Old Dec 02, 2012, 11:26 PM
efast is offline
Find More Posts by efast
Joined Nov 2012
Nine Eagles SKY CLIMBER right aileron not working, out of the box
I connected everything, but the right aileron refuses to move. I checked the receiver, all connectors in correct place, right aileron = slot 1, left aileron = slot 5
see video:
https://dl.dropbox.com/u/55140017/ri...%20working.mp4
is the servo broken? out of the box
thanks guys
efast is offline Find More Posts by efast
Old Dec 03, 2012, 12:19 AM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
swap the servo connectors at the receiver.
If the right aileron still doesn't work, the servo is broken or the linkage is glued/stuck.
If the right aileron works and the left aileron is now bad, the transmitter-receiver is suspect.
Replace the receiver, put it all together, test it again, If the same issue remains, the transmitter is defective.
Did you resolve your balance charger issue in your other thread?
http://www.rcgroups.com/forums/showthread.php?t=1781150
rick.benjamin is offline Find More Posts by rick.benjamin
Old Dec 03, 2012, 03:15 AM
efast is offline
Joined Nov 2012
Thanks for your help
I swapped the servo connectors at the receiver, no hope, and right aileron servo still not moving. I suspect it is either the servo or the linkage.
Balance charger issue still there, plugging the battery in no use, I’m guessing either the charger is broken or the adapter feeding the charger supply incorrect voltage/current
The thing is all this new from the shop, do I need to pay for replacements (servos/adapter) at my own expense given technically it is the new product's fault?
Discussion Nine Eagles 776 Sky Climber RC Glider balance charger flashing RED efast Electric Sailplanes 6 Apr 08, 2015 02:46 PM
Discussion Cox Sky Cruiser / Nine Eagles Sky Runner Mod Thread, SpekTrum, B-Less & Ailerons ShokWaveRider Foamies (Kits) 31 Jun 08, 2014 05:21 PM
Wanted Nine eagles sky climber. 70frankie Aircraft - Sailplanes (FS/W) 1 Jun 21, 2012 07:43 PM
Wanted Nine eagles sky climber 70frankie Aircraft - Electric - Airplanes (FS/W) 4 Jun 21, 2012 03:20 PM
Found Nine Eagles Sky Climber skydvejam Aircraft - Sailplanes (FS/W) 2 Mar 30, 2012 02:58 AM
