Old Dec 02, 2012, 04:49 PM
templton89 is online now
Find More Posts by templton89
templton89's Avatar
United States, NY, Kings County
Joined Nov 2011
Mini-Review
New RCTimer motors. HP series. The good and the Bad
Couple weeks ago rctimer was down for a few days and it came back up and had new motors.
I was shopping around for popular 2830-8 1300KV outrunners,
when I came across similar motor, but with a different name. HP2812-1300KV , specs are pretty much identical, but this one is advertised to have higher performance and "sale" price was very tempting. I ordered 4 for an Armatan style quad to use with 8x4 props.
Previously I had turnigy 2826-2200kv motors on it, and it was a bad fit, SF props slowed it down, but I was wasting prescious mAh's..
In case anyone is curious - my quad has 6" arms, AUW is 860g and I use 3s 2200mah 45c lipo and 30a esc
Took it for a flight today , first impression was great. Nice and smooth, plenty of power and speed for 3D flying.
Bearings were indeed smooth compared to previous rctimer models.
Motor mount and prop adapters were made of better materials, and didn't feel like cheese. If you've ever used older rctimer stuff, you know that those mounts are as soft as tin can.
Wires are longer and thinner than your typical brushless outrunner in this class. Also more flexible.
All in all it seemed like a solid product, and for $13 each, I couldn't be happier.
However fun was over when one of the motors came apart after a few flights. Luckily I was ~20-30ft up in the air and was flying on top of grass. It looks like the e-clip either came off, or broke off and released the shaft. I was lucky enough to get away with as little damage as bent arm, which I can fix, but I'll be very carefully with these motors from now on.
However I'd like to believe it's just a single case and wont happen again. I was always very happy with rctimer motors and even after trashing them for a while, they still held together and performed well.
I'll try to find another e-clip and will take it for a flight tomorrow morning, and will report back.
Curious to hear others opinions on these motors, and if anyone else got them. Im thinking about buying some more before flash discount ends.
templton89 is online now Find More Posts by templton89
Old Dec 05, 2012, 05:19 PM
quad007 is offline
Find More Posts by quad007
DOLLA DOLLA BILL YALL
quad007's Avatar
United States, FL, Orlando
Joined Oct 2012
thanks for this, was wondering how good these motors are
quad007 is offline Find More Posts by quad007
Old Dec 06, 2012, 07:36 AM
templton89's Avatar
Joined Nov 2011
Other than failed clip (which may or may not have been my fault) they run reall smooth. I'm considering getting another set before sale ends.
Old Dec 07, 2012, 08:12 PM
templton89's Avatar
Joined Nov 2011
here is a quick video I put together using these motors
Destroying Armattan quad + testing new RCTimer HP motors (1 min 48 sec)
Old Dec 08, 2012, 02:54 AM
Torque66 is online now
Find More Posts by Torque66
Noob
Torque66's Avatar
Canada, ON, Toronto
Joined Dec 2011
Hey Dude thx for the info... was looking for some 4s motors and these look good for the price.
How are the holding up so far?
Torque66 is online now Find More Posts by Torque66
Old Dec 08, 2012, 03:37 AM
Great_Dane is offline
Find More Posts by Great_Dane
Woof!
Denmark, Region Zealand, Roskilde
Joined Oct 2012
RCTimer has a bag of 10 of those clips for around one dollar:
http://www.rctimer.com/index.php?gOo....x=0&image.y=0
Great_Dane is offline Find More Posts by Great_Dane
Old Dec 08, 2012, 03:51 AM
ecks is offline
Find More Posts by ecks
Knowledge prevents flyaways
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
I love your flying! Great music choice too
ecks is offline Find More Posts by ecks
Old Dec 08, 2012, 06:57 AM
oyibox is offline
Find More Posts by oyibox
Joined Jun 2011
the only thing is i do not like is the motor props adapter
this is my quad with HP2212 1000kv
http://www.rcgroups.com/forums/showp...5&postcount=14
oyibox is offline Find More Posts by oyibox
Old Dec 08, 2012, 11:56 AM
templton89's Avatar
Joined Nov 2011
so far alright, even thought one of them is packing some serious dirt at the moment I haven't repaired after last crash in the video
the thing is that we're not supposed to need those, because it's not just a clip we lose, it's an aircraft that is in potential danger. For me personally it's just a pain in the ass to drill holes in new aluminum tube and screw everything in once again.
thanks, but it takes it's toll as you saw from the intro
actually these prop adapters and mounts seem to be sturdier than other rctimer stuff, you can't bend them with your fingers. At least not as easy. And also I got used to them, maybe not the most optimal solution but for sport flying it's enough.
Old Dec 08, 2012, 06:37 PM
98 SNAKE EATER is offline
Find More Posts by 98 SNAKE EATER
Queens, NY and sometimes Orlando, FL
Joined Sep 2003
Are the wires the same thin gauge stuff they used on the purple morors?
98 SNAKE EATER is offline Find More Posts by 98 SNAKE EATER
Old Dec 08, 2012, 07:11 PM
quad007 is offline
quad007's Avatar
Joined Oct 2012
yes it looks a bit thin, but no thinner than turnigy NTM wires.
Old Dec 08, 2012, 08:19 PM
templton89's Avatar
Joined Nov 2011
they are thinner than on purple motors, however they seem to be different material. Purple ones had large lose wire sleeve, and it would always break. Also those wires were a pain in the rear to solder in case you broke it or wanted to extend it.
HP stuff has more flexible thinner wire, with a nicely fitted sleeve whch is made of much better silicone rubber
If I remember correctly NTM wires were fairly thick, short and not flexible at all. Also it might be just my experience, but NTMs felt heavy and too power hungry compared to other motors in same class.
Old Jul 21, 2014, 10:22 PM
brianksh is offline
Find More Posts by brianksh
Joined Oct 2013
Today I had a problem with one of the six HP 2826 motors (3548 with blue bell) I purchased from UAVobjects. I found that the small worm screw that holds the bell on the motor shaft was loose allowing the bell to rotate faster than the motor shaft, You can imagine what happened. Good thing I was only 2 feet off the ground when it tipped sideways and fell. 3 minute before that I had it a good 12 feet in the air, and was going to raise up to tree top level, but heard one motors RPM going high than the rest and my hex seemed a little unstable so I kept it low to the ground.
So quality control is an issue with this and maybe other Rctimer motors. I must admit up until then, the motors flew flawlessly and had lots of power. I could hover at 40 to 45% throttle! However if the motor shaft and bell become loosened from one another that is a nasty accident waiting to happen.
Update 7/29/2014
I sent the two motors back to UAVObjects (RCTimers USA warehouse) where I purchased them and they stated they couldn't find any problem with them and sent them back to me!
I told them exactly what the problem was and they didn't check to insure the bell and motor shaft didn't rotate independently of one another. So buy at your own risk. Their quality control needs a major overhaul if they can't tell that the motor bell isn't tight to the motor shaft. Most companies use two grub screws to lock the bell to the motor shaft to insure no slippage, so why does RCTimer use just one very small (.09mm) grub screw on such a big powerful motor? Especially when there 3 areas where grub screws could have been placed.
I gave them one more chance to correct this issue before I take further action. Hopefully they will send me new motors.
brianksh is offline Find More Posts by brianksh
Last edited by brianksh; Jul 29, 2014 at 07:02 PM. Reason: Update on Rctimer HP 2826 770 KV motors.
4 x Brand new RCTIMER BC3536-11 750KV Outrunner Brushless Motors anixs Non R/C Items (FS/W) 15 Sep 21, 2012 08:39 PM
Discussion New rctimer motor 4215 (3507) , anyone try it yet caotri Multirotor Talk 19 Aug 01, 2012 06:33 PM
Sold <<<<<<NEW LOW GREAT PRICE>>>>>Saito FA 150 S HP HIGH POWERED HIGH CAM SERIES crosby Aircraft - Fuel - Engines and Accessories (FS/W) 5 Mar 31, 2012 12:35 PM
Sold NEW RCTimer BC-1712/15 1600KV motor - $10 shipped shawn595 Aircraft - Electric - Power Systems (FS/W) 9 May 20, 2010 07:09 PM
Sold Hyperion Motor Mount for Z40 Series HP-Z40-FRMNT new for $16.50 DrAGen Aircraft - Electric - Power Systems (FS/W) 0 Oct 10, 2008 12:47 PM
