Old Dec 03, 2012, 09:35 AM
Tim Wan is offline
Find More Posts by Tim Wan
Joined Apr 2008
RCLander new one piece version 12 blades rotor for 90mm edf
This is our new one piece version 12 blades rotor for 90mm which is light but strong.
Overall thrust power is a little bit more than put together version and the current draw amps amount is also lower (2-3A difference with same voltage level). The running sound effect is same as existing put together version. BTW It is saved any put together trouble and easy to handle the balancing.
This rotor is come with 5mm shaft adaptor & alloy spinner. 8mm shaft adaptor is an option parts.
It can be applied with our existing new multi stators metal housing..
Those are ready for ordering now.
If you have any question, please feel free to contact with our dealers or us.
Best regards,
Tim
Tim Wan is offline Find More Posts by Tim Wan
Old Dec 03, 2012, 09:48 AM
viperviper is offline
Find More Posts by viperviper
Antarctica
Joined Apr 2012
What is the diameter of this 70mm 12 bladed fan? same as the 10 blade fan? dimension? can it be fitted on the 10 bladed CS shroud?
viperviper is offline Find More Posts by viperviper
Old Dec 03, 2012, 10:13 AM
Antarctica
Joined Apr 2012
ignore the above. thought it was for 70mm.
Old Dec 03, 2012, 11:59 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
This is great news Tim.
Looking forward to some tests.
When will this be available?
anlucas is offline Find More Posts by anlucas
Old Dec 04, 2012, 04:01 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Will we be able to purchase the one piece rotor with the shaft adapter by themselves and without the shrouds?
Very nice looking and makes sense
Is this as strong as the haoye 7 blade rotor?
Lee Liddle put over 7k watts through the haoye rotor in some test earlier this year...
Regards
erh7771 is online now Find More Posts by erh7771
Old Dec 04, 2012, 04:26 AM
Tim Wan is offline
Joined Apr 2008
Hi anlucas,
it is already for any order now.
Tim
Old Dec 04, 2012, 06:48 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Hi Tim,
Looks like a good improvement over fans with many parts.
A suggestion, perhaps you can add the company name to the title of your thread, and post a link to where it may be purchased.
Also interested in the price of the fan only.
Cheers
4stripes is offline Find More Posts by 4stripes
Old Dec 04, 2012, 08:25 AM
darmar is online now
Find More Posts by darmar
USA, PA, Pittsburgh
Joined Jul 2001
I'd like to see picture of rotor hub inside. Looks like blade area has been reduced in the root area to have same hub diameter on top and bottom unlike original CS version. This might be new CS version? Rotor hub looks identical to 10 blade 70mm version.
darmar is online now Find More Posts by darmar
Old Dec 04, 2012, 04:52 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
I would also be interested in a rotor/adapter only purchase
jcdfrd is offline Find More Posts by jcdfrd
Old Dec 05, 2012, 12:37 AM
Pepperpete is offline
Find More Posts by Pepperpete
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
I am interested but who do I buy from??
Pepperpete is offline Find More Posts by Pepperpete
Old Dec 05, 2012, 12:54 AM
anlucas is offline
anlucas's Avatar
Joined May 2011
I guess it should be available in the coming days from the usual sources.
Old Dec 05, 2012, 08:39 AM
rfodor is offline
Find More Posts by rfodor
United States, GA, Alpharetta
Joined Feb 2009
It has been available at Hobby King for over a month in both 10S and 6S versions.
http://www.hobbyking.com/hobbyking/s...watt_10s_.html
http://www.hobbyking.com/hobbyking/s..._2250watt.html
rfodor is offline Find More Posts by rfodor
Old Dec 05, 2012, 08:49 AM
invertmast is online now
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
where can one get just the rotor and adpater?
invertmast is online now Find More Posts by invertmast
Old Dec 05, 2012, 08:57 AM
anlucas is offline
anlucas's Avatar
Joined May 2011
These are the motor/fan combos but with a rotor made up of separate blades like the CS12 fan.
I am under the impression that the one piece rotor is totally new - thus the new thread...
Old Dec 05, 2012, 11:32 AM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
Looks like this might be it not sure though.
http://parkrcmodels.com/photos/MBS90rotorcrp.jpg
Looks like a one piece rotor
http://parkrcmodels.com/product_info...oducts_id=1415
unclecrash is offline Find More Posts by unclecrash
Discussion New series EDF LEDFDPS64-1A33 4S/.10 blades rotor version Tim Wan Electric Ducted Fan Jet Talk 2 Oct 05, 2012 11:45 PM
Sold TamJets TJ90MM Fan With Change Sun 12 Bladed Rotor $275 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 1 Apr 02, 2012 04:24 PM
Sold Alfa 5 bladed Rotor and 5 rotor plugs NEW $12.00 Shipped FieldofDreamsFlyer Aircraft - Electric - Jets (FS/W) 1 Jan 18, 2012 04:58 PM
Question Will a genius canopy (one piece new version) physically fit on an MCPx? Ampdraw Micro Helis 8 Dec 12, 2011 04:16 PM
