Old Dec 04, 2012, 07:52 PM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
DXF is much easier for me to use than PDF.
Roto Rob is offline Find More Posts by Roto Rob
Old Dec 04, 2012, 08:45 PM
bullseye000 is offline
Find More Posts by bullseye000
bullseye000's Avatar
Aurora Municipal, Illinois, United States
Joined Jul 2002
Sure it is. If you have a CAD or drawing package installed that opens dxf files and actually interprets it correctly. If I'm looking to build from a plan and not modify it then any CAD file adds no value.
bullseye000 is offline Find More Posts by bullseye000
Old Dec 05, 2012, 04:53 AM
WMD is offline
WMD
Find More Posts by WMD
WMD
WMD's Avatar
Bradford, UK
Joined Jan 2010
Originally Posted by Hutch View Post
Opened fine in Autosketch 10. It had to flatten the 3d elements but that's totally normal as Autosketch is a 2D only program.
-hutch
Thanks Hutch. That's interesting - can you tell me what 3D elements are there in there, exactly? I was expecting this to be a completely flat 2D drawing.
I am also still surprised by the filesize - I would have expected a DXF file, being vector based, to be a lot smaller than the 4MB we have here. Maybe by a factor of 10. Is there a way to get the filesize smaller by ripping anything else out?
WMD is offline Find More Posts by WMD
Old Dec 05, 2012, 05:33 AM
WMD is offline
WMD
WMD
WMD's Avatar
Bradford, UK
Joined Jan 2010
Originally Posted by bullseye000 View Post
I've worked with CAD and drawing programs for most of my adult life and this has always been a perpetual thorn in the side. Even though dxf was supposed to be a common file exchange type I always seem to encounter something that is wonky. To be honest unless you are posting the files in a CAD format with the intention of letting a user modify them, I think a pdf file is an excellent alternative. Print and go. I think the pdf relieves the user of neeeding the right app to open a file.
Yes, that's the plan. The default format for all plans on Outerzone is pdf. This will remain so. I expect that all the CAD files that get added on top of this service will only ever appear as optional further bonus versions of a pdf plan.
That way, if you want the CAD file and if we have it available, then you can have it. Conversely if you don't want CAD, you ignore it, and continue as usual with the pdf.
Old Dec 05, 2012, 11:09 AM
Hutch is offline
Find More Posts by Hutch
Slopeaholic
Hutch's Avatar
Roseville, California, United States
Joined Mar 2001
I thought the file size was pretty big too. There are two "lighting locations" that show up outside of the plan that look like they are there to shade a 3d object. I'm not sure specifically what in the plan is 3D but I just assumed that the Fuel tank, bell crank, and elevator horn were drawn in 3D and not just flat isometric drawings.
I'll try opening it up in DWG True View and see if it sheds any more light on the subject.
-hutch
*EDIT* - Tru View Shows a lighting object off to the left bottom of your plan sheet. If you got rid of that I bet your file size would go down substantially.
Hutch is offline Find More Posts by Hutch
Old Dec 06, 2012, 04:31 AM
WMD is offline
WMD
WMD
WMD's Avatar
Bradford, UK
Joined Jan 2010
Thanks - in fact thanks to everyone.
I think this has established for me that using TurboCAD as a viewer is really the problem, and if I instead recommend DraftSight to all site users as a viewer, and if we all use 2000 Ascii DXF as the standard format, we should be in a pretty good position for the future.
Old Dec 07, 2012, 05:34 AM
SRWitt is offline
Find More Posts by SRWitt
Joined Jan 2011
As a "professional" in the drafting/design field i could get behind the draftsight recommendation, its what I have on my home computer, just as good as Autocad LT(damn near a clone of the older versions). Ive tried turbocad in the past and just couldn't get into it. Draftsight is free as well.
SRWitt is offline Find More Posts by SRWitt
Question Can a pdf file be imported into a cad file? JIMA Scale Kit/Scratch Built 24 May 29, 2012 06:27 AM
Discussion How do I convert CAD files to PDF? OFFA 1 Foamies (Scratchbuilt) 6 May 14, 2012 10:30 AM
Discussion Any Open Source / CC CAD Files for gliders? DrFragnasty Composites Fabrication 8 Apr 09, 2012 05:36 AM
Question Looking for Supra 3.4m CAD Files orrinade Multi Task F3X 1 Mar 23, 2012 10:15 PM
Pentax Optio 5si question on camera files format BobFlyer Aerial Photography 2 Apr 25, 2005 05:31 PM
