Old Dec 04, 2012, 12:02 AM
janmykelg is offline
Find More Posts by janmykelg
Joined Nov 2012
Help!
all servos acting crazy on throttle up
i had to replace one servo because it was stripped.
had to upgrade it to metal gear servos
since i bought 3 servos, i thought y not change all the 3 servos to metal gear. i used the tower pro mg90s.
there were no problems not until after the repair.
all servos has it's own life on throttle up. the swashplate seems to dance back and forth, left and right, including the tail
what should i do?
janmykelg is offline Find More Posts by janmykelg
Old Dec 04, 2012, 12:54 AM
Steve_ is offline
Find More Posts by Steve_
Venting Nowlege
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
I'm new to heli's but been into RC for 20 years.
Sure sounds like an interference problem, or possibly
an internal intermittent short in one of the servos.
Will your radio still initialize if a servo is unplugged?
Some will not (maybe all), so that might not work.
Is there a way to test them individually?
With an old radio and RX perhaps?
Also, look for pinched servo leads.
If the rest of the old servos were good, start swapping them out
one at a time
Also, if you have an antenna lead, the antenna touching anything
conductive will make it act crazy like that.
Steve_ is offline Find More Posts by Steve_
Old Dec 04, 2012, 02:51 AM
old4570 is online now
Find More Posts by old4570
Australia, VIC
Joined Dec 2011
Hmmm , Hardware incompatibility ?
Are the servos plugged in correctly ?
If everything is Good plug in wise ! disconnect the gyro and see if the problem goes away .
Components dont always play nice with each other .
old4570 is online now Find More Posts by old4570
Old Dec 04, 2012, 04:05 AM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
What's your heli?
Hajile is online now Find More Posts by Hajile
Old Dec 04, 2012, 08:02 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
That sounds like voltage compatibility problems. Disconnect the motor and exercise the servos.
Balr14 is offline Find More Posts by Balr14
Old Dec 04, 2012, 10:42 AM
Joined Nov 2012
Originally Posted by Hajile View Post
What's your heli?
copter x black angel FBL
Old Dec 04, 2012, 10:43 AM
Joined Nov 2012
okay i will try that
Old Dec 04, 2012, 11:08 AM
minbari is offline
Find More Posts by minbari
minbari's Avatar
Joined Jul 2012
I bet they dont have enough torque. I have those for my heli and they work ok for a flybar heli, but they only have about 1kg of torque. for an FBL heli, I bet that is the issue. (I assume that the swash is behaving correctly on the bench, for direction)
on my tail, wouldnt work AT ALL. on the bench it worked fine, but once you spun up the heli and tried to law the tail it would just seize up or go to one direction and couldnt pull it back.
replaced the tail servo with a 3kg servo and all problems went away.
minbari is offline Find More Posts by minbari
Old Dec 04, 2012, 12:05 PM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
An excellent observation, minbari. The servos have to work really hard on a flybarless heli. If they don't show any problems with the motor disconnected you probably nailed it. 3kg force on all servos is probably a good idea.
Old Dec 04, 2012, 03:17 PM
Joined Nov 2012
Yes, the servos are behaving correctly on throttle hold.
what exact brand do you recommend for a 3kg tail servo that goes well with those towerpro MG90s?
Old Dec 04, 2012, 03:19 PM
Joined Nov 2012
i haven't tried this yet, i'm still at the office for my work
but i will try this once i got home
Old Dec 04, 2012, 03:48 PM
minbari is offline
minbari's Avatar
Joined Jul 2012
The ones I have are the Turnigy tgy306g. $22 but have impressed me so far. I plan on replacing the tower pros with these after Christmas for the cyclics as well
Friend of mine said they look like mks made them
Old Dec 04, 2012, 04:46 PM
Joined Nov 2012
the one i'm using right now are the stock tail servo (Fusonic (MG-D-9257-V2) 9257 25g Metal Gear High Speed Mini Digital Servo).
so what i'll do i'll just replace that tail servo with the Turnigy tgy306g and it should work fine then?
Old Dec 04, 2012, 04:54 PM
minbari is offline
minbari's Avatar
Joined Jul 2012
If your cyclic servos are the problem, then replacing the tail won't solve that. If tail control is the problem, then yes.
I thought you said that cyclic and collective control was the problem
Old Dec 04, 2012, 04:59 PM
Joined Nov 2012
my bad. sorry. it's the cyclic and the tail servos are the problem.i have no idea what to do.
a friend of mine said that it might be the esc or the flybarless gyro that causing that problem, do u think he might be correct?
Discussion servo acting crazy - jittering, shaking, etc. Wabball Parkflyers 9 Aug 13, 2012 04:12 AM
Help! [HELP] Ailerons acting crazy nocomp Eagle Tree Systems 8 Jun 26, 2012 09:07 PM
Help! Full throttle issue with servos acting up!! VIDEOPRO Power Systems 0 Jun 20, 2012 06:19 PM
Discussion servo crazy with throttle over 60% mick3485 Electric Heli Talk 15 Apr 29, 2012 08:06 AM
