Old Jan 02, 2013, 01:08 PM
perttime is online now
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
Just saw this thread... It reminds me of a couple of things:
Tim Hooper's Blackburn B2 that he covered with aluminium builders tape (no hot irons)
http://www.modelflying.co.uk/forums/...s.asp?th=56199
(I don't think he did a build thread here)
Macchi 72 that has the forward prop of the contraprop freewheeling:
http://www.rcgroups.com/forums/showthread.php?t=1792749
perttime is online now Find More Posts by perttime
Old Jan 02, 2013, 03:23 PM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
I've used foil tape on quite a few birds. It repilcates bare aluminum well. On this bird, it has a highly polished, mirror finish, so no go
Saw the thread on the macchi, post a nasa link in there that shows the facts regarding freewheeling props.
Mark
mrittinger is offline Find More Posts by mrittinger
Old Jan 02, 2013, 04:00 PM
tr6world is offline
Find More Posts by tr6world
Mike Brinker
tr6world's Avatar
SouthEast Michigan
Joined May 2008
Fantastic job Mark. Sunglasses required to fly that bird!
tr6world is offline Find More Posts by tr6world
Old Jan 02, 2013, 05:54 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
Thanks, you'll be throwing it so.... lol
Score! Got the font for the lettering and numbers from none other than Thom Richard!
That will make things a LOT easier
Old Jan 03, 2013, 06:53 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
Well it took an hour of fanagling to get the font from a PC into my ancient Mac Power PC G3, but I FINALLY got it to open and work, and it's going to make things really easy! I ahve a customer with a sign shop that said he can produce the lettering on his vinyl machine..a lot easier than cutting Monokote trim sheet!
Mark
Old Jan 03, 2013, 09:21 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
A little more done
Old Jan 04, 2013, 07:39 AM
Brian Allen is online now
Find More Posts by Brian Allen
Veni Vidi Volavi
Sterling, VA
Joined Jan 2002
Mark
Looking very nice!! Really going to need your sunglasses on a sunny day when PM is all done!!
Brian Allen
Veni Vidi Volavi
I came I saw I flew
Brian Allen is online now Find More Posts by Brian Allen
Old Jan 04, 2013, 08:21 AM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
Thanks. I hope the yellow znd black lettering and stripes will help!
Old Jan 04, 2013, 09:14 AM
tr6world is offline
Mike Brinker
tr6world's Avatar
SouthEast Michigan
Joined May 2008
was thinking about the prop size Mark. Looking at this photo, it looks like the rear prop is smaller.... Also a nice view of how the lines are for the spinner to the fues.....
That chrome covering sure looks smooth!
Old Jan 04, 2013, 11:08 AM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
Yes, the rear prop on PM is slightly smaller dia. Im seeing significantly higher amp draws on the rear prop, even with 2" different dia....
Old Jan 04, 2013, 04:12 PM
stuntflyr is offline
Find More Posts by stuntflyr
stuntflyr's Avatar
United States, AZ, Tucson
Joined Jun 2010
The two photos above show the airplane with two different propellers. The older square clipped prop was much shorter and the difference between the front and rear lengths much greater. The new blades are a foot longer and have very little difference in length front and aft.
Chris...
stuntflyr is offline Find More Posts by stuntflyr
Old Jan 04, 2013, 09:28 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
There is a long discussion on FB fan page aboutt he props, and Thom has been on there a good bit.
Picking up 64 mph from last years speed has been mostly due to prop change. The largest difference is the sweept blades. Apparently it has something to do with high sub-mach numbers on the prop tips.
I found a NASA test paper that said, pretty much other than noise, there's not much of an efficiency reason to have a smaller dia second prop.
What I have found in testing is that even with a 12" front and 10" rear, the rear still pulls 5+ more amps.The paper also states a 1.1 to 5% increase in rear prop pitch to be optimal, so what I really need is a 12-8LH front, and a 10-8.5 rear ....wierd, I know!
I'll play around more with props
Mark
Old Jan 04, 2013, 09:39 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
Incidently, PM has 2,387,200 watts on 9000 lbs, or 265.44 watts/lb
I hope to have about 700 watts on 4 lbs, or about 175 watts/lb
Old Jan 05, 2013, 11:15 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
And a couple more hours on the sealing iron....
Old Jan 06, 2013, 07:14 AM
Dennis Sumner is online now
Find More Posts by Dennis Sumner
Wanted for breaking Ohm's Law
Dennis Sumner's Avatar
United States, MI, Canton
Joined Sep 2002
Looks great Mark.
Dennis Sumner is online now Find More Posts by Dennis Sumner
Reno Racer "Precious Metal" mrittinger Electric Plane Talk 49 Feb 15, 2007 06:36 PM
Discussion LEG 48" Precious Metal Reno Racer: Spinner color? PDX Slope Pilot Slope 19 Aug 27, 2006 08:23 PM
Precious Metal Pics so far : ) mrittinger Electric Plane Talk 92 Aug 31, 2003 09:45 PM
