Old Dec 03, 2012, 11:52 AM
weekend hack is offline
Find More Posts by weekend hack
weekend hack's Avatar
Riverside, California,USA
Joined Mar 2009
CMP Yak 54
Any one have this model? CMP Yak 54 .46-.50 size. I have had 2. I first put a .61 Magnum engine in it but it seemed under powered. Then I placed a Magnum .91 four stroke in it. Over all it seemed to be a good fit, as far as the cowl etc. It balanced by placing the battery to the rear. However, It flew heavy, during moderate elevator input it would (high speed stall?) snap roll to right. I thought it was over powered and possibly too heavy / high wing load. The landing gear broke during a light bounce. I replaced it with a metal gear. Any way eventually it met its demise.
I bought a second one recently placing a Magnum .60 four stroke, more along what was recommeded. To balance it I had to place the battery forward under the fuel tank and add an additional 12 oz ! of weight behind the engine. Now it still flys like the first one, heavy and wants too snap roll during moderate elevator input. The only thing I can think of is to extend the motor mount (considerably) to balance it so I can remove the 12oz of lead added. I will also have to add a few inches to the cowl...more work than I wanted to put into it. Anyone esle have this plane and have a similar problem?
weekend hack is offline Find More Posts by weekend hack
Old Dec 04, 2012, 07:36 AM
dtm360 is online now
Find More Posts by dtm360
Hong Kong
Joined Sep 2004
Give up, the CMP Yak was not the best plane in the world. You have hit upon it's problem... high wing loading and snap happy....
dtm360 is online now Find More Posts by dtm360
Old Dec 04, 2012, 12:02 PM
jetmech05 is online now
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
Wow must be the design. I fly a Yak 50CC size and have no problems.
Have you tried reducing the throw a bit more?
jetmech05 is online now Find More Posts by jetmech05
Old Dec 06, 2012, 08:33 PM
Joined Mar 2009
Thats what I was afraid of, like they say you get what you pay for. Thanks for the reply. tomorrow I am going to test fly it. I extended the motor mount up 3 inched forward. We will see.
Old Dec 06, 2012, 08:42 PM
Joined Mar 2009
Yea, I have them set at the recommended throws. It is a conservative amount. When flying it, if you get into trouble and have to give anymore than mild elevator input, stand by she may snap to the right and if you do not have a good amount of altitude, shes going in.Glad your is flying well. Guess I should super size! Thanks for the suggestion
Old Dec 07, 2012, 10:11 AM
Jacksonville Fla.
Joined Mar 2007
A snap with full elevator can be a sign of too much throw...If you're not running out of elevator on landing try reducing the throws some.....the instruction on CG and throws are a starting point
Good Luck...I hope it's not the airplane
Wanted Cmp Yak 54-50 jroteff Aircraft - General - Miscellaneous (FS/W) 0 Aug 07, 2012 08:03 PM
Help! CMP Yak 54 question HMX Dave Glow to Electric Conversions 8 Oct 26, 2008 12:30 PM
For Sale CMP Yak-54 140 size 72" Backwing Aircraft - Fuel - Airplanes (FS/W) 2 Sep 16, 2007 07:39 PM
For Sale New CMP Yak 54 with TT91 Four Stroke Stewby Aircraft - Fuel - Airplanes (FS/W) 1 Dec 20, 2005 04:04 PM
For Sale New CMP Yak 54 W/ TT91 FS/Futaba T6XA Stewby Aircraft - Fuel - Airplanes (FS/W) 0 Nov 19, 2005 02:10 PM
