View Poll Results: Whatís the most important thing to you?
Lowest possible cost 3 23.08%
Make it as small and light as possible 6 46.15%
Battery longevity is very important 3 23.08%
Highest power possible 3 23.08%
Highest RPM possible 2 15.38%
Only use through hole construction 2 15.38%
No winding of transformers 4 30.77%
Group buy of components including boards 0 0%
Group buy of boards only 1 7.69%
Iíd rather buy a kit with everything in it 0 0%
I want to buy a pre-built & pre-programmed system 0 0%
I only want to use a 4.8v Ni-MH battery 2 15.38%
I only want to use a 2S battery 1 7.69%
I only want to use a 3S battery 1 7.69%
I want to use a 4.8v battery to 3S battery 5 38.46%
I want to use only off the shelf parts from Digi-Key or Mouser 3 23.08%
I want the Timer board to be separate from the HV board 6 46.15%
I want a combination Timer & HV board 1 7.69%
I want all the options possible using jumpers 3 23.08%
I want a USB connection 2 15.38%
I want a serial connection (DB9) and Iíll use my own USB adapter 3 23.08%
I want a ICSP connection 3 23.08%
I want a premade parts list (BOM) at Digi-Key 2 15.38%
I want a premade project parts list (BOM) at Mouser 1 7.69%
I want 1 design and 1 design only 1 7.69%
I want optional designs to choose from and Ill make the boards myself 8 61.54%
Multiple Choice Poll. Voters: 13. You may not vote on this poll
Old Feb 21, 2013, 09:32 AM
ZAGNUT is offline
Find More Posts by ZAGNUT
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
how are you guys handling the spark delay on start up? is it just a set delay until the engine is up to a certain speed? or is it something more elaborate like with the synchrospark where the dwell time of the magnet under the hall sensor is measured?
ZAGNUT is offline Find More Posts by ZAGNUT
Old Feb 21, 2013, 10:05 AM
Nav_Aids is offline
Find More Posts by Nav_Aids
Nav_Aids's Avatar
Canada, MB, Winnipeg
Joined Nov 2011
It is a set delay but, the amount can be changed in the code. I believe the most used amount works out to 5 degrees advanced for starting.
When the timing uses the look-up table (delay/timing) is once again set in the code, so you could say that the engine is not concidered running until the rpm hits something like say 400 rpm. The code also can be set to distinguish between you slowly turning the motor (No Spark) and you trying to start it, say 200 rpm.
This one is a little more tougher to answer because there is no set hall sensor being used. IMHO I think we all agree to use a rising edge. Because there is no set Hall Sensor used the trigger point (Dwell Point) is different for every magnet and every Hall Sensor used. Jake has done a pretty good job with the code and if you set the magnet and sensor properly while watching the sense LED then only the trigger point is important (Digital), same as a RCexel ignition. With the SynchroSpark you described it is more like an inductive pickup rather than hall sensor (digital switch).
Ray
P.S. Nice to see your still around Zagnut.
Nav_Aids is offline Find More Posts by Nav_Aids
Old Feb 21, 2013, 10:26 AM
ZAGNUT is offline
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
Ray
that's precisely what has always bugged me about the synchro spark: it supposedly measures dwell time between rising and falling edges to determine start up retard yet it gets installed with any combination of magnet size and hub diameter and still seems to work just fine. just guessing they picked a nice middle ground that works OK no matter how it's set up.
Old Feb 21, 2013, 10:57 AM
Nav_Aids is offline
Nav_Aids's Avatar
Joined Nov 2011
I apologize to everyone that I haven't been more active on this thread but, life has been very busy for me lately. Good news is that I have finally been able to get back to the ignition and start to do some testing. I'll update when I get a chance.
Ray
Old Feb 21, 2013, 11:21 AM
Nav_Aids is offline
Nav_Aids's Avatar
Joined Nov 2011
......... just guessing they picked a nice middle ground that works OK no matter how it's set up.
That is what most manufacturers do and this way they play it safe. I've seen some engines double their power just by adjusting the ignition timing. Have to remember not to get greedy or you could end up melting a hole in the piston and I've been down that road. In the case that we use here (airplane power) just changing a prop size could put an engine in trouble or make it a dog for no reason other than timing. That's what makes this ignition so great, you have full control of the timing.
Lets say you put a bigger prop on and you take the plane for a test flight. During the test the engine doesn't seem to be putting out enough power you could through a bit-switch throw a switch on your transmitter and instantly load in a different timing curve while still in the air to see if the power increases or maybe gets worse.
Ray
Old Feb 26, 2013, 02:00 PM
Gompy is offline
Find More Posts by Gompy
Gompy's Avatar
The Netherlands, NH, Alkmaar
Joined Dec 2012
Have fun.
Gompy is offline Find More Posts by Gompy
Old Feb 27, 2013, 12:24 AM
dinoslmn is offline
Find More Posts by dinoslmn
Netanya, Israel
Joined Oct 2003
Hi Rob,
Can you share with us?
Explication please.
The program and "The Aplication" have a "public" licence?
Dino
dinoslmn is offline Find More Posts by dinoslmn
Old Feb 28, 2013, 08:22 PM
Nav_Aids is offline
Nav_Aids's Avatar
Joined Nov 2011
Old Mar 03, 2013, 08:15 AM
Gompy is offline
Gompy's Avatar
Joined Dec 2012
Have fun.
Old Mar 17, 2013, 08:34 AM
Gompy is offline
Gompy's Avatar
Joined Dec 2012
Have fun.
Old Mar 17, 2013, 10:33 AM
dinoslmn is offline
Netanya, Israel
Joined Oct 2003
WOW !!, WOW !!, WOW !!
Old Mar 19, 2013, 04:40 PM
CharlieM41 is offline
Find More Posts by CharlieM41
Joined Dec 2012
So Rob, Can you give us more details? Obviously this is not free, so what it the price?
CharlieM41 is offline Find More Posts by CharlieM41
Old Mar 19, 2013, 04:58 PM
Gompy is offline
Gompy's Avatar
Joined Dec 2012
Have fun.
Old Mar 20, 2013, 03:46 PM
bluejets is offline
Find More Posts by bluejets
Joined Dec 2012
Link is not working.
bluejets is offline Find More Posts by bluejets
Old Mar 20, 2013, 03:56 PM
Gompy is offline
Gompy's Avatar
Joined Dec 2012
Have fun.
Discussion CD Ignition lead and fixed plug .... solentlife Engines 10 Feb 18, 2014 11:03 AM
For Sale NIB 52cc Gas engine w/CD-Ignition 3.2kw kukntra Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jul 23, 2012 08:10 AM
Discussion Best open source autopilot vs commercial solution syncra Multirotor Talk 0 Apr 12, 2012 01:35 PM
Discussion Any Open Source / CC CAD Files for gliders? DrFragnasty Composites Fabrication 8 Apr 09, 2012 05:36 AM
Discussion I'm designing an open source quad frame. Inclusions anyone? Physics_Dude Multirotor Talk 3 Mar 11, 2012 12:22 PM
