This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Old Dec 02, 2012, 10:15 PM
Jack Crossfire is offline
Find More Posts by Jack Crossfire
Jack Crossfire's Avatar
Calif*
Joined Sep 2006
raspberry pi comes to life
Keeping the camera mount in its laser painter form wasn't an option, because there wasn't enough room to store every gadget. Now, the tripod blind nut & more of the wood had to go. 3 circuit boards have to go on it.
There were a number of options. Wifi ended up having too many dropouts to be used in any feedback loop, but would have to be used when communicating with a tablet.
So all the intense vision processing had to be done on the camera mount, wired to the cameras. The camera mount required an access point to communicate with a tablet for the user interface.
In the old days, this would have required an FPGA or DSP with custom software. Nowadays, a 1Ghz linux board computer can do it very cheaply. The computational requirement meant the STM32F407 was completely out of this project. A common webcam + board computer was the cheapest method.
Once the SD card is flashed & the right pins are soldered to 5V, GND, & UART, the raspberry pi runs exactly like any other board computer you know & love. It has a single serial console, network interface, & USB. USB is your only realistic path to the hardware world.
Steps to bringing it up:
log in as
user: pi
passwd: raspberry
enable root login:
sudo passwd root
step up to 1Ghz & reduce video RAM:
raspi-config
/boot/config.txt contains the settings
enable static ethernet:
vi /etc/network/interfaces
change
iface eth0 inet dhcp
to
iface eth0 inet static
address 10.0.0.11
netmask 255.255.255.0
gateway 10.0.0.9
disable swap file:
vi /etc/init.d/dphys-swapfile
fix slow ssh login:
vi /etc/hosts
Maximum CPU speed:
echo userspace > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo 1000000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed
Download cross compiler from:
https://github.com/raspberrypi/tools
So far, it needs 0.5A when idle. That requires a modern USB charger wall wart, a PC power supply, or a really big, heavy, bench supply.
Jack Crossfire is offline Find More Posts by Jack Crossfire
Discussion Raspberry Pi for multi rotor 360walt Multirotor Talk 15 Apr 15, 2013 09:33 AM
Discussion South Fork comes back to life Aerogance Dynamic Soaring 2 Oct 05, 2012 12:47 AM
Discussion Raspberry pi discussion. chaosdestro0 Multirotor Talk 1 Feb 19, 2012 01:41 PM
New Product Raspberry Pi $35 Capture device or more? CzechPilot FPV Talk 6 Jan 27, 2012 02:52 PM
Discussion Raspberry Pi - Autopilot game changer? CenTexFlyer UAV - Unmanned Aerial Vehicles 10 Sep 17, 2011 04:27 PM
