Old Dec 22, 2012, 03:15 AM
Rocketboy1030 is offline
Find More Posts by Rocketboy1030
Rocketboy1030's Avatar
Canada, ON, Mississauga
Joined Nov 2011
I bought the 70mm and the 90mm version , looks good .I hope the power is there....running them on test 'mule's first .
Rocketboy1030 is offline Find More Posts by Rocketboy1030
Old Jan 02, 2013, 03:03 AM
mopetista is online now
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
alloy 70mm and 90mm at HK
- and there's the single piece rotor in the 90mm version.
hope HK will sell the rotor separately as well...
mopetista is online now Find More Posts by mopetista
Old Jan 02, 2013, 11:35 AM
darmar is offline
Find More Posts by darmar
USA, PA, Pittsburgh
Joined Jul 2001
Pay attention to the rotor dia of 86mm vs 89 of CS. Just heads up depending on what brand shroud you use. That is 6mm gap on standard shroud.
darmar is offline Find More Posts by darmar
Old Jan 02, 2013, 11:51 AM
Vienna, Austria
Joined Apr 2007
86mm vs. 89mm diameter - not sooo bad
thanks, I wasn't aware of that difference - however since we are talking diameters (not radii) it's 3mm difference, not 6mm, or 1,5mm "material" everywhere (and twice on opposite sides, so it makes 3mm) - could be done using tape on the inside of the shroud, or?
Old Jan 02, 2013, 05:05 PM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
CS 90mm12 rotor is not 89mm, I just measured two of mines, and the soft lighter one is 86,4mm, the stiffer, heavier one is 86,65mm.
Inner dia off the shroud is 88,4mm, so I think it would be a good match with this one pice rotor.
MagnusEl is offline Find More Posts by MagnusEl
Old Jan 02, 2013, 06:16 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Sounds great... Now if they were actually available to purchase as a rotor only.
invertmast is offline Find More Posts by invertmast
Old Jan 02, 2013, 06:53 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
I hope they do the single piece rotor with the 120mm also...
If they're made in the same place as the haoye rotors (since the 70mm accepts the same shaft adapter and have similar looking hub holes) then it could stand a lot of spinning force.
erh7771 is offline Find More Posts by erh7771
Old Jan 03, 2013, 12:43 PM
voxel is offline
Find More Posts by voxel
United States, FL, Altamonte Springs
Joined Jun 2012
I'm pretty sure ParkRCmodels stocks the rotors... these it?
http://parkrcmodels.com/product_info...oducts_id=1442
I know they stock the other Lander fan rotors (70mm 5-blade).
voxel is offline Find More Posts by voxel
Old Jan 03, 2013, 01:01 PM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
That's the multi-piece unit at ParkRC.
alexandermh is offline Find More Posts by alexandermh
Old Jan 03, 2013, 01:05 PM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
So is there a ONE piece 12 blade 90 mm rotor ? Or is Tim yoinking all our chains ?
pencon is offline Find More Posts by pencon
Old Jan 03, 2013, 03:05 PM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Yes there is.
HK sells the fan and the fan+motor combo.
http://www.hobbyking.com/hobbyking/s..._Heatsink.html
anlucas is offline Find More Posts by anlucas
Old Jan 03, 2013, 04:16 PM
Joined Mar 2004
Originally Posted by anlucas View Post
Yes there is.
He said ROTOR.... As in Fan ROTOR only.. Not fan and motor
Old Jan 03, 2013, 04:28 PM
Fairborn, OH
Joined Nov 2009
I haven't seen the rotor sold separately anywhere yet.
Old Jan 03, 2013, 04:41 PM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
I don't know why Tim would tell us all it was already available when obviously it has not hit the market as a one piece rotor yet!!
unclecrash is offline Find More Posts by unclecrash
Old Jan 03, 2013, 04:45 PM
Alpha10 is online now
Find More Posts by Alpha10
Alpha10's Avatar
United States, IL, Chicago
Joined Aug 2011
It has... Park and EDFhobbies has them
Alpha10 is online now Find More Posts by Alpha10
Discussion New series EDF LEDFDPS64-1A33 4S/.10 blades rotor version Tim Wan Electric Ducted Fan Jet Talk 2 Oct 05, 2012 11:45 PM
Sold TamJets TJ90MM Fan With Change Sun 12 Bladed Rotor $275 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 1 Apr 02, 2012 04:24 PM
Sold Alfa 5 bladed Rotor and 5 rotor plugs NEW $12.00 Shipped FieldofDreamsFlyer Aircraft - Electric - Jets (FS/W) 1 Jan 18, 2012 04:58 PM
Question Will a genius canopy (one piece new version) physically fit on an MCPx? Ampdraw Micro Helis 8 Dec 12, 2011 04:16 PM
