Old Dec 03, 2012, 06:56 PM
EBerris is offline
Find More Posts by EBerris
Minneapolis, MN and Durango, CO
Joined Apr 2002
Help!
Adding 2.4 to a 72 mghz TX
I plan to install a FRSky DIY internal 2.4 module to my Hitec Eclipse TX. I would like to be able to use this TX for both 72 mghz and 2.4 but do not wish to change the external module each time I want to use one or the other transmission modes.
I plan to install a DPDT toggle switch that would direct the plus side to either the internal FRSky module or the external 72 mghz spectra module.
Is this the correct way to make everything work as I want. ie in one direction the 2.4 will transmit and in the other the 72 mghz will be transmitting.
Thanks in advance for the technical assistance. I can solder but I'm not sure I thinking about this correctly.
Ed
EBerris is offline Find More Posts by EBerris
Old Dec 03, 2012, 09:09 PM
hammer22 is offline
Find More Posts by hammer22
United States, NH, Exeter
Joined Oct 2010
I am assuming you want to leave the 72Mhz module in the radio socket? Thats going to make it a bit harder to switch the BAT+ to the 72Mhz module because your going to have to cut traces on the PCB inside the radio to control the BAT+. The correct way to do it would be to switch the PPM signal and the BAT+ between the 72Mhz and 2.4Ghz modules.
hammer22 is offline Find More Posts by hammer22
Old Dec 04, 2012, 02:45 AM
srnet is online now
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Would that disable the transmitter thats is not in use ?
srnet is online now Find More Posts by srnet
Old Dec 04, 2012, 01:40 PM
hammer22 is offline
Joined Oct 2010
Yes it would disable the unused transmitter. You need to remove the PPM signal in additional to BAT+ because there could be leakage current inside the 72Mhz module that may cause spurious RF emissions.
Old Dec 04, 2012, 02:53 PM
EBerris is offline
Joined Apr 2002
Wiring Diagram
Hammer has been very helpful in explaining how to wire a DPDT switch to my Hitec Eclipse that will allow me to switch between the internal and newly added FRSky 2.4 Module and the 72MgHz Spectra module. This installation allows me to slide a switch to select transmission in 2.4 or 72 MgHz.
Some pilots have modified their module equipped transmitters to achieve the same end but must remove the 72MgHz module when in the 2.4 mode. I wanted the convenience of simply being able to flip a switch rather than removing the module.
Thanks to Hammer for his patience in explaining the process in detail to someone that can solder but has no clue how to achieve the results I was looking for.
Ed
Sold Hitec 72 MgHz Spectra Module EBerris Aircraft - General - Radio Equipment (FS/W) 1 Sep 10, 2012 07:09 PM
Sold Hightec 72 mghz receivers EBerris Aircraft - General - Radio Equipment (FS/W) 1 Aug 22, 2012 11:01 PM
Sold Futaba 8 channel micro 72 Mghz RX EBerris Aircraft - General - Radio Equipment (FS/W) 2 Aug 03, 2012 02:32 PM
For Sale Jr 72 mghz receiver sale EBerris Aircraft - General - Radio Equipment (FS/W) 1 Jul 04, 2012 08:12 PM
Sold Parkzone 72 mghz TX/RX & Hitec Buddy Box - FREE - Just pay Shipping Wolfman Aircraft - General - Radio Equipment (FS/W) 2 Sep 30, 2009 02:37 PM
