup, servos still working crazy on throttle up w/o the blades.
Steve_'s Avatar
Joined Nov 2012
I just looked that bird up. Holy crap. Not a beginner helicopter.
If you are starting out with that, you have stones the size of
grapefruits.
Old Dec 05, 2012, 12:43 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
I guess I would run the same tests again, but disconnect one servo at a time and do it.
Balr14 is offline Find More Posts by Balr14
Old Dec 05, 2012, 12:50 PM
Joined Nov 2012
grapefruits.
haha that's funny. thats what my friend told me too
i started out with a 3 channel heli that my girlfriend bought me a few months ago and then after that i got hooked pretty hard to the hobby.
im pretty much doing everything i can to understand how the electronics works.
actually im still at the hovering stage, good thing i had the phoenix simu to practice with
Old Dec 05, 2012, 12:51 PM
Joined Nov 2012
okay, i'll try that but not at this moment. people are sleeping, it's actually 3am here in the philippines
Old Dec 05, 2012, 01:06 PM
Steve_'s Avatar
Joined Nov 2012
Yes, but does the ESC get hot just sitting idle?
Or only after you have ran the motor a few minutes?
At idle, a bad servo could generate heat in the BEC section of the
ESC, that's why I ask.
That is a BIG motor, so it may be normal for ESC to heat up after
a couple minutes of spooling up. But to be honest, if it's getting hot
after a couple minutes without the blades, imagine how hot it will
be after a 5 minute flight under load...
Dunno, way bigger than anything I have messed with (hobby stuff anyway).
Old Dec 05, 2012, 01:16 PM
minbari is offline
minbari's Avatar
Joined Jul 2012
if it cant move the swash up and down and in all cyclic directions on the bench with no blades on it, I would be looking more at the FBL controller setup. With no blades loading the servos they should be able to move that swash with ease. doesnt even have a flybar to force around, it is just moving the grips
also, are we talking about the 450 version or the 600?
Old Dec 05, 2012, 01:30 PM
Joined Nov 2012
450 version
i can still move the swash up and down, left and right, tilt forward or backward on throttle up even when it's moving on its own.
yes, after i ran the motor a few minutes it gets hot
Old Dec 05, 2012, 01:43 PM
minbari is offline
minbari's Avatar
Joined Jul 2012
It is sounding more and more like an fbl setup issue. If the servos can move, but are just moving weird, then the gyros are doing it
Not sure how you so it. But run this test. Make you pitch curve so you only get about 3 Max pitch. Then disable the fbl gyros. Spin up and see if the problem goes away
Ps, you DONT want to take off
Old Dec 05, 2012, 02:00 PM
karlik is offline
Find More Posts by karlik
Closed Account
Joined Apr 2010
I'm an old fart, so maybe I missed it (I've read the thread twice but that doesn't mean it's not right there). And I'm only an old tv repairman. not an engineer or nuthin.
But the speed controller for the motor is getting hot... and I don't see where anybody has asked what size motor and how many amps is the esc rated for?
First thread says you replaced all 3 servos and the problem started. Put back the 3 old servos and bench test - does the problem go away?
Go back to basics (we used to use flow charts). Unplug everything except the motor - still get hot? If no, unplug the motor, bypass the fbl gyro and plug the servos directly into a receiver - do they still chatter and does the esc get hot?
karlik is offline Find More Posts by karlik
Old Dec 05, 2012, 02:12 PM
Steve_'s Avatar
Joined Nov 2012
I didn't ask because he was flying it previously, the problems showed up
after servo replacement. So there is a good chance the motor & ESC combo
are compatible.
Perhaps parameters for the ESC somehow got changed or reset. If it is not
properly set up for the motor you are driving, all kinds of weird things could happen.
Discussion servo acting crazy - jittering, shaking, etc. Wabball Parkflyers 9 Aug 13, 2012 04:12 AM
Help! [HELP] Ailerons acting crazy nocomp Eagle Tree Systems 8 Jun 26, 2012 09:07 PM
Help! Full throttle issue with servos acting up!! VIDEOPRO Power Systems 0 Jun 20, 2012 06:19 PM
Discussion servo crazy with throttle over 60% mick3485 Electric Heli Talk 15 Apr 29, 2012 08:06 AM
