Thanks for the replies guys. I went to my not local hobby shop (60 miles each way) today while I was down that way and bought all the balsa I needed for my next project... promptly breaking a 1/4 x 1/8 stick for a wing spar when I got the wood home. Duh. But there's a Michaels nearby and I may be able to get a replacement there. The other hobby shop is 15 miles each way but has very limited selection. Ugh.
Leander, Texas
Joined Sep 2003
I order $300 to $400 of wood at a time to keep stock. I have an old high school wood shop bench (bought a long time ago) where all the new wood is stored. Right now, I have enough to frame up 5 or 6 .60 sized planes. I've always got something on the work bench.
Edwin |
Gas costs were negligible since I drive down to within 5 miles of that shop once a month. And I get reimbursed for driving costs, so I actually come out ahead in that deal. So it looks like in my case that online ordering probably won't save me much, if anything. On the other hand, if I'm picky about balsa grades and quality then I'd do better to order from the 'net so that I can get what works best for a given model. Thanks guys! |
buying balsa online is good becuase it tends to be cheaper but the consistenty isn't there. One day you'll get a piece that looks like the picture of the product and the next day you will get a piece of wood thats has a thousand holes in it.
I say go with the LHS it maybe a few dollars or pounds more but in the long run you will have wood just like how you want it. |
United States, NJ, Browns Mills
Joined May 2005
I buy in bulk (usually under $100, though) by mail about once a year. I use a Master Airscrew balsa stripper to make my own strip stock from sheet, plus I use the same stripper to cut down bass for spars, etc.
I always buy more than I'll need, so I can sort out the wood for different uses. "Iron" balsa (i.e., the really heavy, hard stuff) gets put aside for use under the nose of a model, etc., whilst the lighter stuff gets used for ribs & sides, etc. I rarely can't find a use for any of the sheet I buy. Over the years (I started scratch-building around 1983), I've found I do better buying sheet and making strip stock than buying strip stock to begin with. I have more control over the quality of the wood, have less wastage, and break less in handling/storing. CD |
Buying balasa online is cheaper when you know where to get the stuff you want. It will be useless, if you get heavy material when you need light balsa. I like local hobby shop, because I can choose my balsa. Price there is same regardless of weight. If I would need balsa in large quantities, I`d probably order online.
Windsor, Canada, near Detroit
Joined Jul 2007
another source
the source i have been buying with great results, is this: Specialized Balsa Wood, jake@specializedbalsa.com, 405 8th St SE, Unit 2, Loveland CO 80537 Phone 970 461 9663, Fax 970 461 9662 and the prices are really good. for instance, 1 sheet of 1/16x3x36 is about $1; if i ask for 'c' grain is another buck, and if i ask for certain density (like 6#) is another buck. and this is specialized balsa that when getting it from a hobby shop-if you find it-(called 'contest grade'), costs about the same or more. and ordering about 10 assorted sheets the shipping is not overly expensive. |
I know at Lone Star Balsa you can request the grade/type of balsa you need and they will hand-pick it for you. They do a damn good job of it too! Yes, there is a small up-charge for hand picking, but I find it is still a lot cheaper than paying hobby shop prices. A while back I bought $100 worth of balsa and found it to be about half the price of hobby shop balsa including the shipping. Saving $50 is nothing to turn your nose up at. And in this area (Atlanta, GA) there aren't many hobby shops anywhere close by anyway.
Planeman |
Central Lake, Michigan
Joined Dec 2002
Another point about Lone Star Balsa is that they weigh and label each piece of wood you buy especially the sheeting so you know how much the piece weighs. Nice touch. As for Michaels, well, they sell Midwest so you take your chances. Besides you will generally pay less for the wood at these suppliers. I've found that Midwest balsa is always more expensive and since they sell only one type of balsa you have no choice. Most scratch builders buy from reputable balsa suppliers where quality is always consistent. |
| Thread Tools | |
| Discussion Buying Balsa online | PatrykU | Australia | 22 | Oct 31, 2006 12:42 PM |
| Buying balsa online | sabaco | The Builders Workshop | 6 | May 14, 2005 10:40 AM |
