United States, TN, Hixson
Joined Nov 2012
My x525 build thread
Hey everyone, I'm starting to feel over my head a bit here, so I figured I'd post up in here and see what advice I can get.
-------------------------------------------------------------------------------------------------------------------------------------------- EDIT:Here are the final parts I used:
-------------------------------------------------------------------------------------------------------------------------------------------- My first goal is to get it flying stable without any FPV gear, get practice flying it LOS. Planning on using my DX6i for now. So, I know I'm going to need a receiver, power dist board, wire, connectors, batteries, charger, shrink wrap, heat gun, soldering iron, solder, flux, 3rd hand, zip ties.
I've had a hard time getting good examples of x525 builds. I haven't even figured out where people are mounting the battery and cameras. Anyway, I have a lot of research to do still, I know. But if anyone has any info off the top of their head, I would greatly appreciate anyone sharing. I will keep this thread updated when I start the actual build as well, and hopefully someone down the line can learn from it. EDIT: Found THIS LINK with info on these motors. Am I reading this right? Looks to me like it says I need 40A ESCs for these motors. Max current on the motors on that same chart is 16.80A and the 18A plush ESCs I have are rated for 18A continuous, 22A burst. Also, I have two sets of props, one are 9x4.7, other are 10x4.5. So, let's break this down...
Joined Nov 2012
My first quad I used the KK V1 and it was horrible to setup. Flies crappy, allot of manual trim. The KK2 was a different story, so easy, and stable. The KK V1 will work, but I had to trial allot of versions to flash in order to it compatible to my ESCs. The KK2 is a breeze 100% improvement. No flashing, and LED interface is great. Save the KK1 for another cheap build...
The KK2 is great for noobs :P easy to set up and such also if you get the X525 Kit you need these the stock ones are crap
http://www.ebay.com/itm/160757154600...84.m1423.l2649 Here is a couple pics to give you an idea does not need to be just like mine to work but will give you some basic ideas to work with...Quote:
Joined Nov 2012
Where are your ESCs? What's with the standoffs and extra plate above kk2? You using a PDB or just a harness? |
| Thread Tools | |
| Discussion My Eurofighter build thread.. | rusty_y2k2 | Video Piloting (FPV/RPV) | 79 | Mar 23, 2013 07:57 PM |
| Discussion My Maxi Swift FPV build thread | DaveyLC | Flying Wings | 8 | Nov 13, 2012 03:35 AM |
| Help! Help with a kk2.0 quadcopter build (check my shoplist thread) | metap0Pe | Multirotor Talk | 12 | Oct 14, 2012 06:23 AM |
| Question My First Multi Rotor - Learning / Build Thread | sykmethodz | Multirotor Talk | 7 | Oct 11, 2012 08:12 PM |
