Old Dec 03, 2012, 04:29 PM
gman3000 is offline
Find More Posts by gman3000
Joined Oct 2012
Can I use hbcp2 main motor in hbfp
Hi can I use a hb cp2 main motor in hb fp? I know ones 9t and ones 10t.
The main drive cog and frame are the same for both models.
gman3000 is offline Find More Posts by gman3000
Old Dec 03, 2012, 04:49 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
It should be fine. If you notice it's running too hot you may wish to trim the blades down to reduce drag.
Balr14 is offline Find More Posts by Balr14
Old Dec 03, 2012, 05:24 PM
gman3000 is offline
Joined Oct 2012
Why would it run hot?
Old Dec 03, 2012, 09:16 PM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
The blades on an HBFP have tons of resistance, due to their shape. They have been known to cause the 4 in 1 to go up in smoke when the motor has to work too hard.
Old Dec 04, 2012, 01:14 AM
arbilab is offline
Find More Posts by arbilab
Fly Runaway Fans
United States, TX, Fort Worth
Joined Jan 2009
I cut 3/8" off mine and main motor never got above 115F, perfectly comfortable.
Motor current on these depends on motor running in its comfort zone (back EMF) and one tooth on the pinion makes a difference. If you can't leave your finger on motor after running, that's too hot.
arbilab is offline Find More Posts by arbilab
Old Dec 04, 2012, 01:57 AM
gman3000 is offline
Joined Oct 2012
Interesting. Where abouts do you cut blades?
What about different blades?
Old Dec 04, 2012, 07:55 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
There are aftermarket blades available, like these: http://www.thinkrc.com/xtreme-fiber-...bee-p-672.html. There may be others, but that was several yeas ago.
I trimmed about 1/4" from the trailing edge, entire length. I have also tried cutting 1/2" off the end and reshaping it.
Old Dec 04, 2012, 01:31 PM
gman3000 is offline
Joined Oct 2012
How does it effect the lift
Old Dec 04, 2012, 03:09 PM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Lift feels smoother but there's no noticeable loss.Trimming the stock blades or replacing them with aftermarket was pretty standard procedure a few years ago.
Question Can this motor be used in an airplane? GoodStuff Engines 15 Oct 17, 2012 03:40 PM
Discussion Can I use this motor in the P40? GetterDragun GWS (Grand Wing Servo) 7 Aug 10, 2012 10:29 PM
Help! Can this motor be used in a car? Anjan Babu On-road Cars 12 Jun 08, 2012 04:28 PM
For Sale HBFP 4-in-1 modified for brushless main motor landru Aircraft - Electric - Helis (FS/W) 0 Dec 04, 2008 12:50 PM
Discussion HBFP - Can I use my CX2 radio, 4-in-1 & battery? puma1824 Micro Helis 5 Mar 04, 2008 05:23 PM
