View Poll Results: Whatís the most important thing to you?
Lowest possible cost 3 23.08%
Make it as small and light as possible 6 46.15%
Battery longevity is very important 3 23.08%
Highest power possible 3 23.08%
Highest RPM possible 2 15.38%
Only use through hole construction 2 15.38%
No winding of transformers 4 30.77%
Group buy of components including boards 0 0%
Group buy of boards only 1 7.69%
Iíd rather buy a kit with everything in it 0 0%
I want to buy a pre-built & pre-programmed system 0 0%
I only want to use a 4.8v Ni-MH battery 2 15.38%
I only want to use a 2S battery 1 7.69%
I only want to use a 3S battery 1 7.69%
I want to use a 4.8v battery to 3S battery 5 38.46%
I want to use only off the shelf parts from Digi-Key or Mouser 3 23.08%
I want the Timer board to be separate from the HV board 6 46.15%
I want a combination Timer & HV board 1 7.69%
I want all the options possible using jumpers 3 23.08%
I want a USB connection 2 15.38%
I want a serial connection (DB9) and Iíll use my own USB adapter 3 23.08%
I want a ICSP connection 3 23.08%
I want a premade parts list (BOM) at Digi-Key 2 15.38%
I want a premade project parts list (BOM) at Mouser 1 7.69%
I want 1 design and 1 design only 1 7.69%
I want optional designs to choose from and Ill make the boards myself 8 61.54%
Multiple Choice Poll. Voters: 13. You may not vote on this poll
Old Dec 30, 2012, 08:23 PM
bluejets is offline
Find More Posts by bluejets
Joined Dec 2012
Above install would not work so removed Mplab v1.10 and re-installed v 1.41.
It comes up with errors everywhere when one loads a C code in new projects but at least I can get a hex file out of it.
Hope the hex is ok, no way of knowing really.
I think the mplab is just a shoddy system, maybe look for some other compiler.
Just waste too much time on things that should work.
bluejets is offline Find More Posts by bluejets
Old Jan 01, 2013, 01:12 PM
gr8flyer55 is offline
Find More Posts by gr8flyer55
Joined Dec 2012
I think if you copy your source code into the projects directory and right click on the directory it should then show the source files available. Then by clicking on the source file it should load it without a problem. At least that's how I've been doing it. After it is loaded, you just click the hammer symbol to do the build. It will display some cautions and suggestions but ignore those. Do the build, then Find the hex it made. Should work, since that is what I've been doing and was successful.
John
gr8flyer55 is offline Find More Posts by gr8flyer55
Old Jan 01, 2013, 01:53 PM
Nav_Aids is offline
Find More Posts by Nav_Aids
Nav_Aids's Avatar
Canada, MB, Winnipeg
Joined Nov 2011
Lastest Spreadsheet Fixes
John (gr8flyer55), Guys, people I have uploaded the lastest fixed spreadsheets. Please see Post #4
for the lastest versions. John and I checked it and it is now copying the values correctly to the Code and Tables sheets.
Ray
Nav_Aids is offline Find More Posts by Nav_Aids
Old Jan 01, 2013, 03:10 PM
Gompy is offline
Find More Posts by Gompy
Gompy's Avatar
The Netherlands, NH, Alkmaar
Joined Dec 2012
Have fun.
Gompy is offline Find More Posts by Gompy
Old Jan 01, 2013, 03:26 PM
Nav_Aids is offline
Nav_Aids's Avatar
Joined Nov 2011
Originally Posted by Gompy View Post
Please use the right hardware.
Where can I get the correct ones?
Ray
Never mind Rob I figured it out.
Old Jan 01, 2013, 04:31 PM
bluejets is offline
Joined Dec 2012
I have seen this output transistor configuration before to try to get output inversion, and I think it could be a problem.
Connected as common emitter is fine, i.e. with R12 zero and R11 as 1K.
However, when you make R11 zero and R12 as 1K, it becomes a common collector configuration. In this mode, as the base starts to conduct, it causes the emitter voltage to rise and thus , turn off the transistor again. I think you may have problems getting it to saturate under this mode.
Old Jan 01, 2013, 04:42 PM
bluejets is offline
Joined Dec 2012
John
Yes,well, it's the installation errors that come up when getting near the end of the compiler install that concern me. Primarily because it states that the compiler may not work properly as it failed some test or other.
I think I will wait until Microchip supply some answers.
Old Jan 01, 2013, 04:49 PM
Nav_Aids is offline
Nav_Aids's Avatar
Joined Nov 2011
If R11 is 1k and R12 is 0 then the output is inverse to the input, sort of like an amplifier circuit. If R11 is 0 and R12 is 1k then this is an emitter follower and the output signal is in step with the input signal minus the biasing voltage. I'm being very simple about this because you can get into bypass caps and such but, thats for another time.
Ray
Old Jan 01, 2013, 05:10 PM
bluejets is offline
Joined Dec 2012
I'm pretty sure that's what I just said, but you miss the most important point.
Look again.
Old Jan 01, 2013, 09:40 PM
Nav_Aids is offline
Nav_Aids's Avatar
Joined Nov 2011
Look again.
What, saturation, the BC547, has a Vbe(sat) of just 0.7 volts and a max V(BR)EBO of just 6 volts and most raings given are at 5 volts.
Besides, I believe I used the wrong version because Gompy now uses a 4N25 opto there, I have to change the schematic.
Ray
Old Jan 02, 2013, 02:47 AM
bluejets is offline
Joined Dec 2012
You have no idea what I'm talking about.
I'll round up some theory for you to read.
Old Jan 02, 2013, 04:40 AM
Don m5aky is offline
Find More Posts by Don m5aky
Joined Dec 2012
Hi bluejets
Thanks for your reply to my post #83. OK about the limitations of the 628A. This is my first attempt so hope to make progress. The 628a version appeared promising as it looked easy to change the curve. My requirement is for up to 6000 rpm. I'll be looking at the links you provided and ito alternative circuits.
cheers
Don m5aky
Don m5aky is offline Find More Posts by Don m5aky
Old Jan 02, 2013, 06:41 AM
Nav_Aids is offline
Nav_Aids's Avatar
Joined Nov 2011
That would be nice.
Ray
Old Jan 02, 2013, 07:27 AM
Nav_Aids is offline
Nav_Aids's Avatar
Joined Nov 2011
Gompy I put up the latest Timer board design I could find, post #4. I hope I got it right this time.
Ray
Old Jan 08, 2013, 02:22 PM
jakestew is offline
Find More Posts by jakestew
United States, ID
Joined Sep 2011
Update
New spreadsheet versions posted on the website!
http://www.electrofunnel.com/CDI-2012/index.htm
A big thanks goes out to Ray Richter (Nav_Aids) for creating these versions!
Ray created these versions to fix a number of bugs in my spreadsheets. The v1.0 spreadsheets work great for me, running Excel 2007, on Windows XP SP3. However, it seems that several bugs crop up when using different Excel versions, and/or OS versions, and/or VB runtimes, and/or .Net framework versions. I have no way to test all these configurations, and I certainly can't fix all of Micro$oft's bugs, so Ray's mastery of VBA and Excel macros, and knowledge of the many version compatibility problems, have really helped the project. All future spreadsheets will be based off of these.
I suggest downloading the v1.0 release .zip file, then replacing the spreadsheet contained in them with Ray's new version. The old v1.0 release file will remain on the website for historical reasons and because I'm too busy (and lazy) to mess with it. If anyone needs or wants any of the old, pre-v1.0 code versions feel free to email or PM me. (my email is on the website)
-Jake
jakestew is offline Find More Posts by jakestew
Discussion CD Ignition lead and fixed plug .... solentlife Engines 10 Feb 18, 2014 11:03 AM
For Sale NIB 52cc Gas engine w/CD-Ignition 3.2kw kukntra Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jul 23, 2012 08:10 AM
Discussion Best open source autopilot vs commercial solution syncra Multirotor Talk 0 Apr 12, 2012 01:35 PM
Discussion Any Open Source / CC CAD Files for gliders? DrFragnasty Composites Fabrication 8 Apr 09, 2012 05:36 AM
Discussion I'm designing an open source quad frame. Inclusions anyone? Physics_Dude Multirotor Talk 3 Mar 11, 2012 12:22 PM
