Old Dec 02, 2012, 08:04 PM
proppy jon is offline
Find More Posts by proppy jon
Original Bloody Spadder
proppy jon's Avatar
phoenix
Joined Jul 2004
Question
ober winch users
bought a ober winch from skip miller used it the first time at f3j in dec could some one explain the drum spacers(change diameter of drum) that come with the winch they spin on the drum id think they would wedge on with the end plate but when its tight the spin john
proppy jon is offline Find More Posts by proppy jon
Old Dec 02, 2012, 09:51 PM
tewatson is online now
Find More Posts by tewatson
Riddle me this...
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
I use a few layers of blue masking tape across one end, positioned edge-to-edge so there are no bumps, and rotating subsequent layers so the seams criss-cross. Then use a sharp knife to trim away to the sleeve edges inside and out.
Tom
tewatson is online now Find More Posts by tewatson
Old Dec 03, 2012, 02:05 AM
satinet is offline
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
Mine does it.... Seems to work okay though. They all do it from what I have seen.
satinet is offline Find More Posts by satinet
Old Dec 03, 2012, 02:26 AM
luvF3b is offline
Find More Posts by luvF3b
launch high, go fast
luvF3b's Avatar
Australia, TAS, Devonport
Joined May 2008
I have one too.
I didn't think the drum sleeve spinning was such a big issue. The drum end cap has 3 holes drilled at diameters matching the sleeves for attaching the line. If the line is attached using these, the drum sleeve is captured after several wraps of the line around the drum.
John
luvF3b is offline Find More Posts by luvF3b
Old Dec 03, 2012, 10:25 AM
cody303 is offline
Find More Posts by cody303
cody303's Avatar
Louisville, Colorado
Joined Nov 2003
Hey Guys,
We just use a little masking tape like Tom does. The line does self lock the drums after the first layer of line gets on it.
Cody
cody303 is offline Find More Posts by cody303
Site Sponsor
Old Dec 03, 2012, 12:40 PM
Riddle me this...
tewatson's Avatar
Joined Oct 2006
The problem comes when tensioning the line with the brake off, to adjust the winch alignment or just straighten the line on the ground during use. When you let off the pedal and the drum spins backwards with a loose sleeve, the drum can actually spin faster than the sleeve...then you can end up with a real rats nest.
Tom
Old Dec 03, 2012, 01:27 PM
proppy jon's Avatar
phoenix
Joined Jul 2004
yes tom ober yesterday was a long day thanks for the reply
so i didnot tie line in end of drum i thought all the tension would be on the end i judt looped with a slip knot so ill cnc cut a thin piece of g10 for a spacerthat should do it do you guys tie to the end of the drumand the line does not fail??
Old Dec 03, 2012, 01:51 PM
satinet is offline
F3B
satinet's Avatar
Joined Sep 2006
Attach the line through one of the holes in the end plate. I don't know what you mean about line failing tbh.
All the force does move to the free hanging end of the winch when the line is under tension at that end. That is a downside of the single sided winch i guess. Still works though.
Bear in mind the ober is the most common f3b winch out there. It works.
Old Dec 03, 2012, 02:32 PM
proppy jon's Avatar
phoenix
Joined Jul 2004
breaking from the aluminum end plate cutting it sounds like this isnt happening
Old Dec 03, 2012, 02:51 PM
jimsoars is offline
Find More Posts by jimsoars
United States, CO, Broomfield
Joined Jan 2003
No - that is how I do it.
Jim
jimsoars is offline Find More Posts by jimsoars
Old Dec 05, 2012, 11:48 AM
stefanoc2 is offline
Find More Posts by stefanoc2
stefanoc2's Avatar
United States, TX, Houston
Joined Aug 2006
Did you drill a new hole to pull the braided line throught the end of the drum? The hole for the mono is to small for the braided line.
Stefano
stefanoc2 is offline Find More Posts by stefanoc2
Old Dec 05, 2012, 11:56 AM
Kiesling is online now
Find More Posts by Kiesling
San Diego
Joined Aug 2004
Stefano
I just tie a small piece of mono to the end of the braided line and feed that through the hole. The idea of modifying the Ober winch permanently for braided line somehow seems wrong to me . . .
Tom
Kiesling is online now Find More Posts by Kiesling
Old Dec 05, 2012, 12:24 PM
jimsoars is offline
Joined Jan 2003
Tom
But it was not wrong to me - so that is what I did...
Jim
Old Dec 05, 2012, 12:29 PM
Riddle me this...
tewatson's Avatar
Joined Oct 2006
Egad...that would be like gluing Barbie arms on the Venus de Milo. We just tie a loop around the drum with a hitch so it locks under tension.
Tom
Old Dec 05, 2012, 04:01 PM
mlachow is offline
Find More Posts by mlachow
Joined Oct 2005
Stefano
You start flying F3b and then you don't have any reason for braided line.
mlachow is offline Find More Posts by mlachow
Discussion Tolerance, as demonstrated by Uber-libs. Twizter68 Life, The Universe, and Politics 34 Jul 12, 2012 04:03 PM
Sold Uber Rare Beeline Fokker Triplane NNIB jcstalls Aircraft - Electric - Airplanes (FS/W) 2 Jul 10, 2012 11:27 AM
Sold Christen Eagle (Great Planes) uber cheap viper69 Aircraft - Electric - Airplanes (FS/W) 1 May 13, 2012 09:08 PM
Gallery Uber cool feature offered by Tamron-USA Kmot Dock Talk 1 May 02, 2012 06:55 AM
Sold Winch (Little Big Winch) Brand New curtusua Aircraft - Sailplanes (FS/W) 3 Mar 23, 2012 04:26 PM
