View Poll Results: Whatís the most important thing to you?
Lowest possible cost 3 23.08%
Make it as small and light as possible 6 46.15%
Battery longevity is very important 3 23.08%
Highest power possible 3 23.08%
Highest RPM possible 2 15.38%
Only use through hole construction 2 15.38%
No winding of transformers 4 30.77%
Group buy of components including boards 0 0%
Group buy of boards only 1 7.69%
Iíd rather buy a kit with everything in it 0 0%
I want to buy a pre-built & pre-programmed system 0 0%
I only want to use a 4.8v Ni-MH battery 2 15.38%
I only want to use a 2S battery 1 7.69%
I only want to use a 3S battery 1 7.69%
I want to use a 4.8v battery to 3S battery 5 38.46%
I want to use only off the shelf parts from Digi-Key or Mouser 3 23.08%
I want the Timer board to be separate from the HV board 6 46.15%
I want a combination Timer & HV board 1 7.69%
I want all the options possible using jumpers 3 23.08%
I want a USB connection 2 15.38%
I want a serial connection (DB9) and Iíll use my own USB adapter 3 23.08%
I want a ICSP connection 3 23.08%
I want a premade parts list (BOM) at Digi-Key 2 15.38%
I want a premade project parts list (BOM) at Mouser 1 7.69%
I want 1 design and 1 design only 1 7.69%
I want optional designs to choose from and Ill make the boards myself 8 61.54%
Multiple Choice Poll. Voters: 13. You may not vote on this poll
Old Jan 10, 2013, 01:13 PM
Nav_Aids is offline
Find More Posts by Nav_Aids
Nav_Aids's Avatar
Canada, MB, Winnipeg
Joined Nov 2011
Originally Posted by jakestew View Post
Update
New spreadsheet versions posted on the website!
http://www.electrofunnel.com/CDI-2012/index.htm
A big thanks goes out to Ray Richter (Nav_Aids) for creating these versions!
-Jake
Thanks Jake but you did the bulk of the spreadsheet, the hard stuff, I'm just tweeking it.
Ray
Nav_Aids is offline Find More Posts by Nav_Aids
Old Jan 17, 2013, 05:57 AM
tune by tito is offline
Find More Posts by tune by tito
Inventor&Genius Extraordinary
tune by tito's Avatar
USA, CA, Riverside
Joined May 2006
Long time ago(circa 1998-2003) when I was a "SITH"(Sorry but with the new Disney deal I Returned to be a "Jedi") I did develop a Programmable CDI for Mini ATV and motorcycles. I will like to see it been develop farther into today technology like Android Phones and USB.
Best Regards Tito
tune by tito is offline Find More Posts by tune by tito
Old Jan 19, 2013, 12:16 PM
gr8flyer55 is offline
Find More Posts by gr8flyer55
Joined Dec 2012
Nothing new for our dead ended project.
I am still getting ignition cut off after 4,000 rpm. Board power is still there, just quits sparking.
John
gr8flyer55 is offline Find More Posts by gr8flyer55
Old Jan 19, 2013, 10:42 PM
jakestew is offline
Find More Posts by jakestew
United States, ID
Joined Sep 2011
When did this start? Last I heard everything was working fine up to at least 14k RPM.
jakestew is offline Find More Posts by jakestew
Old Jan 22, 2013, 10:12 AM
Joined Dec 2012
Jake, I found the problem. Bad pic chip. I think it got zapped on my workbench with all the wires I have laying in my test area next to the ignition coil. I had it working fine, then heard sparks somewhere besides the coil. Figured I'd try a fresh chip and curves and found the chip wouldnt take a program. Working ok now.
Any updates on the 1840 chip programming?
John
Old Jan 22, 2013, 12:21 PM
jakestew is offline
United States, ID
Joined Sep 2011
I've been pretty busy with work, but I think I'm close to getting the OTF method working right. I'll be testing on my engine sometime this week. I'm waiting on my buddy to get a new tank of gas and weld up my new exhaust system. When that's don't I'll be able to run in the house and inside the shop, so that should make things a lot easier. It's pretty cold at the moment here to be working outside for any length of time.
Old Jan 22, 2013, 12:32 PM
Nav_Aids is offline
Nav_Aids's Avatar
Joined Nov 2011
.....It's pretty cold at the moment here to be working outside for any length of time.
How cold is cold Jake? It's cold here -31C/-23.8F with the windchill it's -40C/F
Ray
Old Jan 22, 2013, 12:55 PM
jakestew is offline
United States, ID
Joined Sep 2011
Ray
LOL, even I know I'm being a crybaby. I used to live in Minnesota and this is T-shirt weather compared to winters there.
Guess I'm habituated to the easy winters here by now. It had been somewhat cold here, but was just over freezing the past two days.
The main thing is my exhaust. I used a piece of aluminium plate to adapt the Homelite exhaust to a 50cc scooter exhaust pipe, which I cut off right after the bend. Then I welded on two lawn mower style mufflers, one skinny long one and one short fatter one. It works well, but my buddy ran out of gas and there are a couple leaks in the thing still. A two-stroke CAN be muffled down to sound like a 4-stroke, and my end muffler even stays cool to the touch. It's not suitable for flying the way I have it, but it should work good for my fan-boat/sled project.
Old Jan 22, 2013, 01:16 PM
Nav_Aids is offline
Nav_Aids's Avatar
Joined Nov 2011
I remember you saying you were from Minnesota, northern Minnesota has a windchill warning out also right now. Wish I could get a job in Hawaii, not to cold, not to hot.
I forgot to tell you, when I was a kid I made a Cox .049 air-boat that I use to run in the winter. It was free running so it was neat to watch it go all over the place, have fun.
Jake, do you know how many clock cycles it takes to do a read from the EEPROM memory in the cpu?
Ray
Old Jan 22, 2013, 01:32 PM
jakestew is offline
United States, ID
Joined Sep 2011
I think the reads are pretty fast. Write or erase takes 4-5ms.
IIRC the reads are tied to the clock, but write times are related to a certain amount of time and are pretty slow.
Old Jan 29, 2013, 11:20 AM
Gompy is offline
Find More Posts by Gompy
Gompy's Avatar
The Netherlands, NH, Alkmaar
Joined Dec 2012
Have fun.
Gompy is offline Find More Posts by Gompy
Old Feb 01, 2013, 09:13 PM
Joined Dec 2012
Rob, looks like you have some perfect tracking now with that video. Problems all solved for now?
John
Old Feb 04, 2013, 06:24 AM
Nav_Aids is offline
Nav_Aids's Avatar
Joined Nov 2011
Excellent work Rob.
By the way what Android software is that you are running? it looks handy.
Ray
Old Feb 07, 2013, 11:16 PM
Joined Dec 2012
Jake, how are doing with the OTF data changes?
Testing more changes to curves and settings, and test engine is getting a real workout this week. I have what seems to be my best curves since I started all of the testing of version #1. MSD cutoff at 2300 is working as expected. There is sometimes a slight delay when closing the kill switch for a maybe 1 or 2 seconds at mid rpm ranges. Odd.... It does work, just a slight delay. Had a receiver operated cutoff thru the Bitswitch circuit which I thought was the delay, but after testing with a manual pushbutton hard wired to the timer board, I got the same delays. It is not every time though, also odd. I can use my other direct CDI board kill and might just switch over to that one with the Bitswitch circuit instead.
I have some commercially made board samples. One for my old CDI board and one for the original timer. Both considerably smaller than my originals.
John
Old Feb 09, 2013, 01:25 PM
jakestew is offline
United States, ID
Joined Sep 2011
I'm trying to work out the hall delay factor so that the code can calculate for that. Hopefully I'll have a beta version sometime this week.
I still have to make up a spread sheet and figure out the final method of how the curves are defined. Right now I'm still running with a fixed advance. But it seems like things will pan out and the code will run faster and more accurately. Hopefully the RPM limit problem will also be worked out from the same changes.
Discussion CD Ignition lead and fixed plug .... solentlife Engines 10 Feb 18, 2014 11:03 AM
For Sale NIB 52cc Gas engine w/CD-Ignition 3.2kw kukntra Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jul 23, 2012 08:10 AM
Discussion Best open source autopilot vs commercial solution syncra Multirotor Talk 0 Apr 12, 2012 01:35 PM
Discussion Any Open Source / CC CAD Files for gliders? DrFragnasty Composites Fabrication 8 Apr 09, 2012 05:36 AM
Discussion I'm designing an open source quad frame. Inclusions anyone? Physics_Dude Multirotor Talk 3 Mar 11, 2012 12:22 PM
