Old Dec 12, 2003, 04:33 PM
austinflyer is offline
Find More Posts by austinflyer
Joined Dec 2002
Seagull Spacewalker II Conversion Ideas
Just bought the Seagulls Spacewalker II 40 size and want to convert to electric. I would like to use Kokam 1500 2 OR 3 cell in series or parallel with a brushless motor. I have a mega 20/30/3, but I don't think it will have enough to pull this plane...? Specs are
Wing Area = 627 sq. inch
Weight Glow = 6.2-6.5 lbs.
Would like your thoughts on motor, battery, prop set-ups. Thanks
austinflyer is offline Find More Posts by austinflyer
Old Dec 12, 2003, 04:40 PM
Joined Dec 2002
Picture attached
Old Dec 13, 2003, 01:21 AM
kmashima is offline
Find More Posts by kmashima
kmashima's Avatar
San Jose, California, United States
Joined Feb 2002
Hacker B50-13S, 6.7:1 gear, 15x10, and probably need 5s4p of those 1500s. If you use ThunderPower, get the 5s3p 6000mah pack. This should provide excellent performance.
-- Kyle
kmashima is offline Find More Posts by kmashima
Old Dec 13, 2003, 01:45 AM
AndyMb is offline
Find More Posts by AndyMb
AndyMb's Avatar
Maribor, Slovenia
Joined Oct 2002
You can use the Mega 22/30/3 you already have, put a gearbox on and take a 4s4p pack .
Try to search for some combos, what gearbox, what prop, what cells.
The Mega should provide excellent power !
Regards, Andrej
AndyMb is offline Find More Posts by AndyMb
Old Dec 13, 2003, 10:27 AM
Mike Parsons is offline
Find More Posts by Mike Parsons
Forgot how to fly
Mike Parsons's Avatar
Atlanta, Georgia
Joined Oct 2002
That Mega will give you plenty of performance. Put it in an MEC Superbox at 3:1 swinging a 15X10 APC E. You will be around 38 amps and just shy of 1:1 which is perfect for the Spacewalker as you dont need unlimited verticle for this sport flyer. If you want more verticle you can up the disk size at the cost of a few amps (and if you have the clearance). The Mega has a threshold of 70 amps, so you have plenty of room to work with.
I have a Mega running in my Funtana, SA CAP 232 40E and am in the process of converting a Kyosho Sukhoi with a MEGA 22/30/2. They are nice motors for the price.
-Mike
Mike Parsons is offline Find More Posts by Mike Parsons
Old Dec 13, 2003, 11:56 AM
Kou is online now
Kou
Find More Posts by Kou
Kou
Andover,MA.,USA
Joined Aug 2001
Aveox
I am thinking about the same plane and this is what I suggest:
Aveox 36/24/3, ModelAirTech 2.57:1 belt drive, APCE 14X10, 16 Cell GP3300. Castle Creation PH60 controller.
I have this set up in a Rambler 30 and it was drawing about 35-40 amp static and 10 minutes duration with throttle management.
MK
Kou is online now Find More Posts by Kou
Old Dec 18, 2003, 01:13 AM
DavidN is online now
Find More Posts by DavidN
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
I vote for Mega 20/30/3 (since you already have it) 3:1,I use an inline drive.........VK Ithink. APCe15x10. This gives performance within a couple of hundred RPM of the Hacker13s 6.7. I use 16 cells. one lipo = 3.5 nimh, so 4-5s and parallel enough to handle 40 amps.
DavidN
DavidN is online now Find More Posts by DavidN
Old Dec 18, 2003, 09:41 AM
DeaninMilwaukee is offline
Find More Posts by DeaninMilwaukee
Motors beat engines!
Milwaukee Wisconsin, United States
Joined Feb 2001
I just bought this same plane for a X-mas present to myself for glow use. Mines still in the box yet.
There have been some good power recommendations here, but I think there may be a problem with most of them, specifically prop clearance. I'm not certain here since mines not built, but I think you may not be able to use bigger than about a 11" prop without LG mods.
If true, that will limit what you can do for power.
Dean in Milwaukee
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee
Old Dec 18, 2003, 02:41 PM
ChrisD is offline
Find More Posts by ChrisD
I'm disoriented!
ChrisD's Avatar
Mt. Laurel, NJ, USA
Joined Aug 2000
Sorry I can't contribute here. I'm actually going glow - oh no!
My son (15 now) made me do it!
Dean - I also bought it for myself for glow use. We think alike!
Don't worry - I still have a bunch of electrics!
Happy Holidays,
Chris
ChrisD is offline Find More Posts by ChrisD
Old Dec 18, 2003, 10:20 PM
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
Dean I am surprised by your thoughts on prop size restriction. I have a GP 1/4 scale (79") Spacewalker. It EASILY accomodates sn 18x12 prop.
davidN
Old Dec 19, 2003, 08:59 AM
Joined Feb 2001
David: I'm going by the pic on the cover of my box. ( same kit).
It just does'nt have the look of excess clearance, the landing gear seems pretty squat and not a huge clearance to the bottom of the fuse either.
I defniately could be wrong, but measuring needs to be done before anythings purchased.
Obviously, the large prop he can fit on there, the better his potential performance will be.
Dean in Milwaukee
Old Dec 19, 2003, 09:52 AM
Forgot how to fly
Atlanta, Georgia
Joined Oct 2002
I had the same concerns with the Sukhoi Conversion I am doing. I simply could not clear a 17" prop, so I adjusted the ratio a bit and moved by e-mount up 1/4 of an inch. This gave me the clearance for a 16" even though I am only swinging a 15"
Old Dec 19, 2003, 09:58 AM
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
As in the photo by Austinflier the fuselage is very deep but the bottom curves up at the front to deceive the eye. the photo I assume is a 10" glow prop and doesn't extend below the fuse. I'll try and take a photo on the weekend
DavidN
Old Dec 19, 2003, 10:31 AM
Joined Feb 2001
Looking at my box cover, I think the yellow prop in the photo is much smaller, maybe only 6 or 7".
Old Dec 20, 2003, 12:41 AM
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
Hard to believe they would show a prop smaller than 10" for a 46glow.
here is mine with 18x12
Seagull Spacewalker II rcsoar4fun Fuel Plane Talk 5 Feb 11, 2008 12:20 PM
Discussion Seagull Spacewalker II Eflite 60 Conversion TomC Glow to Electric Conversions 3 Jul 04, 2007 01:59 AM
