Old Dec 27, 2012, 01:59 AM
George Shering is offline
Find More Posts by George Shering
Scotland
Joined May 2005
[QUOTE=Golikov;23621083For example, some known to me propellers have a maximum efficiency at the blade angle of attack of about 6 degrees. And to increase the angle of attack to 9 degrees, prop does not stall. But does accelerate just less effective. You spend more energy. In order to achieve the same result on the speed and altitude.
[/QUOTE]
how big is the difference, say from 6 degrees optimum to 4 degrees on one side and 9 degrees on the other?
A long time ago I ran the RFM 15x16 through Martin Hepperle's program and indeed the efficiency curve was very peaked, falling of rapidly from a maximum of 80%.
This was a Hannes Delago design I believe, may be wrong. It was extended by Rudi to the RFM 16x17 slim which can be very effective, but only in certain conditions. But I forget the exact efficiency curve.
Both you and Joe are right, it is the rpm v. forward speed that matters, but the thing we can change is the controller PWM ratio, hence the power, hence the rpm. The rpm could be controlled, like in helicopter governor mode, but this is probably beyond the processing power capability of the ATMega and 8051F processors used in today's controllers at F5B rpms.
Now if Steve's new controller above uses an ARM Cortex controller then we are talking business!
George Shering is offline Find More Posts by George Shering
Old Dec 27, 2012, 11:38 AM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
While it has some interesting features ---- a ARM controller is not one of them
It does have a dedicated line which can be used as a gain control for a RPM governor or that line can provide realtime RPM information. Other features will be added as interest requires.
One nice improvement to the new controller is the option to over write the data log when it fills up--now you can always have the last flight recorded.
Steve Neu
sneu is offline Find More Posts by sneu
Old Jan 06, 2013, 08:30 PM
MarkF is online now
Find More Posts by MarkF
Battery Puffer
United States, NV, Las Vegas
Joined Nov 2001
I flew the enigma again with a lot better flight this time. I changed the throttle response from 10 to 5 and it made a big difference. I was able to do 10 climbs and get everything working and setup right. I may move up a little on the response to maybe 6 or 7 to see how I like it untill I get a proper radio to do ramps. I have a quetion for Steve or Georgi. Can I replace my 18 x 21 blades with the new 18 x 23 blades with out buying a new spinner?
Mark
MarkF is online now Find More Posts by MarkF
Old Jan 06, 2013, 10:30 PM
DownUnderPilot is online now
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Anyone care to tell me how I can achieve a ramp with my Futaba 9C and 160 HV2? Not for F5B, but speedcup style flying where some kind of ramp is necessary to prevent my setup melting in the first 1-2 seconds...
DownUnderPilot is online now Find More Posts by DownUnderPilot
Old Jan 07, 2013, 03:08 AM
Gerben is online now
Find More Posts by Gerben
Joined Dec 2004
MarkF: no, you need to buy a complete prop.
Gerben is online now Find More Posts by Gerben
Old Jan 07, 2013, 07:34 AM
MarkF is online now
Battery Puffer
Joined Nov 2001
Thanks Gerben, I only ask because I havn't seen it available in 38mm and because I'm only pulling 159 amps. Aern't you guys pulling closer to 200 amps? My battery and motor were only warm after my flight and all though the speed looked good it didn't look as good as you guys are doing.
Mark
Old Jan 07, 2013, 01:52 PM
Joined Dec 2004
Hi Mark,
On my WC setup I was at about 5.3kw's, that's pretty close to what you're seeing.
You get used to the speed very quickly
IGerben
Old Jan 07, 2013, 08:30 PM
MarkF is online now
Battery Puffer
Joined Nov 2001
The bystanders thought my plane was crazy fast and I thought yea not bad.
Mark
Old Jan 07, 2013, 08:32 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
Mark
You could come down and fly with us sometime and get a first hand idea of the setups that are in use. We are usually out on Sunday afternoons at the SEFSD field.
Steve
Old Jan 07, 2013, 08:36 PM
MarkF is online now
Battery Puffer
Joined Nov 2001
Well I guess not this Sunday since the AMA show is this weekend but I might be able to the following weekend. I will double check with you guys when the time comes to make sure your going to be there.
Mark
Old Jan 29, 2013, 05:00 PM
Dotcom is offline
Find More Posts by Dotcom
Winterthur, Switzerland
Joined Aug 2003
Limiters?
Hello all,
as a side question related to 10s powertrains, what limiters are used or available? Is a SM Unilog setup required or are Neu or eflight or any other manufacturer coming out with their custom-made limiters? I see currently available limiters are good up to 6s only.
Looking forward to getting into F5B,
Cheers, Andy
Dotcom is offline Find More Posts by Dotcom
For Sale Lightly used F5B Sting Hotliner for sale, no electronics multi-planes Aircraft - Electric - Airplanes (FS/W) 2 Jun 25, 2012 05:32 PM
Discussion Setting up the F5B gas box when motor ramp is used David H High Performance 16 Sep 18, 2011 11:41 AM
Discussion Throttle ramps - traction control for F5B Mike Seale High Performance 37 Mar 08, 2011 10:17 AM
Use a switch as a WOT control for big brushed motors WingMan33 Power Systems 17 Feb 26, 2004 05:38 PM
